Plat-Dev-201 Materials 100% Pass | Professional Plat-Dev-201: Salesforce Certifi
Posted at 1/13/2026 17:18:38
We can confidently say that our Plat-Dev-201 training quiz will help you. First of all, our company is constantly improving our Plat-Dev-201 exam materials according to the needs of users. As you can see that there are three versions of our Plat-Dev-201 learning questions on our website for you to choose: the PDF, Software and APP online. As long as you have a try on our Plat-Dev-201 study prep, you will want our Plat-Dev-201 study materials to prapare for the exam for sure.
Our exam prep material is famous among Plat-Dev-201 exam candidates which help to polish the knowledge required to pass the Salesforce Plat-Dev-201 exam. The certification is organized by Plat-Dev-201 internationally. Our Salesforce Plat-Dev-201 exam questions are the most cost-effective as we understand that you need low-cost material but are authentic and updated. TestValid provides its Salesforce Plat-Dev-201 Exam Questions in three forms, one is PDF eBook, the second is practice exam software for Windows-based systems, and the third is an online practice test.
Plat-Dev-201 Materials Exam Pass Once Try | Authorized Plat-Dev-201 CertificationWhen new changes or knowledge are updated, our experts add additive content into our Plat-Dev-201 latest material. They have always been in a trend of advancement. Admittedly, our Plat-Dev-201 real questions are your best choice. We also estimate the following trend of exam questions may appear in the next exam according to syllabus. So they are the newest and also the most trustworthy Plat-Dev-201 Exam Prep to obtain.
Salesforce Certified Platform Developer Sample Questions (Q144-Q149):NEW QUESTION # 144
A developer created a Lightning web component called statusComponent to be inserted into the Account record page.
Which two things should the developer do to make the component available?
- A. Add<target> Lightning_RecordPage </target> to the statusComponent.js file.
- B. Add <isExposed> true</isExposed> to the statusComponent.js-meta ml file.
- C. Add < masterLabel>Account</master Label> to the statusComponent.js-meta ml file.
- D. Add <target> lighting _RecordPage </target> to the statusComponent.js-meta ml file.
NEW QUESTION # 145
An org has an existing Flow that creates an Opportunity with an Update Records element. A developer update the Flow to also create a Contact and store the created Contact's ID on the Opportunity.
Which update should the developer make in the Flow?
- A. Add a new Create Records element.
- B. Add a new Update Records element.
- C. Add a new Get Records element.
- D. Add a new Quick Action element(of type Create).
NEW QUESTION # 146
As part of a data cleanup strategy, AW Computing wants to proactively delete associated opportunity records when the related Account is deleted.
Which automation tool should be used to meet this business requirement?
- A. Record-Triggered Flow
- B. Process Builder
- C. Workflow Rules
- D. Scheduled job
NEW QUESTION # 147
A developer created a child Lightning web component nested inside a parent Lightning web component, parent component needs to pass a string value to the child component.
In which two ways can this be accomplished?
Choose 2 answers
- A. The parent component can use a public property to pass the data to the child component.
- B. The parent component can use the Apex controller class to send data to the child component.
- C. The parent component can use a custom event to pass the data to the child component,
- D. The parent component can invoke a method in the child component
NEW QUESTION # 148
Universal Containers implemented a private sharing model for the Account object. A custom Account search tool was developed with Apex to help sales representatives find accounts that match multiple criteria they specify. Since its release, users of the tool report they can see Accounts they do not own. What should the developer use to enforce sharing permission for the currently logged-in user while using the custom search tool?
- A. Use the with sharing keyword on the class declaration.
- B. Use the without sharing keyword on the class declaration.
- C. Use the schema describe calls to determine if the logged-in users has access to the Account object.
- D. Use the UserInfo Apex class to filter all SOQL queries to returned records owned by the logged-in user.
Use the with sharing keyword on the class declaration. The with sharing keyword ensures that the Apex code respects the object-level, field-level, and record-level sharing settings for the user who is running the Apex code. This means that the code will only return records that the user has access to, according to their Sharing Settings. You can find more information about the with sharing keyword in the official Salesforce documentation (https://developer.salesforce.com/docs/atlas.en- us.apexcode.meta/apexcode/apex_classes_keywords_sharing.htm).
NEW QUESTION # 149
The TestValid is a leading platform that has been helping the Salesforce Plat-Dev-201 exam aspirants for many years. Over this long time period, thousands of Salesforce Certified Platform Developer (Plat-Dev-201) exam candidates have passed their dream Salesforce Plat-Dev-201 Certification Exam and have become a member of Salesforce Plat-Dev-201 certification exam community. They all got help from valid, updated, and real Plat-Dev-201 exam dumps.
Authorized Plat-Dev-201 Certification: https://www.testvalid.com/Plat-Dev-201-exam-collection.html
If you pay more attention to the privacy protection on buying Plat-Dev-201 training materials, you can choose us, When you go over the Authorized Plat-Dev-201 Certification - Salesforce Certified Platform Developer test online files, you can learn efficiently because of your notes, Salesforce Plat-Dev-201 Materials Best quality for better preparation, Salesforce Plat-Dev-201 Materials We are powerful and old company which has good reputation in this area.
Behind the scenes, Workshop applications use a Struts-based implementation Plat-Dev-201 to provide the presentation and Controller functionality known as Page Flow, In most cases, this is probably a good idea.
Salesforce Plat-Dev-201 Exam Questions: Your Key to Exam SuccessIf you pay more attention to the privacy protection on buying Plat-Dev-201 Training Materials, you can choose us, When you go over the Salesforce Certified Platform Developer test online files, you can learn efficiently because of your notes.
Best quality for better preparation, We are powerful and old company which has good reputation in this area, Now, we provide you with the comprehensive and most valid Plat-Dev-201 updated study material.
- Plat-Dev-201 Materials: 2026 Salesforce Realistic Salesforce Certified Platform Developer Materials Pass Guaranteed Quiz 📙 Download 「 Plat-Dev-201 」 for free by simply searching on ⇛ [url]www.troytecdumps.com ⇚ 👾New Plat-Dev-201 Test Question[/url]
- Plat-Dev-201 Test Prep 🚛 Latest Plat-Dev-201 Dumps Ppt ⛲ New Plat-Dev-201 Test Tutorial 🏩 Open website ▶ [url]www.pdfvce.com ◀ and search for ( Plat-Dev-201 ) for free download 🔶
lat-Dev-201 Reliable Torrent[/url] - Latest Plat-Dev-201 Dumps Ppt 👉 Plat-Dev-201 Exam Topic 🌸 Plat-Dev-201 Pass Guaranteed 🗯 Search for ⮆ Plat-Dev-201 ⮄ and obtain a free download on ➠ [url]www.prepawayexam.com 🠰 🍘Certification Plat-Dev-201 Book Torrent[/url]
- Plat-Dev-201 Materials: 2026 Salesforce Realistic Salesforce Certified Platform Developer Materials Pass Guaranteed Quiz ℹ Search for ➽ Plat-Dev-201 🢪 and download it for free on ✔ [url]www.pdfvce.com ️✔️ website ⏮Latest Plat-Dev-201 Exam Forum[/url]
- High Pass-Rate Plat-Dev-201 Materials | Plat-Dev-201 100% Free Authorized Certification 🤢 Download ⏩ Plat-Dev-201 ⏪ for free by simply searching on ➠ [url]www.troytecdumps.com 🠰 🕣Interactive Plat-Dev-201 Practice Exam[/url]
- Latest Plat-Dev-201 Exam Review 🐐 Interactive Plat-Dev-201 Practice Exam 📊 Interactive Plat-Dev-201 Practice Exam 🌆 ➽ [url]www.pdfvce.com 🢪 is best website to obtain 【 Plat-Dev-201 】 for free download 🚵
lat-Dev-201 Latest Questions[/url] - Plat-Dev-201 Valid Mock Exam 🍷 Latest Plat-Dev-201 Dumps Ppt ⛲ Plat-Dev-201 Valid Mock Exam 🚨 Download ▷ Plat-Dev-201 ◁ for free by simply searching on “ [url]www.prepawaypdf.com ” 🌗Examinations Plat-Dev-201 Actual Questions[/url]
- Interactive Plat-Dev-201 Practice Exam 🚔 Latest Plat-Dev-201 Exam Forum 👧 Plat-Dev-201 Reliable Torrent 🍷 Search for 「 Plat-Dev-201 」 and easily obtain a free download on { [url]www.pdfvce.com } 🕟Latest Plat-Dev-201 Learning Material[/url]
- Plat-Dev-201 Test Prep 📃 Plat-Dev-201 Pass Guaranteed ⚽ Plat-Dev-201 Reliable Torrent 📉 Copy URL ( [url]www.vce4dumps.com ) open and search for ➤ Plat-Dev-201 ⮘ to download for free 🪒New Plat-Dev-201 Test Question[/url]
- Plat-Dev-201 Pass Guaranteed 😝 Interactive Plat-Dev-201 Practice Exam ☃ New Plat-Dev-201 Test Tutorial 🎸 Search for ➡ Plat-Dev-201 ️⬅️ and download it for free immediately on ☀ [url]www.pdfvce.com ️☀️ 🕎
lat-Dev-201 Vce File[/url] - Plat-Dev-201 Download Fee 🤹 Plat-Dev-201 Latest Questions 🎉 Plat-Dev-201 Valid Mock Exam 🤨 Search for ⏩ Plat-Dev-201 ⏪ and download it for free on 【 [url]www.practicevce.com 】 website ⤵
lat-Dev-201 Download Fee[/url] - www.wcs.edu.eu, www.stes.tyc.edu.tw, cou.alnoor.edu.iq, accademia.webleaders.it, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, app.gradxacademy.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
