[General] New AWS-Solutions-Architect-Associate Test Sample - AWS-Solutions-Architect-Asso
96
【General】 New AWS-Solutions-Architect-Associate Test Sample - AWS-Solutions-Architect-Asso
Posted at 1/13/2026 10:47:18      View:157 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Exam-Killer AWS-Solutions-Architect-Associate dumps for free: https://drive.google.com/open?id=1ooDsGbGhT_S8Fm_JZZevuWdH4XrZKBKy
Professionals who hold AWS-Solutions-Architect-Associate certification demonstrate to their employers and clients that they have the knowledge and skills necessary to succeed in the industry. To meet the growing demand for Amazon AWS-Solutions-Architect-Associate certification exam, preparation platforms have emerged in recent years. Exam-Killer offers candidates actual AWS-Solutions-Architect-Associate Questions Pdf, practice exams, and 24/7 support to ensure they have the best possible preparation for the exam.
The AWS Certified Solutions Architect - Associate (SAA-C02) certification exam is a highly sought-after certification by individuals and organizations alike. AWS-Solutions-Architect-Associate Exam is designed to test the knowledge and skills of candidates in designing and deploying scalable, highly available, and fault-tolerant systems on the Amazon Web Services (AWS) platform.
Amazon AWS-Solutions-Architect-Associate Latest Learning Material, Valid Test AWS-Solutions-Architect-Associate TestkingOur AWS-Solutions-Architect-Associate question torrent not only have reasonable price but also can support practice perfectly, as well as in the update to facilitate instant upgrade for the users in the first place, compared with other education platform on the market, the AWS-Solutions-Architect-Associate Exam Question can be said to have high quality performance. We can sure that you will never regret to download and learn our study material, and you will pass the exam at your first try.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q253-Q258):NEW QUESTION # 253
A data science team needs storage for nightly log processing. The size and number of logs is unknown, and the logs persist for only 24 hours.
What is the MOST cost-effective solution?
  • A. Amazon S3 One Zone-Infrequent Access (S3 One Zone-IA)
  • B. Amazon S3 Intelligent-Tiering
  • C. Amazon S3 Standard
  • D. Amazon S3 Glacier Deep Archive
Amazon S3 Intelligent-Tiering is designed for unknown or unpredictable access patterns, automatically moving objects to the most cost-effective tier without performance impact.
It is ideal when you do not know object size or access frequency.
S3 Standard (Option B) works but costs more.
S3 One Zone-IA and Glacier Deep Archive (Options D and A) are not appropriate because data is frequently accessed for processing and persists only 24 hours.
NEW QUESTION # 254
An ecommerce application places orders in an Amazon Simple Queue Service (Amazon SQS) queue When a message is received, the Amazon EC2 worker instances process the request The EC2 instances are in an Auto Scaling group 236 How should the architecture be designed to scale the auto scaling group with the LEAST amount of operational overhead?
  • A. Use an Amazon CloudWatch alarm based on the number of messages in the queue to scale the Auto Scaling group up or down
  • B. Use an Amazon CloudWatch alarm on the EC2 CPU to scale the Auto Scaling group up and down
  • C. Use an Amazon EC2 Auto Scaling health check for messages processed on the EC2 instances to scale up or down.
  • D. Use an Amazon CloudWatch alarm based on the CPU to scale the Auto Scaling group up or down
NEW QUESTION # 255
An application running on an Amazon EC2 instance needs to securely access tiles on an Amazon Elastic File System (Amazon I tile system. The EFS tiles are stored using encryption at rest. Which solution for accessing the tiles is MOST secure?
  • A. Store the encryption key in the code of the application
  • B. Enable TLS when mounting Amazon EFS
  • C. Store the encryption key in an Amazon S3 bucket and use IAM roles to grant the EC2 instance access permission
  • D. Enable AWS Key Management Service (AWS KMS) when mounting Amazon EFS
NEW QUESTION # 256
In regard to DynamoDB, for which one of the following parameters does Amazon not charge you?
  • A. Cost per provisioned read units
  • B. I/O usage within the same Region
  • C. Storage cost
  • D. Cost per provisioned write units
Explanation/Reference:
In DynamoDB, you will be charged for the storage and the throughput you use rather than for the I/O which has been used.
http://aws.amazon.com/dynamodb/pricing/
NEW QUESTION # 257
You have deployed a three-tier web application in a VPC with a CIDR block of 10.0.0.0/28. You initially deploy two web servers, two application servers, two database servers and one NAT instance tor a total of seven EC2 instances. The web, application and database servers are deployed across two availability zones (AZs). You also deploy an ELB in front of the two web servers, and use Route53 for DNS Web (raffle gradually increases in the first few days following the deployment, so you attempt to double the number of instances in each tier of the application to handle the new load unfortunately some of these new instances fail to launch.
Which of the following could be the root caused? (Choose two.)
  • A. AWS reserves the first four and the last IP address in each subnet's CIDR block so you do not have enough addresses left to launch all of the new EC2 instances
  • B. The Internet Gateway (IGW) of your VPC has scaled-up, adding more instances to handle the traffic spike, reducing the number of available private IP addresses for new instance launches
  • C. The ELB has scaled-up, adding more instances to handle the traffic spike, reducing the number of available private IP addresses for new instance launches
  • D. AWS reserves one IP address in each subnet's CIDR block for Route53 so you do not have enough addresses left to launch all of the new EC2 instances
  • E. AWS reserves the first and the last private IP address in each subnet's CIDR block so you do not have enough addresses left to launch all of the new EC2 instances
Explanation/Reference: http://docs.aws.amazon.com/Amazo ... de/VPC_Subnets.html
NEW QUESTION # 258
There is always a fear of losing the AWS-Solutions-Architect-Associate exam and this causes you may loss your money and waste the time. There is no such issue if you study our AWS-Solutions-Architect-Associate exam questions. Your money and exam attempt is bound to award you a sure and definite success if you study with our AWS-Solutions-Architect-Associate Study Guide to prapare for the exam. According to our data, our pass rate of the AWS-Solutions-Architect-Associate practice engine is high as 98% to 100%. So if you choose our AWS-Solutions-Architect-Associate learning quiz, you will pass for sure.
AWS-Solutions-Architect-Associate Latest Learning Material: https://www.exam-killer.com/AWS-Solutions-Architect-Associate-valid-questions.html
2026 Latest Exam-Killer AWS-Solutions-Architect-Associate PDF Dumps and AWS-Solutions-Architect-Associate Exam Engine Free Share: https://drive.google.com/open?id=1ooDsGbGhT_S8Fm_JZZevuWdH4XrZKBKy
Posted at 1/26/2026 13:20:50        Only Author  2#
Thank you for your impactful article, it really stayed with me. Enhance your IT expertise by downloading free 1Z0-1056-24 cost effective dumps. Wishing you all the best!
