[General] Correct Sample CCAAK Exam & Leader in Qualification Exams & Pass-Sure CC
57
General Correct Sample CCAAK Exam & Leader in Qualification Exams & Pass-Sure CC
Posted at 1/13/2026 17:54:02      View256 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest ActualTestsQuiz CCAAK PDF Dumps and CCAAK Exam Engine Free Share: https://drive.google.com/open?id=1h3MOT5NaUABX9ntVBrXw3ZHWCyZKpEMi
For candidates who choose CCAAK test materials for the exam, the quality must be one of most important standards for consideration. We have a professional team to collect the first-rate information for the exam, and we also have reliable channel to ensure you that CCAAK exam braindumps you receive is the latest one. We are strict with the quality and answers, and CCAAK Exam Materials we offer you is the best and the latest one. In addition, we provide you with free update for 365 days, so that you can know the latest information for the exam, and the latest version for CCAAK training materials will be sent to your email address autonmatically.
How to get a good job? If you are a freshman, a good educational background and some useful qualifications certification will make you outstanding. If you are dreaming for obtaining a IT certificate, our CCAAK test dumps pdf will help you clear exam easily. If you are a working man, a valid certification will make you obtain an advantage over others while facing job promotion competition. Our CCAAK Test Dumps Pdf can help you clear exam and obtain exam at the first attempt.
Free PDF Quiz 2026 Confluent CCAAK: Trustable Sample Confluent Certified Administrator for Apache Kafka ExamWith the pass rate reaching 98.75%, our CCAAK test materials have gained popularity in the international market. Many candidates have recommended our products to their friends. In addition, CCAAK exam materials are edited by skilled professionals, and they possess the professional knowledge for the exam, therefore you can use the exam materials at ease. Free demo for CCAAK Exam Dumps are available, and you can have a try before buying , so that you can have a better understanding of what you are going to buy.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q26-Q31):NEW QUESTION # 26
You are managing a cluster with a large number of topics, and each topic has a lot of partitions. A team wants to significantly increase the number of partitions for some topics.
Which parameters should you check before increasing the partitions?
  • A. Check the producer batch size and buffer size.
  • B. Check if acks=all is beina used.
  • C. Check if compression is being used.
  • D. Check the max open file count on brokers.
Each Kafka partition maps to multiple log segment files, and each segment results in open file descriptors on the broker. When the number of partitions increases significantly, it can exceed the OS-level limit for open files per broker process, leading to failures or degraded performance. Therefore, it is essential to check and possibly increase the ulimit -n (max open files) setting on the broker machines.
NEW QUESTION # 27
The Consumer property 'auto offset reset' determines what to do if there is no valid offset for a Consumer Group.
Which scenario is an example of a valid offset and therefore the 'auto.offset.reset' does NOT apply?
  • A. The Consumer offset is greater than the last offset in the partition (log end offset).
  • B. The Consumer offset is less than the smallest offset in the partition (log start offset).
  • C. When an offset points to a message that has been removed by compaction but is still within the current partition.offset range.
  • D. The Consumer Group started for the first time.
In this scenario, the offset itself is still valid, even though the record at that offset was compacted away. The consumer can continue consuming from the next available record. Therefore, auto.offset.reset does NOT apply, because there is a valid offset present.
NEW QUESTION # 28
You are managing a Kafka cluster with five brokers (broker id '0', '1','2','3','4') and three ZooKeepers. There are 100 topics, five partitions for each topic, and replication factor three on the cluster. Broker id '0' is currently the Controller, and this broker suddenly fails.
Which statements are correct? (Choose three.)
  • A. The Controller uses the epoch number to prevent a split brain scenario.
  • B. The Controller is responsible for reassigning partitions to the consumers in a Consumer Group.
  • C. The number of Controllers should always be equal to the number of brokers alive in the cluster.
  • D. Kafka uses ZooKeeper's ephemeral node feature to elect a controller.
  • E. The broker id is used as the epoch number to prevent a split brain scenario.
  • F. The Controller is responsible for electing Leaders among the partitions and replicas.
Answer: A,D,F
Kafka relies on ZooKeeper's ephemeral nodes to detect if a broker (controller) goes down and to elect a new controller.
The controller manages partition leadership assignments and handles leader election when a broker fails.
The epoch number ensures coordination and avoids outdated controllers acting on stale data.
NEW QUESTION # 29
A Kafka administrator notices that their consumers of Topic X are starting to fall behind. The administrator sees that Topic X has four partitions, and the consumer group has two consumers.
Which change can increase the performance of the Consumer Group?
  • A. Decrease the consumer acknowledgment property to increase throughput.
  • B. Increase the number of consumers in the consumer group.
  • C. Create a new consumer group for Topic X containing two (2) consumers.
  • D. Increase the partitions in Topic X.
With 4 partitions and only 2 consumers, some consumers are handling multiple partitions, which may cause lag if processing is slow. By increasing the number of consumers in the group (up to 4), Kafka can assign one partition per consumer, improving parallelism and throughput.
NEW QUESTION # 30
How can load balancing of Kafka clients across multiple brokers be accomplished?
  • A. Replicas
  • B. Connectors
  • C. Offsets
  • D. Partitions
Partitions are the primary mechanism for achieving load balancing in Kafka. When a topic has multiple partitions, Kafka clients (producers and consumers) can distribute the load across brokers hosting these partitions.
NEW QUESTION # 31
Our website can offer you the latest Confluent pass guide and learning materials, which enable you pass CCAAK valid exam at your first attempt. Besides, there are CCAAK free braindumps that you can download to learn about our products. Once you decide to buy our test answers, you will be allowed to free update your CCAAK Top Dumps one-year.
CCAAK Sample Questions Answers: https://www.actualtestsquiz.com/CCAAK-test-torrent.html
Try it right now, Especially in such a fast-pace living tempo, we attach great importance to high-efficient learning our CCAAK study guide, With the company of our CCAAK study dumps, you will find the direction of success, If you want to be a more successful person and become the best, the first step you need to take is to have our CCAAK exam questions, Doubtlessly, clearing the CCAAK certification exam is a challenging task.
Share information in one location, If the cables could hiss, they surely would, Try it right now, Especially in such a fast-pace living tempo, we attach great importance to high-efficient learning our CCAAK Study Guide.
Pass-Sure Sample CCAAK Exam | CCAAK 100% Free Sample Questions AnswersWith the company of our CCAAK study dumps, you will find the direction of success, If you want to be a more successful person and become the best, the first step you need to take is to have our CCAAK exam questions.
DOWNLOAD the newest ActualTestsQuiz CCAAK PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1h3MOT5NaUABX9ntVBrXw3ZHWCyZKpEMi
Posted at 2/3/2026 02:51:50        Only Author  2#
Im so appreciative of your article, it really made an impression. The 312-97 latest visual cert exam exam that helped me get promoted and earn a salary raise is available for you today at no charge. Hope you reach your career targets soon!
Posted at 3/7/2026 04:08:32        Only Author  3#
ˆɹҸV㣬ɹTestpdfxTestpdfxɹTestpdf SalesforceB2C-Commerce-ArchitectԇӖYǎITJCĿͨ^JCģᘌSalesforceB2C-Commerce-ArchitectԇJCģ^࿼ӳTestpdf SalesforceB2C-Commerce-ArchitectԇӖYڿеõ˺ܴķ푣˺ܺõĿڱfxTestpdf SalesforceB2C-Commerce-ArchitectԇӖYϾxɹ
