New Topic
[Linux] Debian 11 SATA is not working
152
Linux Debian 11 SATA is not working
Posted at 8/10/2022 16:35:07      View7555 | Replies10        Print      Only Author   [Copy Link] 1#
In u-boot everything is working great - scsi scan shows my disk and I can work with it. After I booting in debian 11 - I can't see my sata disks. After I rebooting to U-BOOT - there is no sata disks here to - scsi scan says nothing. Then I can reflash my uboot to sdcard and scsi can see my sata after this until the moment I boot into debian 11. After booting the Debian - system can't see my sata disks until the next u-boot reflashing...
What can it be? Device Tree is correct due to:
https://wiki.t-firefly.com/en/Core-3588J/usage_sata.html
Moreover - everything is correct due to this...
Posted at 8/10/2022 19:04:59        Only Author  2#
I discovered, that there is the same problem with USB. Moreover - when you plugging USB - kernel sees it but there is no new devices in /dev/ .
There is the same with sata - I see, that system acknowledged it, but there is no such device appeared in /dev
Posted at 8/11/2022 09:47:42        Only Author  3#
Sorry, I don't quite understand what you mean (uboot -> ubuntu?)
Posted at 8/11/2022 09:48:48        Only Author  4#
Please tell us the version number of the firmware and try the latest firmware v1.0.1a
Posted at 8/11/2022 21:47:57        Only Author  5#
SDK 1.0.1 not compiling:
********boot_merger ver 1.2********
Infoack loader ok.
pack loader okay! Input: /home/firefly/rockchip/rk3588/check/rkbin/RKBOOT/RK3588MINIALL.ini
/home/firefly/rockchip/rk3588/check/u-boot
ERROR: pack uboot.img failed! fit/uboot.itb actual: 2107392 bytes, max limit: 2097152 bytes
ERROR: Running build_uboot failed!
ERROR: exit code 1 from line 631:
    ./make.sh $UBOOT_COMPILE_COMMANDS CROSS_COMPILE=$CROSS_COMPILE
My commands:
./build.sh itx-3588j-debian.mk
./build.sh debian
./build.sh
Posted at 8/12/2022 15:55:49        Only Author  6#
I found the problem - the debian you are compiling with provided SDK had been configured incorrectly. There is such options you configured:
CONFIG_ATA=m
CONFIG_SATA_AHCI=m
CONFIG_SATA_AHCI_PLATFORM=m
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_RTKBTUSB=m
CONFIG_IP_VS=m
CONFIG_VXLAN=m
CONFIG_BLK_DEV_SD=m
CONFIG_BLK_DEV_SR=m
CONFIG_SCSI=m
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_USB_STORAGE=m
CONFIG_USB_UAS=m
You compiled modules, but lib module on running debian is empty. You should explain in your guide (on wiki) or automate inserting compiled modules to debian compiled rootfs.
Posted at 8/12/2022 16:00:22        Only Author  7#
I found modules in boot partition but they are not installing when you are booting to the system
Posted at 8/16/2022 15:10:30        Only Author  8#
Even you SDK 1.0.1b is not building yet:
Infoack loader ok.
ERROR: exit code 1 from line 630:
Posted at 1/11/2026 08:40:59        Only Author  9#
Your article is outstanding, thank you for sharing! Thanks to the Premium JN0-253 exam, I got promoted and received a salary boost. Its free now. Wishing you all a successful career advancement!
Posted at 2/12/2026 17:06:39        Only Author  10#
This article is a masterpiece in its own right, thank you for sharing. I advanced with the L5M6 accurate answers, earning both a promotion and salary increase. Now, its free for everyone. Best wishes to all!
Return to List
12
