[General] Sample FCP_FMG_AD-7.4 Exam & Certification FCP_FMG_AD-7.4 Sample Questions
94
【General】 Sample FCP_FMG_AD-7.4 Exam & Certification FCP_FMG_AD-7.4 Sample Questions
Posted at 1/13/2026 12:12:21      View:172 | Replies:5        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeDump FCP_FMG_AD-7.4 PDF Dumps and FCP_FMG_AD-7.4 Exam Engine Free Share: https://drive.google.com/open?id=1M44ReBLTVO9wzvpgeA1bFLX-r-8ah-e8
Just choose the right PracticeDump Fortinet FCP_FMG_AD-7.4 exam questions format demo and download it quickly. Download the Fortinet FCP_FMG_AD-7.4 exam questions demo now and check the top features of Fortinet FCP_FMG_AD-7.4 Exam Questions. If you think the Fortinet FCP_FMG_AD-7.4 exam dumps can work for you then take your buying decision. Best of luck in exams and career!!!
Fortinet FCP_FMG_AD-7.4 Exam Syllabus Topics:
  • Device Manager: In this domain, the focus is on how to register devices within ADOMs, implement configuration changes using scripts, and troubleshoot using the revision history.
  • Advanced Configuration: This domain explains FortiManager's high availability (HA), configures FortiGuard services and works with the global database ADOM.
  • Administration: This section covers how to understand FortiManager capabilities, perform initial configurations, and set up administrative domains (ADOMs).
  • Policy and Objects: This section deals with how to manage policies and objects, oversee ADOM revisions, configure workspace mode, and conduct policy imports and installations.
Topic 5
  • Troubleshooting: This section covers how to fmiliarize with FortiManager deployment scenarios and troubleshoot issues related to imports, installations, device-level, ADOM-level, and system-level concerns.
Certification Fortinet FCP_FMG_AD-7.4 Sample Questions | FCP_FMG_AD-7.4 Exam SyllabusAs indicator on your way to success, our FCP_FMG_AD-7.4 practice materials can navigate you through all difficulties in your journey. Every challenge cannot be dealt like walk-ins, but our FCP_FMG_AD-7.4 simulating practice can make your review effective. That is why our FCP_FMG_AD-7.4 study questions are professional model in the line. With high pass rate as more than 98%, our FCP_FMG_AD-7.4 exam questions have helped tens of millions of candidates passed their exam successfully.
Fortinet FCP - FortiManager 7.4 Administrator Sample Questions (Q31-Q36):NEW QUESTION # 31
What is a characteristic of the FortiManager high availability (HA) feature?
  • A. The primary unit synchronizes all configuration revision with the seconday units.
  • B. All secondary units must be in the same network as the primary unit.
  • C. Each cluster member must be upgraded manually, starting with the primary unit.
  • D. When a secondary unit is removed, FortiManager updates the managed devices using TCP port 5199.
NEW QUESTION # 32
You are using the Quick Install option to install configuration changes on the managed FortiGate.
Which two statements correctly describe the result? (Choose two.)
  • A. It installs provisioning template changes on the FortiGate device.
  • B. It installs device-level changes on the FortiGate device without launching the Install Wizard
  • C. It installs all the changes in the device database first and the administrator must reinstall the changes on the FortiGate device.
  • D. It provides the option to preview only the policy package changes before installing them.
* Option B: It provides the option to preview only the policy package changes before installing them.This is correct. The Quick Install option in FortiManager provides a preview of policy changes before they are applied, allowing administrators to review and confirm the changes.
* Option D: It installs device-level changes on the FortiGate device without launching the Install Wizard.This is correct. Quick Install allows for the immediate installation of device-level changes, such as interface or routing configurations, directly onto the FortiGate without going through the full Install Wizard.
Explanation of Incorrect Options:
* Option A: It installs provisioning template changes on the FortiGate deviceis incorrect because Quick Install does not specifically deal with provisioning templates.
* Option C: It installs all the changes in the device database first and the administrator must reinstall the changes on the FortiGate deviceis incorrect because Quick Install directly applies changes to the FortiGate device, not requiring a separate reinstall step.
FortiManager References:
* Refer to "FortiManager Administration Guide" for details on "Quick Install" functionality under
"Device Management."
NEW QUESTION # 33
An administrator runs the reload failure command diagnose test deploymanager reloadconf <deviceid> on FortiManager.
What does this command do?
  • A. It reloads the policy package from the FortiManager to FortiGate.
  • B. It downloads the latest configuration from the specified FortiGate and performs a reload operation on the device database.
  • C. It compares and provides differences in configuration on FortiManager with the current running configuration of the specified FortiGate.
  • D. It installs the latest configuration on the specified FortiGate and updates the revision history database.
This command is used to retrieve the current running configuration from the specified FortiGate device and updates the FortiManager's device database accordingly.
NEW QUESTION # 34
Which API method is used to create objects or overwrite existing ones?
  • A. Set
  • B. Add
  • C. Exec
  • D. Update
In the context of the FortiManager JSON API, thesetmethod is used tocreate new objectsoroverwrite existing ones. The API allows administrators to manage FortiManager and its associated devices by automating tasks like configuration changes, policy updates, and object creation.
Explanation of Options:
* A. Set:
* This istrue. Thesetmethod is used to create a new object if it does not exist or overwrite an existing object if it already exists. This method is frequently used in API requests to configure settings and apply changes on FortiManager.
* B. Add:
* This isfalse. Theaddmethod is used to add new objects without overwriting any existing ones. It is used when you want to create a new entry and ensure it doesn't conflict with or replace an existing object.
* C. Exec:
* This isfalse. Theexecmethod is used to execute specific actions or commands, rather than creating or modifying objects. This is typically used for actions like running scripts or executing operational commands on FortiManager or FortiGate.
* D. Update:
* This isfalse. While "update" might seem relevant, FortiManager's API does not specifically use an "update" method for modifying or creating objects. Thesetmethod serves that function by both creating new objects and overwriting existing ones.
NEW QUESTION # 35
Exhibit.
Which two statements about the output are true? (Choose two.)
  • A. The latest revision history for the managed FortiGate does match the FortiGate running configuration.
  • B. The latest revision history for the managed FortiGate does not match the device-level database.
  • C. Configuration changes have been installed on FortiGate, which means the FortiGate configuration has been changed.
  • D. Configuration changes directly made on FortiGate have been automatically updated to the device-level database.
NEW QUESTION # 36
There are a lot of experts and professors in or company in the field. In order to meet the demands of all people, these excellent experts and professors from our company have been working day and night. They tried their best to design the best FCP_FMG_AD-7.4 certification training dumps from our company for all people. By our study materials, all people can prepare for their FCP_FMG_AD-7.4 exam in the more efficient method. We can guarantee that our study materials will be suitable for all people and meet the demands of all people, including students, workers and housewives and so on. If you decide to buy and use the FCP_FMG_AD-7.4 Training Materials from our company with dedication on and enthusiasm step and step, it will be very easy for you to pass the exam without doubt. We sincerely hope that you can achieve your dream in the near future by the FCP_FMG_AD-7.4 latest questions of our company.
Certification FCP_FMG_AD-7.4 Sample Questions: https://www.practicedump.com/FCP_FMG_AD-7.4_actualtests.html
P.S. Free & New FCP_FMG_AD-7.4 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=1M44ReBLTVO9wzvpgeA1bFLX-r-8ah-e8
Posted at 1/16/2026 00:19:22        Only Author  2#
The content is so good, it’s an immediate like. The Valid exam cram D-ECS-DY-23 sheet file resources are excellent, and they’re available to you free of charge.
Posted at 1/17/2026 03:46:34        Only Author  3#
This article is so powerful, thank you for the inspiration! Ready to face the Exam CV0-004 pattern exam! Pray for good results!
Posted at 2/14/2026 09:55:03        Only Author  4#
想更快的通過C_ARCON_2508認證考試嗎?快速拿到該證書嗎?NewDumps考古題可以幫助您,幾乎包含了C_ARCON_2508考試所有知識點,由專業的認證專家團隊提供100%正確的答案。他們一直致力于為考生提供最好的學習資料,以確保您獲得的是最有價值的SAP C_ARCON_2508考古題。我們不斷的更新C_ARCON_2508考題資料,以保證其高通過率,是大家值得選擇的最新、最準確的SAP C_ARCON_2508學習資料產品。
Posted at 2/17/2026 02:23:47        Only Author  5#
I’m left in complete awe by your article, thank you for sharing it! Free Latest Plat-Arch-206 study plan exam papers to help you prepare. Best of luck to all!
Posted at 2/19/2026 06:16:14        Only Author  6#
That article was a goldmine of information. Don’t miss out on the Reliable N16291GC10 test collection free questions—free and essential for your promotion and salary increase!
