Hardware
DVA-C02 exam collection: AWS Certified Developer - Associate & DVA-C02 torre
Posted at 1/13/2026 09:42:07
View178
Replies0
2026 Latest GetValidTest DVA-C02 PDF Dumps and DVA-C02 Exam Engine Free Share: https://drive.google.com/open?id=1udbgAxLroSii1n7IpGlGCQDVzNzGDmsM
The web-based Amazon DVA-C02 practice exam does not require special plugins and creates a DVA-C02 testing atmosphere that removes candidates exam anxiety. "GetValidTest" web-based AWS Certified Developer - Associate (DVA-C02) practice test tracks your progress and helps you overcome mistakes. Our Amazon DVA-C02 practice exam software displays results at the end of each attempt.
The customers can immediately start using the AWS Certified Developer - Associate (DVA-C02) exam dumps of GetValidTest after buying it. In this way, one can save time and instantly embark on the journey of AWS Certified Developer - Associate (DVA-C02) test preparation. 24/7 customer service is also available at GetValidTest. Feel free to reach our customer support team if you have any questions about our DVA-C02 Exam Preparation material.
Desktop-Based Amazon DVA-C02 Practice Test SoftwareOur company employs experts in many fields to write DVA-C02 study guide, so you can rest assured of the quality of our learning materials. What's more, preparing for the exam under the guidance of our DVA-C02 exam questions, you will give you more opportunities to be promoted and raise your salary in the near future. So when you are ready to take the exam, you can rely on our DVA-C02 Learning Materials. If you want to be the next beneficiary, what are you waiting for? Come and buy our DVA-C02 learning materials.
Amazon DVA-C02 (AWS Certified Developer - Associate) certification exam is an industry-recognized certification for developers who want to validate their expertise in developing and maintaining applications on the Amazon Web Services (AWS) platform. AWS Certified Developer - Associate certification is designed for professionals who have experience in designing and developing cloud-based applications using AWS services.
Amazon DVA-C02 Exam is intended for developers who have one or more years of experience in developing and maintaining AWS-based applications. DVA-C02 exam covers a wide range of topics such as AWS core services, application deployment, security, and troubleshooting, among others. DVA-C02 exam consists of multiple-choice questions and has a time limit of 130 minutes.
Amazon AWS Certified Developer - Associate Sample Questions (Q88-Q93):NEW QUESTION # 88
A company receives food orders from multiple partners. The company has a microservices application that uses Amazon API Gateway APIs with AWS Lambda integration. Each partner sends orders by calling a customized API that is exposed through API Gateway. The API call invokes a shared Lambda function to process the orders.
Partners need to be notified after the Lambda function processes the orders. Each partner must receive updates for only the partner's own orders. The company wants to add new partners in the future with the fewest code changes possible.
Which solution will meet these requirements in the MOST scalable way?
- A. Create an Amazon Simple Notification Service (Amazon SNS) topic. Configure the Lambda function to publish messages with specific attributes to the SNS topic. Subscribe each partner to the SNS topic.
Apply the appropriate filter policy to the topic subscriptions. - B. Create one Amazon Simple Notification Service (Amazon SNS) topic. Subscribe all partners to the SNS topic.
- C. Create a different Amazon Simple Notification Service (Amazon SNS) topic for each partner.
Configure the Lambda function to publish messages for each partner to the partner's SNS topic. - D. Create a different Lambda function for each partner. Configure the Lambda function to notify each partner's service endpoint directly.
Amazon Simple Notification Service (Amazon SNS) is a fully managed messaging service that enables pub/sub communication between distributed systems. The developer can create an SNS topic and configure the Lambda function to publish messages with specific attributes to the topic. The developer can subscribe each partner to the SNS topic and apply the appropriate filter policy to the topic subscriptions. This way, each partner will receive updates for only their own orders based on the message attributes. This solution will meet the requirements in the most scalable way and allow adding new partners in the future with minimal code changes.
[Amazon Simple Notification Service (SNS)]
[Filtering Messages with Attributes - Amazon Simple Notification Service]
NEW QUESTION # 89
A developer works for a company that only has a single pre-production AWS account with an AWS CloudFormation AWS Serverless Application Model (AWS SAM) stack. The developer made changes to an existing AWS Lambda function specified in the AWS SAM template and additional Amazon Simple Notification service (Amazon SNS) topics.
The developer wants to do a one-time deploy of the changes to test if the changes are working.
The developer does not want to impact the existing pre-production application that is currently being used by other team members as part of the release pipeline.
Which solution will meet these requirements?
- A. Update the CloudFormation stack in the pre-production account. Add a separate stage that points to a new AWS account designated for a development environment.
- B. Use the AWS SAM CLI to package and deploy the SAM application to a new AWS account designated for a development environment.
- C. Use the AWS SAM CLI to package and create a change set against the pre-production AWS account. Execute the change set in a new AWS account designated for a development environment.
- D. Use the AWS SAM CLI to package and deploy the SAM application to the pre-production AWS account. Specify the debug parameter.
https://docs.aws.amazon.com/serv ... uide/using-sam-cli- deploy.html
NEW QUESTION # 90
A developer is building an application that uses Amazon DynamoDB. The developer wants to retrieve multiple specific items from the database with a single API call. Which DynamoDB API call will meet these requirements with the MINIMUM impact on the database?
- A. BatchGetltem
- B. Query
- C. Scan
- D. Getltem
NEW QUESTION # 91
A company hosts a batch processing application on AWS Elastic Beanstalk with instances that run the most recent version of Amazon Linux. The application sorts and processes large datasets. In recent weeks, the application's performance has decreased significantly during a peak period for traffic. A developer suspects that the application issues are related to the memory usage. The developer checks the Elastic Beanstalk console and notices that memory usage is not being tracked.
How should the developer gather more information about the application performance issues?
- A. Configure the Elastic Beanstalk .ebextensions directory to track the memory usage of the instances.
- B. Configure the Amazon CloudWatch agent to track the memory usage of the instances.
- C. Configure an Amazon CloudWatch dashboard to track the memory usage of the instances.
- D. Configure the Amazon CloudWatch agent to push logs to Amazon CloudWatch Logs by using port 443.
Comprehensive Detailed Explanation with all AWS Reference
To monitor memory usage in Amazon Elastic Beanstalk environments, it's important to understand that default Elastic Beanstalk monitoring capabilities in Amazon CloudWatch do not track memory usage, as memory metrics are not collected by default. Instead, the Amazon CloudWatch agent must be configured to collect memory usage metrics.
Why Option C is Correct:
The Amazon CloudWatch agent can be installed and configured to monitor system-level metrics such as memory and disk utilization.
To enable memory tracking, developers need to install the CloudWatch agent on the Amazon Elastic Compute Cloud (EC2) instances associated with the Elastic Beanstalk environment.
After installation, the agent can be configured to collect memory metrics, which can then be sent to CloudWatch for further analysis.
How to Implement This Solution:
Install the CloudWatch Agent:
Use .ebextensions or AWS Systems Manager to install and configure the CloudWatch agent on the EC2 instances running in the Elastic Beanstalk environment.
Modify CloudWatch Agent Configuration:
Create a config.json file that specifies memory usage tracking and other desired metrics.
Enable Metrics Reporting:
The CloudWatch agent can push the metrics to CloudWatch, where they can be monitored.
Why Other Options are Incorrect:
Option A: Configuring the agent to push logs is not sufficient to track memory metrics. This option addresses logging but not system-level metrics like memory usage.
Option B: The .ebextensions directory is used to customize Elastic Beanstalk environments but does not directly track memory metrics without additional configuration of the CloudWatch agent.
Option D: Configuring a CloudWatch dashboard will only visualize the metrics that are already being collected. It will not enable memory usage tracking.
AWS Documentation Reference:
Amazon CloudWatch Agent Overview
Elastic Beanstalk Customization Using .ebextensions
Monitoring Custom Metrics
NEW QUESTION # 92
A company wants to deploy and maintain static websites on AWS. Each website's source code is hosted in one of several version control systems, including AWS CodeCommit, Bitbucket, and GitHub. The company wants to implement phased releases by using development, staging, user acceptance testing, and production environments in the AWS Cloud. Deployments to each environment must be started by code merges on the relevant Git branch. The company wants to use HTTPS for all data exchange. The company needs a solution that does not require servers to run continuously. Which solution will meet these requirements with the LEAST operational overhead?
- A. Host each website in different Amazon S3 buckets for each environment. Configure AWS CodePipeline to pull source code from version control. Add an AWS CodeBuild stage to copy source code to Amazon S3.
- B. Host each website in AWS Elastic Beanstalk with multiple environments. Use the EB CLI to link each repository branch. Integrate AWS CodePipeline to automate deployments from version control code merges.
- C. Host each website by using AWS Amplify with a serverless backend. Conned the repository branches that correspond to each of the desired environments. Start deployments by merging code changes to a desired branch.
- D. Host each website on its own Amazon EC2 instance. Write a custom deployment script to bundle each website's static assets. Copy the assets to Amazon EC2. Set up a workflow to run the script when code is merged.
AWS Amplify is an all in one service for the requirement.
https://docs.aws.amazon.com/amplify/latest/userguide/welcome.html
NEW QUESTION # 93
Many candidates find the Amazon DVA-C02 exam preparation difficult. They often buy expensive study courses to start their Amazon DVA-C02 certification exam preparation. However, spending a huge amount on such resources is difficult for many Amazon DVA-C02 Exam applicants.
DVA-C02 Examcollection Dumps Torrent: https://www.getvalidtest.com/DVA-C02-exam.html
- DVA-C02 New Braindumps 😖 DVA-C02 Reliable Exam Camp 🥽 Latest DVA-C02 Braindumps 🙎 Search for DVA-C02 and download it for free immediately on ⏩ [url]www.verifieddumps.com ⏪ 🚝Training DVA-C02 Kit[/url]
- DVA-C02 Exam Quick Prep 🥊 DVA-C02 Reliable Test Guide 🌰 DVA-C02 Reliable Test Guide 😯 Search for ✔ DVA-C02 ️✔️ and easily obtain a free download on ➡ [url]www.pdfvce.com ️⬅️ 🌀Training DVA-C02 Kit[/url]
- DVA-C02 Reliable Test Guide 😍 Valid DVA-C02 Dumps 🏬 Training DVA-C02 Kit 🌉 Search for ✔ DVA-C02 ️✔️ and easily obtain a free download on ▛ [url]www.practicevce.com ▟ 🦸DVA-C02 Exam Quick Prep[/url]
- DVA-C02 Reliable Exam Camp 🎨 Valid DVA-C02 Dumps ❔ DVA-C02 Valid Exam Questions 🐝 Simply search for DVA-C02 for free download on ▷ [url]www.pdfvce.com ◁ ➰Reliable DVA-C02 Test Voucher[/url]
- Top DVA-C02 Dumps 🪁 Latest DVA-C02 Exam Duration 😇 Reliable DVA-C02 Test Voucher 👱 Copy URL ⇛ [url]www.exam4labs.com ⇚ open and search for DVA-C02 to download for free 🦅DVA-C02 Reliable Test Guide[/url]
- High-quality Pass DVA-C02 Guarantee, Ensure to pass the DVA-C02 Exam 💛 Search on [url]www.pdfvce.com for ⏩ DVA-C02 ⏪ to obtain exam materials for free download 🛌DVA-C02 Related Certifications[/url]
- 100% Pass 2026 Amazon Valid DVA-C02: Pass AWS Certified Developer - Associate Guarantee 🎍 Download ➥ DVA-C02 🡄 for free by simply searching on [ [url]www.troytecdumps.com ] 🕤DVA-C02 Valid Exam Camp[/url]
- TOP Pass DVA-C02 Guarantee 100% Pass | Trustable AWS Certified Developer - Associate Examcollection Dumps Torrent Pass for sure 🪕 Simply search for DVA-C02 for free download on { [url]www.pdfvce.com } 😂DVA-C02 Exam Dumps Free[/url]
- Valid DVA-C02 Exam Fee 🔼 DVA-C02 Valid Exam Camp 💉 Top DVA-C02 Dumps 🛄 ➤ [url]www.pass4test.com ⮘ is best website to obtain ☀ DVA-C02 ️☀️ for free download 🌒DVA-C02 Reliable Test Guide[/url]
- Latest DVA-C02 Exam Duration 🗣 DVA-C02 Related Certifications ⛅ DVA-C02 Reliable Test Guide 🚍 Search for DVA-C02 and download it for free immediately on [url]www.pdfvce.com 🔎DVA-C02 Valid Exam Questions[/url]
- Amazon DVA-C02 Unparalleled Pass Guarantee 🦺 Search for ☀ DVA-C02 ️☀️ and obtain a free download on [url]www.examcollectionpass.com 🖼Latest DVA-C02 Braindumps[/url]
- wanderlog.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, thetradeschool.info, zzhan.cn, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, academy.eleven11prod.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, financialtipsacademy.in, Disposable vapes
P.S. Free & New DVA-C02 dumps are available on Google Drive shared by GetValidTest: https://drive.google.com/open?id=1udbgAxLroSii1n7IpGlGCQDVzNzGDmsM
