[General] Valid Salesforce-Certified-Administrator Test Online - Salesforce-Certified-Admi
90
【General】 Valid Salesforce-Certified-Administrator Test Online - Salesforce-Certified-Admi
Posted at 1/13/2026 15:04:36      View:184 | Replies:4        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TorrentVCE Salesforce-Certified-Administrator dumps from Cloud Storage: https://drive.google.com/open?id=1eKF-FR3EW2Df3agPi0jN6N3X4UDXdlqh
Remember that this is a crucial part of your career, and you must keep pace with the changing time to achieve something substantial in terms of a certification or a degree. So do avail yourself of this chance to get help from our exceptional Salesforce Certified Administrator (Salesforce-Certified-Administrator) dumps to grab the most competitive Salesforce Certified Administrator (Salesforce-Certified-Administrator) certificate.
Salesforce Certified Administrator is an important certification that is recognized globally. Salesforce Certified Administrator certification is designed to help professionals gain skills and knowledge in managing and administering Salesforce. The Salesforce Certified Administrator exam is an online proctored exam that consists of 60 multiple-choice questions. Candidates are given 90 minutes to complete the exam.
Salesforce Salesforce-Certified-Administrator Reliable Real Test - Mock Salesforce-Certified-Administrator ExamThese Salesforce-Certified-Administrator mock tests are made for customers to note their mistakes and avoid them in the next try to pass Salesforce Certified Administrator (Salesforce-Certified-Administrator) exam in a single try. These Salesforce Salesforce-Certified-Administrator mock tests will give you real Salesforce-Certified-Administrator exam experience. This feature will boost your confidence when taking the Salesforce Salesforce-Certified-Administrator Certification Exam. The 24/7 support system has been made for you so you don't feel difficulty while using the product. In addition, we offer free demos and up to 1 year of free Salesforce Dumps updates. Buy It Now!
Salesforce Certified Administrator Sample Questions (Q55-Q60):NEW QUESTION # 55
Universal Containers (UC) has a queue that is used for managing tasks that need to be worked by the UC customer support team. The same team will now be working some of UC's Cases.
Which two options should the administrator use tohelp the support team?
Choose 2 answers
  • A. Configure a flow to assign the cases to the queue.
  • B. Add Cass to the existing queue as available object.
  • C. Createa new queue and add Cases asan available object.
  • D. Use assignment rules to set the queue as the owner of the case.
Assignment rules and queue configuration are two options that should be used to help the support team work on some of UC's cases. Assignment rules can be used to automatically assign cases to a queue based on certaincriteria, such as case origin or priority. Queue configuration can be used to add Case as an available object to the existing queue and specify which users or groups can access the queue. References:
https://help.salesforce.com/s/ar ... ules.htm&type=5https://help.salesforce.com/s
NEW QUESTION # 56
At universal Containers, users would like to be able to share Salesforce records with other members of their team, while collaborating around general topics as well.
Which are two considerations for enabling this functionality?
Choose 2 answers
  • A. Object layouts should be configured to include the groups related list.
  • B. An administrator needs to create a group to enable record sharing
  • C. The Add Record action must be configured in the group publisher.
  • D. Collaboration groups are created automatically for every department.
NEW QUESTION # 57
AW Computing would like to improve its Case Lightning record page by including:
* A filtered component to display a message in bold font when a case issaved as acriticalrecord type.
* A quick way to update the account status from the case layout.
Which two components should an administrator use to satisfy these requests?
Choose 2 Answers
  • A. Related List
  • B. Record details
  • C. Related Record
  • D. Rich text
A related record component is a type of component that allows users to view and edit fields from a parent record on a child record page without leaving the page. For example, a related record component can allow users to update the account status from the case layout by selecting an account record from a drop-down list. A rich text component is a type of component that allows users to display formatted text on a record page using rich text editor tools such as bold font, bullet points, images, and links. For example, a rich text component can display a message in bold font when a case is saved as acriticalrecord type by using conditional visibility rules.
https://help.salesforce.com/s/ar ... amp;type=5https://h
NEW QUESTION # 58
Northern Trail Outfitters has requested that when the Referral Date field is updated on the custom object Referral Source, the parent object Referral also needs to be updated.
Which automation solution should an administrator use to meet this request?
  • A. Process Builder
  • B. Approval Process
  • C. Workflow Field Update
  • D. Lightning Web Component
NEW QUESTION # 59
Ursa Solar Major is evaluating Salesforce for its service team and would like to know what objects were available out of the box.
Which three of the standard objects are available to an administrator considering a support use case?
Choose 3 answers
  • A. Request
  • B. Ticket
  • C. Case
  • D. Account
  • E. Contract
Answer: C,D,E
Contract is a standard object that represents a contractual agreement between your company and a customer.
Case is astandard object that represents a customer's question or problem that needs to be resolved by your support team. Account is a standard object that represents an individual or an organization involved in your business, such as customers, competitors, partners, etc. These three objects are commonly used for service use cases in Salesforce. References: https://help.salesforce.com/s/ar ... elds.htm&type=5
https://help.salesforce.com/s/ar ... elds.htm&type=5https://help.salesforce.com/s/articleView
NEW QUESTION # 60
Now, our Salesforce-Certified-Administrator study questions are in short supply in the market. Our sales volumes are beyond your imagination. Every day thousands of people browser our websites to select our Salesforce-Certified-Administrator exam materials. As you can see, many people are inclined to enrich their knowledge reserve. So you must act from now. As we all know, time and tide wait for no man. And our Salesforce-Certified-Administrator Practice Engine will be your best friend to help you succeed.
Salesforce-Certified-Administrator Reliable Real Test: https://www.torrentvce.com/Salesforce-Certified-Administrator-valid-vce-collection.html
Posted at 1/21/2026 04:41:11        Only Author  2#
Thank you for your amazing share; the content is truly shocking! With NCA-GENL pdf dumps, you get access to valuable content at no cost, designed for your benefit.
Posted at 1/25/2026 10:54:17        Only Author  3#
Fortinet NSE7_OTS-7.2 시험환경에 적응하고 싶은 분은 pdf버전 구매시 온라인버전 또는 테스트엔진 버전을 추가구매하시면 됩니다. 문제는 pdf버전의 문제와 같지만 pdf버전의 문제를 마스터한후 실력테스 가능한 프로그램이기에Fortinet NSE7_OTS-7.2시험환경에 익숙해져 시험을 보다 릴렉스한 상태에서 볼수 있습니다.
Posted at 1/26/2026 21:21:47        Only Author  4#
Your article was a true standout, I’m really grateful for it. Here’s the Latest test PCNSE test test that contributed to my promotion and salary increase. It’s free for everyone today—hope you all achieve your career goals soon!
Posted at 2/18/2026 13:08:31        Only Author  5#
I’m so grateful I read that article. The Reliable vce C-SIGPM-2403 test simulator exam questions are free for everyone. Best of luck in your studies!
