Reliable Professional-Cloud-DevOps-Engineer Exam Answers & Professional-Clou
92
Posted at 1/13/2026 12:21:51      View124 | Replies4        Print      Only Author   [Copy Link] 1#
2026 Latest FreeDumps Professional-Cloud-DevOps-Engineer PDF Dumps and Professional-Cloud-DevOps-Engineer Exam Engine Free Share: https://drive.google.com/open?id=1xSVzZR8op9d815K4VDPRleKE8yP2QMx1
With the consistent reform in education, our Professional-Cloud-DevOps-Engineer test question also change with the newest education regulation. We have strong confidence in offering the first-class Professional-Cloud-DevOps-Engineer study prep to our customers. So what you have learned is fully conforming to the latest test syllabus. Also, our specialists can predicate the Professional-Cloud-DevOps-Engineer exam precisely. Firstly, our company has summed up much experience after so many years accumulation. The model test is very important. You are advised to master all knowledge of the model test. Therefore, we sincerely wish you can attempt to our Professional-Cloud-DevOps-Engineer Test Question. Practice and diligence make perfect. Every one looks forward to becoming an excellent person. You will become the lucky guys after passing the Professional-Cloud-DevOps-Engineer exam.
The Google Professional Cloud DevOps Engineer certification is designed to equip the specialists with the expertise required to perform the following technical tasks: applying the principles of site reliability engineering to services, optimizing service performance, implementing the strategies for service monitoring, building and implementing CI/CD pipelines for services, as well as managing service incidents. To get the certificate, the candidates need to complete a single exam covering a wide range of knowledge and skills.
To earn the Google Professional-Cloud-DevOps-Engineer certification, you will need to pass a rigorous exam that covers a wide range of topics related to cloud computing, automation, and continuous delivery. Professional-Cloud-DevOps-Engineer exam consists of multiple-choice questions and is designed to evaluate your ability to design, implement, and manage cloud-based solutions using Google Cloud Platform. Professional-Cloud-DevOps-Engineer Exam also tests your understanding of various DevOps tools and methodologies, such as Docker, Kubernetes, Ansible, and Jenkins. By passing Professional-Cloud-DevOps-Engineer exam, you will demonstrate your proficiency in using Google Cloud Platform to build and deploy scalable and reliable applications and gain recognition as a certified professional in cloud DevOps engineering.
Google Professional-Cloud-DevOps-Engineer exam is a certification program designed to validate the skills and knowledge of professionals in the field of DevOps engineering on the Google Cloud Platform. Professional-Cloud-DevOps-Engineer exam is intended for individuals who are experienced in DevOps practices and have expertise in designing, building, and maintaining scalable and reliable cloud solutions.
Professional-Cloud-DevOps-Engineer Free Exam Dumps | Professional-Cloud-DevOps-Engineer Test Lab QuestionsConsidering your various purchasing behaviors, such as practice frequency. Occasion, different digital equivalents, average amount of time on our Professional-Cloud-DevOps-Engineer practice materials, we made three versions for your reference, and each has its indispensable favor respectively. All Professional-Cloud-DevOps-Engineer guide exam can cater to each type of exam candidates preferences. The three kinds are PDF & Software & APP version. Besides, we have always been exacting to our service standards to make your using experience better. We are exclusive in Professional-Cloud-DevOps-Engineer training prep area, so we professional in practice materials of the test.
Google Cloud Certified - Professional Cloud DevOps Engineer Exam Sample Questions (Q153-Q158):NEW QUESTION # 153
You are building an application that runs on Cloud Run The application needs to access a third-party API by using an API key You need to determine a secure way to store and use the API key in your application by following Google-recommended practices What should you do?
  • A. Encrypt the API key by using Cloud Key Management Service (Cloud KMS) and pass the key to Cloud Run as an environment variable Decrypt and use the key in Cloud Run
  • B. Save the API key in Secret Manager as a secret Reference the secret as an environment variable in the Cloud Run application
  • C. Save the API key in Secret Manager as a secret key Mount the secret key under the /sys/api_key directory and decrypt the key in the Cloud Run application
  • D. Save the API key in Cloud Key Management Service (Cloud KMS) as a key Reference the key as an environment variable in the Cloud Run application
The best option for storing and using the API key in your application by following Google-recommended practices is to save the API key in Secret Manager as a secret and reference the secret as an environment variable in the Cloud Run application. Secret Manager is a service that allows you to store and manage sensitive data, such as API keys, passwords, and certificates, in Google Cloud. A secret is a resource that represents a logical secret, such as an API key. You can save the API key in Secret Manager as a secret and use IAM policies to control who can access it. You can also reference the secret as an environment variable in the Cloud Run application by using the ${SECRET_NAME} syntax. This way, you can securely store and use the API key in your application without exposing it in your code or configuration files.
NEW QUESTION # 154
You manage several production systems that run on Compute Engine in the same Google Cloud Platform (GCP) project. Each system has its own set of dedicated Compute Engine instances. You want to know how must it costs to run each of the systems. What should you do?
  • A. Name each virtual machine (VM) after the system it runs. Set up a usage report export to a Cloud Storage bucket. Configure the bucket as a source in BigQuery to query costs based on VM name.
  • B. In the Google Cloud Platform Console, use the Cost Breakdown section to visualize the costs per system.
  • C. Assign all instances a label specific to the system they run. Configure BigQuery billing export and query costs per label.
  • D. Enrich all instances with metadata specific to the system they run. Configure Stackdriver Logging to export to BigQuery, and query costs based on the metadata.
NEW QUESTION # 155
You recently migrated an ecommerce application to Google Cloud. You now need to prepare the application for the upcoming peak traffic season. You want to follow Google-recommended practices. What should you do first to prepare for the busy season?
  • A. Migrate the application to Cloud Run, and use autoscaling.
  • B. Pre-provision the additional compute power that was used last season, and expect growth.
  • C. Create a Terraform configuration for the application's underlying infrastructure to quickly deploy to additional regions.
  • D. Load test the application to profile its performance for scaling.
The first thing you should do to prepare your ecommerce application for the upcoming peak traffic season is to load test the application to profile its performance for scaling. Load testing is a process of simulating high traffic or user demand on your application and measuring how it responds. Load testing can help you identify any bottlenecks, errors, or performance issues that might affect your application during the busy season1. Load testing can also help you determine the optimal scaling strategy for your application, such as horizontal scaling (adding more instances) or vertical scaling (adding more resources to each instance)2.
There are different tools and methods for load testing your ecommerce application on Google Cloud, depending on the type and complexity of your application. For example, you can use Cloud Load Balancing to distribute traffic across multiple instances of your application, and use Cloud Monitoring to measure the latency, throughput, and error rate of your application3. You can also use Cloud Functions or Cloud Run to create serverless load generators that can simulate user requests and send them to your application4. Alternatively, you can use third-party tools such as Apache JMeter or Locust to create and run load tests on your application.
By load testing your ecommerce application before the peak traffic season, you can ensure that your application is ready to handle the expected load and provide a good user experience. You can also use the results of your load tests to plan and implement other steps to prepare your application for the busy season, such as migrating to a more scalable platform, creating a Terraform configuration for deploying to additional regions, or pre-provisioning additional compute power.
1: Load Testing 101: How To Test Website Performance | BlazeMeter
2: Scaling applications | Google Cloud
3: Load testing using Google Cloud | Solutions | Google Cloud
4: Serverless load testing using Cloud Functions | Solutions | Google Cloud
NEW QUESTION # 156
You are the on-call Site Reliability Engineer for a microservice that is deployed to a Google Kubernetes Engine (GKE) Autopilot cluster. Your company runs an online store that publishes order messages to Pub/Sub and a microservice receives these messages and updates stock information in the warehousing system. A sales event caused an increase in orders, and the stock information is not being updated quickly enough. This is causing a large number of orders to be accepted for products that are out of stock You check the metrics for the microservice and compare them to typical levels.
You need to ensure that the warehouse system accurately reflects product inventory at the time orders are placed and minimize the impact on customers What should you do?
  • A. Increase the number of Pod replicas
  • B. Decrease the acknowledgment deadline on the subscription
  • C. Increase the Pod CPU and memory limits
  • D. Add a virtual queue to the online store that allows typical traffic levels
The best option for ensuring that the warehouse system accurately reflects product inventory at the time orders are placed and minimizing the impact on customers is to increase the number of Pod replicas.
Increasing the number of Pod replicas will increase the scalability and availability of your microservice, which will allow it to handle more Pub/Sub messages and update stock information faster. This way, you can reduce the backlog of undelivered messages and oldest unacknowledged message age, which are causing delays in updating product inventory. You can use Horizontal Pod Autoscaler or Cloud Monitoring metrics- based autoscaling to automatically adjust the number of Pod replicas based on load or custom metrics.
NEW QUESTION # 157
You deploy a new release of an internal application during a weekend maintenance window when there is minimal user traffic. After the window ends, you learn that one of the new features isn't working as expected in the production environment. After an extended outage, you roll back the new release and deploy a fix. You want to modify your release process to reduce the mean time to recovery so you can avoid extended outages in the future. What should you do?
Choose 2 answers
  • A. Integrate a code linting tool to validate coding standards before any code is accepted into the repository.
  • B. Configure a CI server. Add a suite of unit tests to your code and have your CI server run them on commit and verify any changes.
  • C. Require developers to run automated integration tests on their local development environments before release.
  • D. Before merging new code, require 2 different peers to review the code changes.
  • E. Adopt the blue/green deployment strategy when releasing new code via a CD server.
Answer: B,E
NEW QUESTION # 158
Our company in the field of the Professional-Cloud-DevOps-Engineer exam bootcamp for years, we also enjoy high reputation in the business. You choose us, we will give you the best we have, and your right choice will also bring the benefits to you. With the high reputation in the field, we can guarantee the quality of the Professional-Cloud-DevOps-Engineer Exam Dumps. It also contains the free update for one year for you. It can save your money for updating, and the update version will send to your mailbox automatically.
Professional-Cloud-DevOps-Engineer Free Exam Dumps: https://www.freedumps.top/Professional-Cloud-DevOps-Engineer-real-exam.html
BTW, DOWNLOAD part of FreeDumps Professional-Cloud-DevOps-Engineer dumps from Cloud Storage: https://drive.google.com/open?id=1xSVzZR8op9d815K4VDPRleKE8yP2QMx1
Posted at 1/14/2026 08:55:08        Only Author  2#
Your article has left me speechless, thank you for sharing it! 1Y0-204 exam sample questions played a major role in my promotion and salary increaseget it for free today!
Posted at 1/20/2026 02:08:16        Only Author  3#
I'm deeply moved by this article, thank you for sharing it! The Visual CRISC cert exam resources are outstanding, and they come with no cost.
Posted at 2/7/2026 12:01:53        Only Author  4#
This article has provided me with many valuable insights. The GH-300 pdf files questions are the key to successget them for free and unlock your promotion!
Posted at 2/16/2026 12:22:03        Only Author  5#
Reading this article, I have gained a completely new understanding of the issue. With the help of the Latest exam camp C_ARSUM_2508 file, I achieved a promotion and pay raise. Now its free for everyone. Wishing you all success!
