[Linux] Linux distribution image
Linux Linux distribution image
Posted at 8/18/2022 20:39:48      View3489 | Replies7        Print      Only Author   [Copy Link] 1#
Hi, can someone share a ready-made Linux distribution with a working HDMI (an image with a file system, bootloader, kernel, etc.) for this board?
Edit 1: It is possible without a bootloader, only the root partition with the /boot directory, in which the kernel and the device tree are located.
Posted at 8/19/2022 14:33:15        Only Author  2#
Posted at 8/19/2022 19:41:09        Only Author  3#
zooora111 Posted at 8/19/2022 14:33
Maybe you can check this: https://en.t-firefly.com/doc/download/91.html
Yes, I have already examined everything, the system is not going as I need it, but there is no ready-made one, so I ask if anyone has a ready-made and working one.
Posted at 8/20/2022 10:57:37        Only Author  4#
Paquq Posted at 8/19/2022 19:41
Yes, I have already examined everything, the system is not going as I need it, but there is no rea ...
Hey, do you want a mainline kernel
Posted at 8/20/2022 23:21:37        Only Author  5#
Javier Posted at 8/20/2022 10:57
Hello, I need a kernel on which the console is running via HDMI and a working frame buffer, so I also need an up-to-date device tree and a kernel boot command
Posted at 1/22/2026 03:26:23        Only Author  6#
After reading this article, I feel that Ive made progress in both thinking and actions. The C_P2WFI_2023 exam lab questions helped me secure my promotion and raise. Its free now for everyone. Best of luck with your career!
Posted at 2/1/2026 22:08:08        Only Author  7#
The article is so thought-provoking, thank you for your valuable share! Boost your IT knowledge with free CPHQ latest test simulator. Best of luck to everyone!
Posted at 2/11/2026 10:59:25        Only Author  8#
Manchmal bedeutet ein kleinem Schritt ein großem Fortschritt des Lebens. Die Salesforce Plat-Arch-203 Prfung scheit nur ein kleinem Test zu sein, aber der Vorteil der Prfungszertifizierung der Salesforce Plat-Arch-203 fr Ihr Arbeitsleben darf nicht bersehen werden. Diese internationale Zertifikat beweist Ihre ausgezeichnete IT-Fähigkeit. Neben Salesforce Plat-Arch-203 sind auch andere Zertifizierungsprfung sehr wichtig, deren neueste Unterlagen können Sie auch auf unserer Webseite finden.
