100% Pass 2026 Perfect 2V0-16.25: Latest VMware vSphere Foundation 9.0 Administr
67
Posted at 1/13/2026 17:20:26      View229 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New 2V0-16.25 dumps are available on Google Drive shared by BraindumpsPass: https://drive.google.com/open?id=12A-4wEFApRR9ws7Gu037J2rx1SfvJ2X0
Our 2V0-16.25 study materials have a high quality which is mainly reflected in the pass rate. Our product can promise a higher pass rate than other study materials. 99% people who have used our 2V0-16.25 study materials passed their exam and got their certificate successfully, it is no doubt that it means our 2V0-16.25 study materials have a 99% pass rate. So our product will be a very good choice for you. If you are anxious about whether you can pass your exam and get the certificate, we think you need to buy our 2V0-16.25 Study Materials as your study tool, our product will lend you a good helping hand. If you are willing to take our 2V0-16.25 study materials into more consideration, it must be very easy for you to pass your exam in a short time.
VMware 2V0-16.25 Exam Syllabus Topics:
  • IT Architectures, Technologies, Standards: This section of the exam measures the understanding of IT Infrastructure Architects and covers foundational concepts of architectures, emerging technologies, and industry standards. Although no testable objectives are listed here, it establishes the baseline knowledge needed to interpret and design VMware-related environments effectively.
  • Plan and Design the VMware by Broadcom Solution: This section of the exam measures the ability of VMware Solution Architects to plan and design solutions. While there are no specific testable objectives included, the focus is on preparing professionals to design VMware-based solutions that align with organizational goals and best practices.
  • VMware vSphere Foundation Fundamentals: This section of the exam measures the skills of Virtualization Engineers and focuses on the essentials of virtualization technology. It introduces the principles of virtualization, explores use cases, and highlights the value it brings to businesses. Candidates are expected to demonstrate knowledge of VMware compute components such as vCenter and ESX, cluster configuration, and lifecycle management of virtual machines. It also covers secure workload operations, encryption, and managing resources with content libraries. In addition, storage fundamentals are examined through configuring vSphere storage, deploying VMware vSAN clusters, defining storage policies, and ensuring data availability. Networking fundamentals are also introduced, requiring the ability to differentiate between VMware vSphere networking components.
  • Troubleshoot and Optimize the VMware Solution: This section of the exam measures the ability of Systems Engineers to troubleshoot and optimize VMware-based environments. While no explicit testable objectives are listed, candidates are expected to apply their problem-solving skills to diagnose, resolve, and enhance VMware solutions for improved reliability and performance.
Topic 5
  • Deploy, Configure, and Operate VMware vSphere Foundation (VVF): This section of the exam measures the expertise of Data Center Administrators and emphasizes hands-on skills in deploying and configuring VMware vSphere Foundation environments. Candidates must understand the components of a VVF deployment, configure Supervisors within clusters, and manage identity, access control, licensing, and certificate management. The objectives also extend to lifecycle management within the vSphere Foundation. Furthermore, it explores operational tasks including monitoring and analyzing logs, configuring alerting, managing dashboards, and integrating with VMware Cloud Foundation (VCF) Operations. Candidates will also be tested on cost and pricing configuration, compliance monitoring, and security hardening practices. Finally, automation skills are validated through deploying services with Supervisors, running Kubernetes workloads, using VM services, and integrating VCF Operations Orchestrator to support enterprise automation.
2V0-16.25 New Braindumps Pdf - Exam 2V0-16.25 TopicsBraindumpsPass offers 2V0-16.25 actual exam dumps in easy-to-use PDF format. It is a portable format that works on all smart devices. Questions in the 2V0-16.25 PDF can be studied at any time from any place. Furthermore, VMware vSphere Foundation 9.0 Administrator (2V0-16.25) PDF exam questions are printable. It means you can avoid eye strain by preparing real questions in a hard copy.
VMware vSphere Foundation 9.0 Administrator Sample Questions (Q16-Q21):NEW QUESTION # 16
An administrator is tasked to deploy a new eight-node VMware vSAN Express Storage Architecture (ESA) cluster.
What are three minimum requirements to accomplish this? (Choose three.)
  • A. PCIe flash device (NVMe)
  • B. 10GbE network interfaces
  • C. SAS solid-state disk (SSD)
  • D. 25GbE network interfaces
  • E. 128GB Memory
  • F. 256GB Memory
Answer: A,D,E
ForvSAN ESA (Express Storage Architecture), minimum requirements differ from OSA:
* 25GbE NICsare required to handle high-performance traffic. (C)
* NVMe PCIe flash devicesmust be used for storage. (D)
* 128GB Memory minimumper host is required. (F)
Other options:
* A. 10GbE# Only supported in vSAN OSA, not ESA.
* B. 256GB Memory# Recommended for large workloads, not minimum.
* E. SAS SSDs# Not supported in ESA; NVMe required.
VMware Cloud Foundation 9.0 -vSAN ESA Hardware Requirements
VMware Docs: vSAN ESA Deployment Requirements
NEW QUESTION # 17
An administrator has noticed occasional performance degradation during peak usage times and needs to address this issue proactively by creating a mechanism that doesn't give data or outputs too often to overload the team.
Which of the following steps is required to create the mechanism in VMware Cloud Foundation (VCF) Operations?
  • A. Create a custom dashboard to visualize all alerts.
  • B. Implement an alert with the default alert settings.
  • C. Implement an alert that notifies the IT team during off-peak hours.
  • D. Implement an alert specifying the metric, threshold, and duration.
The administrator wants toproactively manage performance degradationduring peak times without overwhelming the IT team.
* The correct method is tocreate a custom alert with specific metric, threshold, and duration(A).
* This ensures alerts are triggered only when sustained performance issues occur, reducing noise.
* B. Default alert settings# Too generic, may cause alert storms.
* C. Custom dashboard# Useful for visualization but not proactive alerting.
* D. Notify during off-peak hours# Defers the issue, not proactive.
VMware Cloud Foundation 9.0.3 -Creating Alerts and Policies
VMware Docs: [Configuring Alerts in vRealize Operations]
NEW QUESTION # 18
A virtual machine (VM) owner has requested to move a VM from one cluster to another. The following information has been provided:
* The VM cannot have downtime during the transfer.
* The same network is present on both clusters.
* The datastore that the VM is currently on is not present in the destination cluster.
What step should the administrator perform to move the VM?
  • A. Inform the owner the VM cannot be moved to the new cluster.
  • B. Perform a vMotion with Storage vMotion to the new cluster.
  • C. Backup the VM and restore it to the new cluster.
  • D. Perform a vMotion of the VM to the new cluster.
To move a VM to another cluster:
* Requirement: Zero downtime# RequiresvMotion.
* Challenge: Datastore not shared# RequiresStorage vMotion.
* The combined operation,Cross-Cluster vMotion with Storage vMotion, allows moving compute and storage at the same time, with no downtime.
Other options:
* A. vMotion only# Requires shared datastore, not available here.
* B. Backup/restore# Causes downtime, not acceptable.
* D. Cannot be moved# Incorrect; vMotion + Storage vMotion supports this.
VMware vSphere 9.0 -Cross-Cluster vMotion Requirements
VMware Docs: vMotion and Storage vMotion
NEW QUESTION # 19
An administrator is tasked with importing a vSphere Lifecycle Manager image and applying it to a cluster containing six hosts, with two of the hosts in maintenance mode. The administrator uses the vSphere Client, navigates to the cluster, and edits the remediation settings to enable Parallel Remediation and clicks the Remediate All button to execute the remediation process.
What is the expected result of this remediation process?
  • A. The image is remediated on the hosts in maintenance mode in parallel. The hosts not in maintenance mode are not remediated.
  • B. The image is remediated on the four hosts not in maintenance mode, in sequence. The hosts in maintenance mode are not remediated.
  • C. The image is remediated on the hosts in maintenance mode in parallel, and when completed the hosts not in maintenance mode are remediated in parallel.
  • D. The image is remediated on the four hosts not in maintenance mode, in parallel. The hosts in maintenance mode are not remediated.
When usingvSphere Lifecycle Manager (vLCM)withParallel Remediationenabled, the following rules apply:
* Parallel remediation only applies to ESXi hosts that are already in Maintenance Mode.
* vLCM doesnotput hosts into Maintenance Mode automatically in this mode.
* Similarly, it does not exit Maintenance Mode automatically after remediation.
* Hosts not in Maintenance Mode are skipped.
* If Parallel Remediation is activated, vLCM remediates only those hosts that are already in Maintenance Mode.
* Any hosts that are not in Maintenance Mode remain untouched.
* Remediation happens in parallel for all eligible hosts.
* In this case, two of the six hosts are in Maintenance Mode. Those two hosts will be remediated in parallel.
* The remaining four hosts (not in Maintenance Mode) willnotbe remediated at all.
* A. Four hosts not in maintenance mode are remediated in parallel##Incorrect. Hosts must already be in Maintenance Mode to be remediated.
* B. Hosts in maintenance mode first, then non-maintenance hosts##Incorrect. Non-maintenance mode hosts are skipped, not remediated after.
* C. Four hosts remediated sequentially, others skipped##Incorrect. Parallel Remediation does not touch non-maintenance mode hosts.
* D. Hosts in maintenance mode remediated in parallel; others skipped##Correct and matches VMware documentation.
VMware vSphere 9.0 Documentation -Parallel Remediation for Lifecycle Manager Images VMware vSphere 9.0 Documentation -Parallel remediation applies only to ESX hosts already in maintenance mode
NEW QUESTION # 20
The security team requests the ability to log into VMware vCenter and review datacenter, cluster and network configurations. The following details are provided:
* The security team is not authorized to make any changes to the environment.
* Each user must login with unique credentials.
What steps should the administrator perform to grant access to the security team?
  • A. Create a group for the security team, add the users to the group, and assign the group the Read-Only role.
  • B. Create a group for the security team, add the users to the group, and assign the group the Network Administrator role.
  • C. Create a security user, assign the user the Read-Only role, share the credentials with the security team.
  • D. Share the password for 'administrator@vsphere.local' with the security team.
The security team requiresvisibility into vCenter configurationsbut must not make changes.
* Best practice is tocreate an Active Directory or vCenter group, add the security users, and assign them theRead-Only roleat thedatacenter/cluster/networklevel.
* This ensures each user logs in with unique credentials, maintaining accountability.
Why others are incorrect:
* A. Share administrator@vsphere.local password# Violates security best practices.
* B. Create a single user and share credentials# Still insecure, lacks unique audit trails.
* C. Assign Network Administrator role# Grants configuration permissions, not allowed.
VMware vSphere 9.0 Documentation -Roles and Permissions Best Practices
VMware Docs: vCenter Server Role-Based Access Control
NEW QUESTION # 21
The second format is a web-based format that can be accessed from browsers like Firefox, Microsoft Edge, Chrome, and Safari. It means you don't need to download or install any software or plugins to take the VMware vSphere Foundation 9.0 Administrator practice test. The web-based format of the VMware 2V0-16.25 Certification Exams practice test supports all operating systems. The third and last format is desktop software format which can be accessed after installing the software on your VMware vSphere Foundation 9.0 Administrator (2V0-16.25) Windows Pc or Laptop. These formats are built especially for the students so they don't stop preparing for the VMware vSphere Foundation 9.0 Administrator (2V0-16.25) certification.
2V0-16.25 New Braindumps Pdf: https://www.braindumpspass.com/VMware/2V0-16.25-practice-exam-dumps.html
DOWNLOAD the newest BraindumpsPass 2V0-16.25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=12A-4wEFApRR9ws7Gu037J2rx1SfvJ2X0
Posted at 1/21/2026 22:57:03        Only Author  2#
֪Τ褦ˡTopexam220-1202ģMԇYˤώڴЈꡢCompTIA͘ߤuƤޤ 220-1202̲Ĥ~Ͻ֧Bǡ99δ_ʤ220-1202ԇY˺ϸ񤷡ͤ뤳ȤǤޤ ʤνĿˤϤγɹԇYʼޤȴ_ŤƤޤ äơ220-1202ȥ`˥YϤxk뤳ȤtxkǤ ˽ξYϤϡʤΉ_ɤΤCompTIA A+ Certification Exam: Core 2֪RΥץåȥե`ṩޤ 220-1202g̲Ĥxkُ뤷Ƥ
Posted at 3/8/2026 08:37:45        Only Author  3#
τ٤ؓʤؓäԤʤˤ٤ʤΤ衣Microsoft PL-300JJԇYyȤǴ󷽤YԇY˺ϸ񤷤ʤäΤ椷ơߤΤ褦ˤΥ󥸤äƤޤǡҡMicrosoft PL-300JoϤԇY}ץοޤԷ֤ꤷ}Щ`PDF桢եȰ򡢥饤棩xǡѧ̲Ĥ㏊_δ𤨤ҙMicrosoft PL-300JYJԇYһȤǺϸǤޤ
