[Linux] Ubuntu 20.04, XServer and Qt applicatons with QOpenGLWidget
25
Linux Ubuntu 20.04, XServer and Qt applicatons with QOpenGLWidget
Posted at 8/12/2022 15:30:04      View3950 | Replies4        Print      Only Author   [Copy Link] 1#
Hello!
Hardware: ITX-3588J and two monitors
Software:
Ubuntu 20.04.4 LTS (GNU/Linux 5.10.66 aarch64)
Qt version 5.12.8 installed on ITX-3588J by: sudo apt-get install build-essential qt5-default
X.Org X Server 1.20.8
When we trying to run a qt application with QOpenGLWidget on two monitors (the window has a size 3840x1080), there were problems.
First scenario (Used eglfs):
  1. sudo killall -3 gnome-shell
  2. export QT_QPA_PLATFORM=eglfs
  3. export QT_QPA_EGLFS_INTEGRATION=eglfs_kms
  4. export QT_QPA_EGLFS_KMS_ATOMIC=1
  5. export QT_QPA_EGLFS_KMS_CONFIG=/home/firefly/kms_config.json
  6. ./ZeroCopyGLSample
Copy the code
kms_config.json are:
  1. {
  2.   "device": "/dev/dri/card0",
  3.   "outputs": [
  4.     {
  5.       "name": "HDMI1",
  6.       "mode": "1920x1080"
  7.     },
  8.     {
  9.       "name": "HDMI2",
  10.       "mode": "1920x1080"
  11.     }
  12.   ]
  13. }
Copy the code
Everything starts and works well, except that the application can only use one monitor, although qAppscreens() correctly returns both devices. Attempts to create widgets with the geometry of the second monitor did not give the expected result.
Second scenario (Used Xserver):
xinit /home/firefly/testapps/OpenGL/ZeroCopyGLSample/ZeroCopyGLSample
The application starts, a window is created on two monitors, but OpenGL does not work correctly:
  1. QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
  2. QOpenGLWidget: Failed to create context
Copy the code
I would be grateful for any hint
Thanks for the help!
Posted at 1/10/2026 00:15:37        Only Author  2#
I am so grateful for your share, the article is amazing! Free Exam Data-Driven-Decision-Making pass guide resources are now availablegood luck!
restricted members
Posted at 1/10/2026 03:01:55        Only Author  3#
Truly an impressive article, Im grateful for your sharing. The C11 braindump pdf test helped me secure my promotion and raisegrab it for free today!
Posted at 1/30/2026 04:57:24        Only Author  4#
Sind Sie neugierig, warum so viele Menschen die schwierige Microsoft DP-900-Deutsch Prfung bestehen können? Ich können Sie beantworten. Der Kunstgriff ist, dass Sie haben die Prfungsunterlagen der Microsoft DP-900-Deutsch von unsere Pass4Test benutzt. Wir bieten Ihnen: reichliche Prfungsaufgaben, professionelle Untersuchung und einjährige kostenlose Aktualisierung nach dem Kauf. Mit Hilfe der Microsoft DP-900-Deutsch Prfungsunterlagen können Sie wirklich die Erhöhung Ihrer Fähigkeit empfinden. Sie können auch das echte Zertifikat der Microsoft DP-900-Deutsch erwerben!
Posted at 2/20/2026 14:54:56        Only Author  5#
Tip: the author has been banned or deleted automatically shield
