[General] SAP C_ACDET_2506TJC & C_ACDET_2506}
90
General SAP C_ACDET_2506TJC & C_ACDET_2506}
Posted at 1/13/2026 18:59:40      View182 | Replies4        Print      Only Author   [Copy Link] 1#
P.S. TestpdfGoogle DriveϷM2026 SAP C_ACDET_2506ԇ}죺https://drive.google.com/open?id=1xmhp9oHuDWvwJ5i28c_yH9uufKY83WTv
ITИIкܶIJČIʿITИIܸһӘǣxIT픷һxSAP C_ACDET_2506@y^ߵJCԇ@ȡͨJCCĶ@ИIJɡSAP C_ACDET_2506 yȱ^ͨ^Ҳ^͡LjSAP C_ACDET_2506 JCԇǂǵx񸂠ҵITИIԓҪԼxܶ෽ʽͨ^ԇ
SAP C_ACDET_2506 ԇV
} 1
  • Project Overview, Roles and Responsibilities: This section of the exam measures the skills of an SAP Cloud Consultant and covers the fundamental understanding of SAP Activate methodology within the context of a cloud implementation project. Candidates are expected to be familiar with the project lifecycle, including phases such as Prepare, Explore, Realize, Deploy, and Run. This part also focuses on identifying key roles and responsibilities within a cloud project team, ensuring clarity in collaboration between consultants, clients, and SAP. It checks whether the consultant understands governance, stakeholder management, and the high-level structure of cloud deployment using SAP best practices.
} 2
  • Field Configuration: This domain evaluates the knowledge of an SAP Deployment Specialist and focuses on customizing and configuring business fields in the SAP system according to client-specific needs. This includes adjusting system settings for master data, transaction data, and other essential field-level controls to support business processes effectively. The section tests the candidates ability to use configuration tools, apply SAP standard templates, and ensure that the field configurations align with the desired operational workflows of the business. It also touches upon validation, testing, and documenting the configuration changes made during the implementation.
} 3
  • Deploy and Migration: This part of the exam assesses the expertise of an SAP Deployment Specialist and focuses on the final deployment of the configured solution and the data migration process. Candidates should demonstrate a solid grasp of how to move configurations from a testing environment into production while minimizing disruption. It also includes knowledge of tools and strategies used for data extraction.
ͨ^ʵC_ACDET_2506TJCµČWYώҼͨ^C_ACDET_2506ԇSC_ACDET_2506ԇ׃Testpdfѽ˿ԇ}ʹ𰸣һЩĆ}ͨ^ʹø°汾SAP C_ACDET_2506}pɿٵͨ^ԇ߀sFĕrg@C_ACDET_2506JC֮šIҲ_ʼµx͕rڡُI҂SAP C_ACDET_2506}YԱCһͨ^ԇ@ֵôه}WվԎʹҜpٿԇɱsrgϰҪ@ȡC_ACDET_2506JCx
µ SAP Certified Associate C_ACDET_2506 Mԇ} (Q23-Q28):} #23
Which of the following master data types requires manual migration from Test to Production in a Greenfield migration?
  • A. Relations and relation entries
  • B. Translations
  • C. Enumerations
  • D. Clause Library
𰸣C
}f
In SAP Ariba Greenfield deployments,Enumerations (picklist value lists) require manual migration because they are not included in Intelligent Configuration Manager (ICM) bundles. Enumerations must be manually exported from Test and imported into Production to ensure correct picklist values for fields that depend on them.
Other master data types like Clause Library and Relations can be migrated using standard migration tools or processes. Translations are handled via AML & Translations Upload.
Ensuring enumerations are migrated correctly is critical because missing or inconsistent enumerations can cause field validation errors and disrupt system usage.
} #24
You want to apply a preset filter to a custom field so that it only shows valid values based on the value of another field. What do you use to apply predefined filter criteria for a field?
  • A. Enable field property "Use relationship chooser" in the Advanced tab
  • B. Load Relation types and Relation entries
  • C. Enable field property "Enable for Template Field Setter" in the Advanced tab
  • D. Populate the "Relation Name" and "NameTableConstraintFieldPath" in the Advanced tab
  • E. Define a Visibility Condition in the Conditions tab
𰸣D
}f
To filter a custom field's available values based on another field's value in SAP Ariba, youpopulate the
"Relation Name" and "NameTableConstraintFieldPath" properties in the field's Advanced tab. This configuration links the field to a predefined relation type and specifies the constraint field used for filtering.
Simply loading relation types (B) is a prerequisite but does not configure filtering on the field itself. Visibility conditions (C) control whether a field is shown, not the filtering of its values. Enabling "Use relationship chooser" (D) is necessary but insufficient alone without defining the relation and constraint field. The "Enable for Template Field Setter" (E) option is unrelated to filtering.
This filtering enables dynamic picklists where options depend on another field's selection, improving data accuracy and user experience.
} #25
Custom partner bundles can be leveraged to share and apply baselines in which deployment scenario?
  • A. Bluefield
  • B. Brownfield
  • C. Grayfield
  • D. Greenfield
𰸣D
} #26
What is the recommended order off operations for creating a required Flex Master Data (FMD) type field in a project header?:
  • A.
  • B.
  • C.
  • D.
𰸣C
} #27
How can you define default values on fields?
  • A. Set as Constants or Expressions based on other field values
  • B. Default values must be manually entered by the user
  • C. Default values are not permitted
  • D. Set only for Constant values
𰸣A
} #28
ÿÿՄ Testpdf Wվ C_ACDET_2506 }ܶ˶Qٝ}Ǻܸߵģ׌S˵ SAP C֮·]֮nf¾䣬ֻǷ|L]µ C_ACDET_2506 }գٶŬǛ]õģ҂ C_ACDET_2506 }挍}}͵ąգ׌MĆλ
C_ACDET_2506}: https://www.testpdf.net/C_ACDET_2506.html
Posted at 1/28/2026 14:01:38        Only Author  2#
ҡH31-341_V2.5-ENU}ُ뤷٤ƤYһΟoϸ¥`ӥäƤޤYϤ¤ΤǤʤκϸ^뤳ȤǤޤ󲿷֤YҡH31-341_V2.5-ENUYϤŤޤʤPʤ顢ҡΟoϥץ`ɤԇȤǤޤ
Posted at 2/6/2026 13:11:55        Only Author  3#
ʂ䅢 GCP-GCX Ŀԇֿ춛]о׼}WYϣKaoGuTi ^Cһ΅ӿԇͿͨ^҂ GCP-GCX JCԇĿ}ͬĽ̌WVnjH Genesys GCP-GCX JCԇҲDz҂ӖYϣõЮaƷ_1M£ҲSrLӆ醕rg㌢õĕrg֜ʂ俼ԇ
Posted at 2/17/2026 18:07:05        Only Author  4#
Im deeply moved by your article, thank you for sharing this insight! The New C_P2W10_2504 exam prep content is of high quality and available for free.
Posted at 2/21/2026 10:52:02        Only Author  5#
This article is truly inspiring, and it has given me a new understanding of the related topic. Free CC reliable test materials exam questionsbest of luck to all exam candidates!
