[Hardware] Salesforce B2C-Commerce-Architect考試資訊 - B2C-Commerce-Architect題庫
80
【Hardware】 Salesforce B2C-Commerce-Architect考試資訊 - B2C-Commerce-Architect題庫
Posted at 1/13/2026 18:31:38      View:177 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的、最新的B2C-Commerce-Architect考試題庫:https://drive.google.com/open?id=1GAYilXEsXSa28V-osj75dCLUMkhIR2XH
儘管當時在市場上有許多 Salesforce 方面的書籍,但沒有一本是百分之百介紹實際操作的。許多關於 Salesforce 配置方面的書也只包括配置的某些部分,並不提供足夠的信息使讀者能完整地建立和測試配置。而 NewDumps 的 B2C-Commerce-Architect 考題助您一次輕鬆通過 Salesforce 考試。我們提供的 B2C-Commerce-Architect 考古題含蓋了當前最新的真實考題,並且全部附有正確答案。如果您正在準備考試,它將是最佳的學習助手,是您通過考試取得 B2C-Commerce-Architect 認證的捷徑。
Salesforce認證的B2C商業架構師認證考試考試考試考試了候選人的知識和技能,包括建築和設計原理,數據建模,網站設計和開發,集成以及安全性。為了通過考試並獲得認證,候選人必須對這些主題有深刻的了解,並能夠將其應用於現實世界中。
Salesforce B2C-Commerce-Architect 考試大綱:
主題簡介
主題 1
  • Monitoring
  • Troubleshooting: This topic equips the B2C Commerce Developer to evaluate and implement custom logging configurations using Log Center while leveraging other diagnostic tools. It emphasizes identifying and addressing performance issues like quota violations and service timeouts, as well as proactively adjusting systems for scalability and health.
主題 2
  • Integrations and Customizations: This topic empowers the B2C Commerce Developer to identify and implement protocols like SOAP
  • REST for secure integrations with third-party web services. It also covers defining approaches for legacy code integration and AppExchange solutions.
主題 3
  • Launch: This topic prepares the B2C Commerce Developer to set up SEO-compliant aliases for site domains, locales, and currencies. It includes creating rollback plans, monitoring system health during site launches, defining data replication schedules, and supporting data migration processes.
主題 4
  • Design
  • Discovery: In this topic, the B2C Commerce Developer gains expertise in creating accurate technical specifications based on business requirements. It explores drafting complementary technical artifacts, reviewing implementation designs for scalability and gap analysis, and evaluating AppExchange solutions and API documentation. Additionally, it emphasizes analyzing integration points, data volume, and migration approaches while diagramming system architectures.
主題 5
  • Build: In this topic, the B2C Commerce Developer hones the ability to evaluate implementation processes to ensure alignment with business objectives. It includes validating best practices for secure, modular, and performant solutions, guiding teams in resolving complex issues, and supporting load testing to meet KPIs. The topic also covers defining processes for deploying cartridges and data to Salesforce environments.
B2C-Commerce-Architect題庫 - B2C-Commerce-Architect更新作為一位 Salesforce B2C-Commerce-Architect 考生而言,作好充分的準備可以幫助您通過考試。首先您必須去當地考試中心咨詢相關考試信息,然后挑選最新的 B2C-Commerce-Architect 考試題庫,因為擁有了最新的 B2C-Commerce-Architect 考試題庫可以有利的提高通過考試的機率。使用NewDumps 的題庫可以節省您寶貴的時間,保證你順利通過 B2C-Commerce-Architect 考試。既能幫您節省時間,又可以順利幫助您通過考試,這將是您的最佳選擇。
贏得Salesforce B2C-Commerce-Architect認證的主要好處之一是,它向潛在的雇主和客戶證明,候選人在Salesforce B2C Commerce Platform中具有很高的專業知識。該認證作為證據表明候選人能夠設計和實施複雜的B2C商業解決方案,並且可以信任為客戶提供高質量的服務。
最新的 Salesforce Architect B2C-Commerce-Architect 免費考試真題 (Q65-Q70):問題 #65
The Architect has been presented with a requirement from the business to implement a new LINK cartridge.
The current site is built on the Storefront Reference Architecture, and the LINK cartridge is certified for Pipelines and Controllers. On review, the Architect notes that the Jobs are all created in Pipelines.
How should the Architect implement that cartridge to make sure the required jobs runs property?
  • A. The job Pipelines must be removed and recreated with scripts.
  • B. The job Pipelines must be updated to work as custom job steps.
  • C. The Job Pipelines must be updated to use SiteGenesis Controllers.
  • D. The job Pipelines must be updated to use SFRA Controllers.
答案:A
問題 #66
Northern Trail Outfitters (NTO) wants to migrate its online shoo from a custom ecommerce platform to B2CCommerce. NTO needs to migrate several thousands of customer records profile information, address book). WTO can provide a B2C Commerce feed. It is currently using SHA-256 as an encryption mechanism for the customer passwords.
What approach can the Architect propose?
  • A. Import the customer records, excluding the password field, and B2C Commerce will automatically require a password reset the first time a customer logs m to the storefront.
  • B. Import the customer records, including the hashed password, as B2C Commerce supports SHA-2S6, and they will be able to login with their existing password.
  • C. Do not import customer records and asks customers to create new accounts the firstfame they try to log in to the B2C Commerce storefront.
  • D. Import the customer records, with the hashed password as a custom attribute, and during the login compare the entered password with the hashed password and save it in the password field.
答案:A
解題說明:
B2C Commerce does not directly support the import of hashed passwords for use in authentication due to security protocols and the platform's password management system. The best approach is to import customer records without the password field. Upon their first login attempt on the new system, customers would be prompted to reset their password. This method ensures that password security is maintained according to B2C Commerce standards and that customer data remains secure during the transition from the old platform.
問題 #67
Northern Trail Outfitters (NTO) wants to migrate its online shoo from a custom ecommerce platform to B2C Commerce. NTO needs to migrate several thousands of customer records profile information, address book).
  • C. Import the customer records, with the hashed password as a custom attribute, and during the login compare the entered password with the hashed password and save it in the password field.
  • D. Do not import customer records and asks customers to create new accounts the first fame they try to log in to the B2C Commerce storefront.
答案:C
問題 #68
An Architect is performing an audit of production logs via Log Center and finds some potentially dangerous custom log output.
In which two ways It this log output Improper In a production environment? Choose 2 answers
  • A. Information logs should not be used in a production environment
  • B. The log information includes the customer s card name as it appears along with the credit card number (PAN), which violates PCI.
  • C. The log information includes the order number and customer s email, which violates PCI.
  • D. The log information includes the customer's card CW (card security code) and expiration date, which violates PCI.
答案:B,C
問題 #69
The Client has requested an Architect's help in documenting the architectural approach to a new home page.
The requirements provided by the business are:
* Multiple areas of static image content, some may need text shown at well
* The content page must be Realizable
* A carousel of featured products must be shown below a banner 101191
* Recommended categories will be featured based on the time of year
Which two solutions would fulfil these requirements?
Choose 2 answers
  • A. Leverage B2C Commerce Page Designer with a dynamic layout.
  • B. Leverage B2C Commerce locales in Business Manager
  • C. Leverage B2C Commerce ContentManagement Service
  • D. Leverage B2C Commerce content slots and assets
答案:A,D
解題說明:
To fulfill the requirements of having multiple static image content areas, a carousel of featured products, and dynamic content adjustments based on the time of year:
* Option C (Leverage B2C Commerce content slots and assets): This solution allows for dynamic content management where different assets and slots can be used to manage and display static images, text overlays, and other content variations effectively.
* Option D (Leverage B2C Commerce Page Designer with a dynamic layout): Using the Page Designer with a dynamic layout enables the easy assembly of complex page designs, including carousels and responsive elements that adjust based on viewing device or other criteria like time of year. This tool provides the flexibility required for real-time customization and resizability of page elements.
These solutions provide robust and flexible management of site content that meets the business's needs for a visually engaging and adaptable homepage.
問題 #70
B2C-Commerce-Architect題庫: https://www.newdumpspdf.com/B2C-Commerce-Architect-exam-new-dumps.html
順便提一下,可以從雲存儲中下載NewDumps B2C-Commerce-Architect考試題庫的完整版:https://drive.google.com/open?id=1GAYilXEsXSa28V-osj75dCLUMkhIR2XH
Posted at 1/13/2026 22:33:46        Only Author  2#
Your article is outstanding, thank you for sharing! Time to tackle the Reliable SPLK-3002 exam registration exam! Fingers crossed!
Posted at 1/20/2026 08:05:17        Only Author  3#
PassTIP에는 베터랑의전문가들로 이루어진 연구팀이 잇습니다, 그들은 it지식과 풍부한 경험으로 여러 가지 여러분이Google인증Google-Workspace-Administrator시험을 패스할 수 있을 자료 등을 만들었습니다, PassTIP 에서는 일년무료 업뎃을 제공하며, PassTIP 의 덤프들은 모두 높은 정확도를 자랑합니다. PassTIP 선택함으로 여러분이Google인증Google-Workspace-Administrator시험에 대한 부담은 사라질 것입니다.
Posted at 2/17/2026 11:34:21        Only Author  4#
Thank you for the brilliant share, it really left me in awe! We offer you access to the rich content of Valid NESTA-PFT guide files for free, hoping it benefits you.
