Useful VCE AZ-305 Exam Simulator for Real Exam
Posted at 1/13/2026 13:26:51
BONUS!!! Download part of Exam4Tests AZ-305 dumps for free: https://drive.google.com/open?id=1rhL7vABPDkNx9WjDSV9jNAvCM23x3OOy
Getting tired of humdrum life, you may want to get some successful feeling or try something different instead. We all know that is of important to pass the AZ-305 exam and get the AZ-305 certification for someone who wants to find a good job in internet area, and it is not a simple thing to prepare for exam. So you are in the right place now. The AZ-305 practice materials are a great beginning to prepare your exam. Actually, just think of our AZ-305 practice materials as the best way to pass the exam is myopic. They can not only achieve this, but ingeniously help you remember more content at the same time.
The AZ-305 certification exam is designed to measure the candidate's skills in different areas of Azure infrastructure solutions design. These areas include designing compute solutions, designing storage solutions, designing networking solutions, designing security solutions, and designing monitoring solutions. AZ-305 Exam is intended to test the candidate's ability to design solutions that meet specific business requirements, technical constraints, and compliance needs.
Latest AZ-305 free braindumps & Microsoft AZ-305 valid exam - AZ-305 valid braindumpsIT certification exam cost is really large cost for most candidates in the whole world. Passing exam at first attempt will be everyone's goal. Now our Microsoft AZ-305 valid exam cram review can help you achieve your goal. Recent years we are engaging in providing 100% pass-rate AZ-305 Valid Exam Cram review for buyers from all over the world, and help thousands of candidates go through exam every year. If you have doubt in your test, let us help you pass exam for sure.
Microsoft Designing Microsoft Azure Infrastructure Solutions Sample Questions (Q155-Q160):NEW QUESTION # 155
You have an Azure Active Directory (Azure AD) tenant named contoso.com that has a security group named Group'. Group i is configured Tor assigned membership. Group I has 50 members. including 20 guest users.
You need To recommend a solution for evaluating the member ship of Group1. The solution must meet the following requirements:
* The evaluation must be repeated automatically every three months
* Every member must be able to report whether they need to be in Group1
* Users who report that they do not need to be in Group 1 must be removed from Group1 automatically
* Users who do not report whether they need to be m Group1 must be removed from Group1 automatically.
What should you include in me recommendation?
- A. implement Azure AU Identity Protection.
- B. Implement Azure AD Privileged Identity Management.
- C. Create an access review.
- D. Change the Membership type of Group1 to Dynamic User.
https://docs.microsoft.com/en-us ... bout-access-reviews Have reviews recur periodically: You can set up recurring access reviews of users at set frequencies such as weekly, monthly, quarterly or annually, and the reviewers will be notified at the start of each review. Reviewers can approve or deny access with a friendly interface and with the help of smart recommendations.
An administrator creates an access review of Group C with 50 member users and 25 guest users. Makes it a self-review. 50 licenses for each user as self-reviewers.* https://docs.microsoft.com/en-us ... e-license-scenarios There are 4 requirements and every single one is only met by access reviews. https://docs.microsoft.com/en-us ... -use-access-reviews Dynamic User is needed if a user must be automatically granted access on base of its attributes (department, jobtitle, location, etc.) https://techcommunity.microsoft. ... ft-365/ba-p/2267494 Implementing Azure AD PIM is no solution and absolutely not necessary for access reviews. https://docs.microsoft.com/en-us ... -you-create-reviews
NEW QUESTION # 156
You have an on-premises Microsoft SQL Server database named SQL1.
You plan to migrate SQL 1 to Azure.
You need to recommend a hosting solution for SQL1. The solution must meet the following requirements:
* Support the deployment of multiple secondary, read-only replicas.
* Support automatic replication between primary and secondary replicas.
* Support failover between primary and secondary replicas within a 15-minute recovery time objective (RTO).
NEW QUESTION # 157
You have 100 Microsoft SQL Server integration Services (SSIS) packages that are configured to use 10 on-premises SQL Server databases as their destinations.
You plan to migrate the 10 on-premises databases to Azure SQL Database
You need to recommend a solution to host the SSlS packages in Azure. The solution must ensure that the packages can target the SQL Database instances as their destinations.
What should you include in the recommendation?
- A. Azure Data Catalog
- B. Azure Data Factory
- C. SQL Server Migration Assistant (SSMA)
- D. Data Migration Assistant
https://docs.microsoft.com/bs-cy ... ed-instance-migrate Quote from that page "Azure SQL Database and SQL Server databases in an Azure Virtual Machine. DMS is the recommended method of migration for your enterprise workloads.
If you use SQL Server Integration Services (SSIS) on your SQL Server on premises, DMS does not yet support migrating SSIS catalog (SSISDB) that stores SSIS packages, but you can provision Azure-SSIS Integration Runtime (IR) in Azure Data Factory (ADF) that will create a new SSISDB in a managed instance and then you can redeploy your packages to it, see Create Azure-SSIS IR in ADF.
To learn more about this scenario and configuration steps for DMS, see Migrate your on-premises database to managed instance using DMS."
https://docs.microsoft.com/en-us ... grate-ssis-job-ssms
NEW QUESTION # 158
You have the Azure resources shown in the following table.
You need to design a solution that provides on-premises network connectivity to SQLDB1 through PE1. How should you configure name resolution? To answer, select the appropriate options in the answer area.
NEW QUESTION # 159
Your company identifies the following business continuity and disaster recovery objectives for virtual machines that host sales, finance, and reporting application in the company's on-premises data center.
*The finance application requires that data be retained for seven years. In the event of a disaster, the application must be able to run from Azure. The recovery in objective (RTO) is 10 minutes,
* The reporting application must be able to recover point in-time data al a daily granularity. The RTO is eight hours.
*The sales application must be able to fail over to second on-premises data center.
You need to recommend which Azure services meet the business community and disaster recovery objectives.
The solution must minimize costs.
What should you recommend for each application? To answer, drag the appropriate services to the correct application. Each service may be used owe. More than once not at an You may need to drag the spin bar between panes or scroll 10 view content.
1) Sales: Azure Site Recovery only
2) Finance: Azure Site Recovery and Azure Backup
3) Reporting: Azure Backup only
NEW QUESTION # 160
The Microsoft market has become so competitive and tough with time. To satisfy this task the professionals have to analyze new in-name for skills and improve their expertise. With the Microsoft AZ-305 certification exam they could do that activity fast and well. Your examination training with Microsoft Certification Questions is our top priority at Exam4Tests. To do this they just join up in Designing Microsoft Azure Infrastructure Solutions (AZ-305) certification exam and show a few firm dedication and self-discipline and prepare well to crack the AZ-305 examination.
AZ-305 Valid Dumps Free: https://www.exam4tests.com/AZ-305-valid-braindumps.html
- Free AZ-305 pdf torrent - Microsoft AZ-305 exam answers - AZ-305 vce dumps 🍃 Go to website ▷ [url]www.examdiscuss.com ◁ open and search for ➡ AZ-305 ️⬅️ to download for free 🗜Answers AZ-305 Real Questions[/url]
- Free PDF Quiz 2026 Microsoft AZ-305 – Trustable VCE Exam Simulator 🥨 Enter ✔ [url]www.pdfvce.com ️✔️ and search for ➠ AZ-305 🠰 to download for free 🚚Latest AZ-305 Dumps Questions[/url]
- AZ-305 New Study Plan ➕ Instant AZ-305 Discount ⬆ AZ-305 Examcollection Dumps Torrent 🦥 Search for ⮆ AZ-305 ⮄ and obtain a free download on ▛ [url]www.examcollectionpass.com ▟ 👎Valid AZ-305 Exam Duration[/url]
- Free PDF Quiz 2026 Microsoft AZ-305 – Trustable VCE Exam Simulator 🏸 Copy URL 《 [url]www.pdfvce.com 》 open and search for 《 AZ-305 》 to download for free 🙀Reliable AZ-305 Test Online[/url]
- Test AZ-305 Cram 🤹 AZ-305 Reliable Exam Pattern 🕸 Latest AZ-305 Exam Question 🥑 Search for ( AZ-305 ) on ➥ [url]www.validtorrent.com 🡄 immediately to obtain a free download 👫AZ-305 Latest Dump[/url]
- Free PDF Quiz 2026 Microsoft AZ-305 – Trustable VCE Exam Simulator 🐺 Download ▶ AZ-305 ◀ for free by simply searching on 《 [url]www.pdfvce.com 》 🅰AZ-305 New Braindumps Book[/url]
- Pass Guaranteed High-quality Microsoft - VCE AZ-305 Exam Simulator 🏴 Open 【 [url]www.prepawayete.com 】 enter ⮆ AZ-305 ⮄ and obtain a free download 🧔Instant AZ-305 Discount[/url]
- Pass Guaranteed 2026 The Best AZ-305: VCE Designing Microsoft Azure Infrastructure Solutions Exam Simulator ➡ Search for ⇛ AZ-305 ⇚ and obtain a free download on ➠ [url]www.pdfvce.com 🠰 🐗AZ-305 Latest Dump[/url]
- Latest AZ-305 Exam Question 🏧 Test AZ-305 Cram 🎎 AZ-305 Exam Objectives 👝 Search for [ AZ-305 ] on 「 [url]www.prepawayete.com 」 immediately to obtain a free download 🚘AZ-305 Reliable Exam Pattern[/url]
- Your Partner in AZ-305 Exam Preparation with Free Demos and Updates 🧖 Search for ▶ AZ-305 ◀ and easily obtain a free download on ▶ [url]www.pdfvce.com ◀ 🧩Frequent AZ-305 Updates[/url]
- Free PDF Quiz 2026 Microsoft AZ-305 – Trustable VCE Exam Simulator 🗽 Easily obtain ▷ AZ-305 ◁ for free download through ▛ [url]www.vceengine.com ▟ 🌰Reliable AZ-305 Test Online[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, hadeeleduc.com, cou.alnoor.edu.iq, www.skudci.com, Disposable vapes
