100% Pass Quiz Microsoft - SC-401 - Administering Information Security in Micros
53
Posted at 1/13/2026 12:39:10      View174 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft SC-401 dumps are available on Google Drive shared by TroytecDumps: https://drive.google.com/open?id=1HyPPrqqQ2VZbiqJ3gxiVHd8rvoVoxudM
We also offer a free demo version that gives you a golden opportunity to evaluate the reliability of the Administering Information Security in Microsoft 365 (SC-401) exam study material before purchasing. Vigorous practice is the only way to ace the Administering Information Security in Microsoft 365 (SC-401) test on the first try. And that is what TroytecDumps Microsoft SC-401 practice material does. Each format of updated Microsoft SC-401 preparation material excels in its way and helps you pass the Administering Information Security in Microsoft 365 (SC-401) examination on the first attempt.
Microsoft SC-401 Exam Syllabus Topics:
  • Implement Information Protection: This section measures the skills of Information Security Analysts in classifying and protecting data. It covers identifying and managing sensitive information, creating and applying sensitivity labels, and implementing protection for Windows, file shares, and Exchange. Candidates must also configure document fingerprinting, trainable classifiers, and encryption strategies using Microsoft Purview.
  • Implement Data Loss Prevention and Retention: This section evaluates Data Protection Officers on designing and managing data loss prevention (DLP) policies and retention strategies. It includes setting policies for data security, configuring Endpoint DLP, and managing retention labels and policies. Candidates must understand adaptive scopes, policy precedence, and data recovery within Microsoft 365.
  • Manage Risks, Alerts, and Activities: This section assesses Security Operations Analysts on insider risk management, monitoring alerts, and investigating security activities. It covers configuring risk policies, handling forensic evidence, and responding to alerts using Microsoft Purview and Defender tools. Candidates must also analyze audit logs and manage security workflows.
  • Protect Data Used by AI Services: This section evaluates AI Governance Specialists on securing data in AI-driven environments. It includes implementing controls for Microsoft Purview, configuring Data Security Posture Management (DSPM) for AI, and monitoring AI-related security risks to ensure compliance and protection.
Helpful Features of SC-401 PDF QuestionsThe (SC-401 exam offered by Microsoft is regarded as one of the most promising certification exams in the field of. The SC-401 preparation products available here are provided in line with latest changes and updates in SC-401 syllabus. The Microsoft SC-401 undergo several changes which are regularly accommodated to keep our customers well-informed. We have the complete list of Popular SC-401 Exams. Now you can simply choose your SC-401 exam from the list and be directed right to its page where you can find links to download SC-401 exams.
Microsoft Administering Information Security in Microsoft 365 Sample Questions (Q194-Q199):NEW QUESTION # 194
HOTSPOT
You have a Microsoft 365 subscription.
You plan to deploy an audit log retention policy.
You need to perform a search to validate whether the policy will be applied to the intended entries.
Which two fields should you configure for the search? To answer, select the appropriate fields in the answer area.
To validate whether an audit log retention policy will apply to the intended entries, you should configure the following fields:
# Date and time range (UTC) ensures that you are searching for audit logs within the time period when the policy should be applied. Audit logs are time-sensitive, and policies affect logs based on their timestamp.
# Record types allows you to filter and search for specific audit log categories (e.g., Exchange, SharePoint, Teams, etc.) that are affected by the retention policy. Selecting the correct record type ensures that the policy is evaluated against the relevant data.
NEW QUESTION # 195
You have a data loss prevention (DLP) policy configured for endpoints as shown in the following exhibit.
From a computer named Computer1, a user can sometimes upload files to cloud services and sometimes cannot. Other users experience the same issue.
What are two possible causes of the issue? Each correct answer presents a complete solution.
  • A. The computers are NOT onboarded to Microsoft Purview.
  • B. There are file path exclusions in the Microsoft 365 Endpoint data loss prevention (Endpoint DLP) settings.
  • C. The unallowed browsers in the Microsoft 365 Endpoint data loss prevention (Endpoint DLP) settings are NOT configured.
  • D. The Copy to clipboard action is set to Audit only.
  • E. The Access by restricted apps action is set to Audit only.
The issue where users sometimes can upload files to cloud services and sometimes cannot suggests inconsistent enforcement of Endpoint DLP policies. This can be caused by the unallowed browsers in the Microsoft 365 Endpoint DLP settings are NOT configured. Also, there are file path exclusions in the Microsoft 365 Endpoint DLP settings.
Endpoint DLP can block uploads only when using unallowed browsers. If unallowed browsers are not configured, users might be able to bypass restrictions by switching to a different browser. This could explain why uploads sometimes work and sometimes don't, depending on which browser is used.
File path exclusions allow certain files or folders to be exempt from DLP restrictions. If a specific file location is excluded, files stored there won't trigger DLP policies, leading to inconsistent behavior. This could result in some uploads being blocked while others are allowed.
NEW QUESTION # 196
You have two Microsoft 365 subscriptions named Contoso and Fabrikam. The subscriptions contain the users shown in the following table.
You have a sensitivity label named Sensitivity! as shown in the exhibit. (Click the Exhibit tab) you have the files shown in the following table.
For each of the following statements, select yes if the statement is true. Otherwise select No.
Yes , Yes, No
To determine whether each statement is true or false, let's analyze the provided information step by step based on the sensitivity label settings and the user permissions associated with the files.
Given Information:
Users and Subscriptions:
User1: Contoso subscription, email: user1@contoso.com
User2: Contoso subscription, email: user2@contoso.com
User3: Fabrikam subscription, email: user3@fabrikam.com
User4: Fabrikam subscription, email: user4@fabrikam.com
Files and Sensitivity Label Application:
File1: Automatically applied Sensitivity1 using an auto-labeling policy File2: Applied by User2 File3: Applied by User1 Sensitivity Label (Sensitivity1) Assumptions: Since the exhibit for the sensitivity label is not fully detailed, we need to make reasonable assumptions based on typical Microsoft 365 sensitivity label behavior.
Sensitivity labels can restrict access based on user permissions, subscription boundaries, or specific configurations (e.g., allowing only users within the same organization to edit or view). Given the context of two separate subscriptions (Contoso and Fabrikam), it's likely that Sensitivity1 restricts access to users within the same subscription unless explicitly configured otherwise. A common default for such labels is to allow editing and other rights only to users within the applying user's organization, with possible restrictions for cross-subscription access.
Key Assumptions:
Sensitivity1 likely encrypts the files and restricts editing rights to users within the same subscription as the user who applied the label or where the auto-labeling policy is configured.
File1 (auto-applied) would inherit permissions based on the policy, likely restricting access to Contoso users if the policy is set up within the Contoso subscription.
File2 (applied by User2 from Contoso) would restrict access to Contoso users.
File3 (applied by User1 from Contoso) would also restrict access to Contoso users.
Users from Fabrikam (User3, User4) would not have edit rights unless explicitly granted, which is unlikely given the separation of subscriptions.
Statement Analysis:
User1 can edit rights for File1.
File1 was automatically applied with Sensitivity1 using an auto-labeling policy. Since the policy is likely configured within the Contoso subscription (where User1 resides), User1, as a Contoso user, should have edit rights unless the policy explicitly restricts this. Given User1's affiliation with Contoso, this is typically allowed.
The  answer: Yes
User2 can edit rights for File3.
File3 was applied by User1, who is from the Contoso subscription. Since User2 is also from the Contoso subscription, they should have edit rights unless the label configuration explicitly denies this for other users within the same subscription. Typically, users within the same organization can edit files labeled by another user from the same organization.
The  answer: Yes
User3 can print File2.
File2 was applied by User2, who is from the Contoso subscription. Sensitivity1 likely restricts access to Contoso users only. User3 is from the Fabrikam subscription, which is a separate entity. Unless cross-sub Answer : No
NEW QUESTION # 197
Hotspot Question
You have a Microsoft 365 E5 subscription.
You plan to implement Microsoft Purview insider risk management.
You need to recommend policy templates that meet the following requirements:
- Contain risk indicators and scoring for when a user receives a poor
performance review.
- Contain risk indicators and scoring for when a user disables security features on a device.
Which template should you use for each requirement? To answer, select the appropriate options in the answer area, NOTE: Each correct selection is worth one point.
Box 1: Security policy violations by risky users
Contain risk indicators and scoring for when a user receives a poor performance review.
Users that experience employment stressors might be at a higher risk for inadvertent or malicious security policy violations. These stressors could include a user being placed on a performance improvement plan, having a poor performance review, or experiencing a demotion. This policy template starts risk scoring based on these indicators and activities associated with these types of events.
Box 2: Security policy violations
In many organizations, users have permission to install software on their devices or to modify device settings to help with their tasks. Either inadvertently or with malicious intent, users might install malware or *disable important security features* that help protect information on their device or on your network resources. This policy template uses security alerts from Microsoft Defender for Endpoint to start scoring these activities and focus detection and alerts to this risk area. Use this template to provide insights for security policy violations in scenarios when users might have a history of security policy violations that might be an indicator of insider risk.
https://learn.microsoft.com/en-u ... nt-policy-templates
NEW QUESTION # 198
You create a sensitivity label named Label1 and publish Label1 to all users and groups.
You have the following files in a SharePoint site:
* File1.doc
* File2.docx
* File3.xlsx
* File4.txt
You need to identify which files can have Label1 applied.
Which files should you identify?
  • A. File2.docx only
  • B. File2.docx and File3.xlsx only
  • C. File1.doc File2-docx, and File3.xlsx only
  • D. File1.doc File2-docx, File3.xlsx, and File4.txt
Sensitivity labels can be applied to modern Office file types that support protection:
Supported: .docx, .xlsx, .pptx, etc.
Not supported: Legacy formats like .doc or non-Office formats like .txt.
Therefore, only File2.docx and File3.xlsx can have Label1 applied.
Reference: File types supported for sensitivity labels
NEW QUESTION # 199
To succeed on the Microsoft SC-401 exam, you require a specific Microsoft SC-401 exam environment to practice. But before settling on any one method, you make sure that it addresses their specific concerns about the SC-401 exam, such as whether or not the platform they are joining will aid them in passing theAdministering Information Security in Microsoft 365 (SC-401) exam on the first try, whether or not it will be worthwhile, and will it provide the necessary SC-401 Questions.
Valid SC-401 Test Labs: https://www.troytecdumps.com/SC-401-troytec-exam-dumps.html
