New Topic
[Linux] English version of Debian 11 needed
19
Linux English version of Debian 11 needed
Posted at 8/9/2022 10:36:37      View21923 | Replies34        Print      Only Author   [Copy Link] 1#
Hi guys, I need a version of Debian for the ROC-RK3588S-PC that boots up into English. I've found some here that boot into Chinese.  Does anyone know where I can get an English language version? Any help would be greatly appreciated.  https://en.t-firefly.com/doc/download/142.html
FYI - I received my board yesterday. Thank you!  It is beautiful. Smart design.
Posted at 8/9/2022 11:41:40        Only Author  2#
Changing Debian from Chinese to English
Solution found
1) boot up in Chinese
2) open a command prompt (icon looks like a black dos window)
3) enter in the following set of commands:
3.1) sudo su
3.2) dpkg -reconfigure locales
4) a new window should pop up, scroll down to en_US.UTF-8 and select it (space bar, or enter key)
5) tab over to the bottom left most button and click it.
6) select en_US.UTF-8 from the list that pops up.
7) type reboot into the command window.
Your system will reboot and come up in English.
Posted at 8/12/2022 14:54:54        Only Author  3#
There is better solution. In mk-rootfs-buulseye.sh turn each occurence cn_zh (or something like this) to en_US and you can comment each string with Chinese locale settings. Moreover if you have not working DNS, you can add to chroot block string:
echo "nameserver 8.8.8.8" | sudo tee /etc/resolv.conf > /dev/null
Posted at 1/13/2025 14:56:42        Only Author  4#
If the Debian image you have downloaded Football Bros Unblocked boots into Chinese, it might still include English as a language option. During the initial boot or setup process, look for a language selector.
Posted at 2/10/2025 17:34:00        Only Author  5#
The devices are really interesting improvements to more effectively access application performance. Access to suitable work sources. Learn and cultivate new knowledge. Challenging practice Geometry Dash Lite helps players achieve the best skill performance.
Posted at 2/12/2025 21:14:20        Only Author  6#
Football bros unblocked ignite pure excitement, where every pass and goal brings fans to their feet. The energy is electric, and the drama unfolds in every moment.
Posted at 2/26/2025 17:57:32        Only Author  7#
Play Chill Guy Clicker in Drive Mad, a special game that combines a real racing engine with Curve Rush
Posted at 3/11/2025 15:16:58        Only Author  8#
Great site! I really love the amazing way it is simple on my eyes it is. I am considering how I may be told at whatever point another post has been made. I have bought in to your RSS which may work? antminer s19
Posted at 3/11/2025 16:13:00        Only Author  9#
Your post arrived at exactly the right moment! I cant thank you enough for simplifying such a complicated topic. Ive read so many articles before, but most of them were either too technical or hard to understand. Your post was different?it made everything so clear and accessible. I really appreciate how you make learning enjoyable and easy to follow. Thank you for sharing such helpful content. Ill definitely be coming back for more!
먹튀폴리스
Posted at 3/11/2025 16:31:09        Only Author  10#
Thanks for taking the time to discuss this, I feel strongly about it and love learning more on this topic. If possible, as you gain expertise, would you mind updating your blog with extra information? It is extremely helpful for me.
View data
Return to List
1234
