1Z0-1042-25 valid training questions & 1Z0-1042-25 updated practice vce &
Posted at 1/13/2026 21:11:10
View217
Replies4
What's more, part of that ActualCollection 1Z0-1042-25 dumps now are free: https://drive.google.com/open?id=1OeRe7pdLIFdntDS3XBvC7D06uVwsgmnL
They are committed to assisting you in Oracle 1Z0-1042-25 exam preparation and boosting the 1Z0-1042-25 exam candidate's confidence to pass it. The Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam questions are designed and verified by Oracle exam trainers. They check and ensure each 1Z0-1042-25 Practice Questions are real, updated, and accurate. So rest assured that with the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) practice exams you can get success in challenging the 1Z0-1042-25 exam easily.
Under the hatchet of fast-paced development, we must always be cognizant of social long term goals and the direction of the development of science and technology. Adapt to the network society, otherwise, we will take the risk of being obsoleted. Although our 1Z0-1042-25 exam dumps have been known as one of the worlds leading providers of exam materials, you may be still suspicious of the content. For your convenience, we especially provide several demos for future reference and we promise not to charge you of any fee for those downloading. Therefore, we welcome you to download to try our 1Z0-1042-25 Exam for a small part. Then you will know whether it is suitable for you to use our 1Z0-1042-25 test questions. There are answers and questions provided to give an explicit explanation. We are sure to be at your service if you have any downloading problems.
Three Formats OF 1Z0-1042-25 Practice Material By ActualCollectionFor candidates who are going to select the 1Z0-1042-25 training materials for the exam, the pass rate for the 1Z0-1042-25 training materials is important. With pass rate reaching 98.65%, the exam dumps have reached great popularity among the candidates, and we have received many good feedbacks from the buyers. In addition, 1Z0-1042-25 Exam Materials are edited by professional experts, they possess the professional knowledge for the exam, therefore the quality can be guaranteed. We have free demo for you to have a try for 1Z0-1042-25 training materials. You can have a try before buying.
Oracle 1Z0-1042-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
| | Topic 2 | - Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OICs integration capabilities.
| | Topic 3 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
| | Topic 4 | - Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
| | Topic 5 | - Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q94-Q99):NEW QUESTION # 94
The Oracle Integration Cloud (OIC) integration design editor provides a data mapper UI tool that is available for Map actions.
Which statements are TRUE regarding the use of the Mapper tool? (Choose two.)
- A. You cannot drag and drop a source data element to a target node element that is already mapped.
- B. You cannot drag and drop an XPath function activity directly to a target node element.
- C. You cannot drag and drop an XSLT flow control statement directly to a target node element.
- D. You can drag and drop a source data element to multiple target node elements.
The Mapper tool allows flexibility in mapping, including mapping one source element to multiple target elements. XSLT flow control statements (e.g., xsl
, xsl
) cannot be directly dragged to target elements.
NEW QUESTION # 95
Your organization maintains two SOA cloud service instances used separately for testing and production. What is the best practice for defining the property values and endpoint addresses unique to each environment when deploying the same SOA composite application archive to both instances?
- A. You cannot deploy the same archive to two different environments. Define the specific properties and endpoint addresses statically within two separate SOA archives.
- B. Manually update any required values for unique properties or endpoint addresses in Fusion Middleware Control following deployment.
- C. Edit each application's deployment descriptor to dynamically retrieve values for properties and endpoint addresses from the environment upon deployment.
- D. Create two separate configuration plans that contain the environment-specific values and then associate the appropriate plan with the SOA archive deployment.
Creating two separate configuration plans for each environment is the best practice. This keeps environment-specific details separate from the SOA archive and promotes reusability and maintainability. Other methods are error-prone or inefficient.
NEW QUESTION # 96
Which Oracle Integration (OIC) XPath function can be used to retrieve data from an OIC Lookup within the Map Editor?
- A. getLookup
- B. get-value-from-lookup
- C. lookupValue
- D. get-content-as-string
XPath in Mapper:
D:True-lookupValue retrieves lookup data.
NEW QUESTION # 97
You are creating integrations in Oracle Integration Cloud (OIC) using B2B trading partner agreements. Which identifier is implicitly used for all outbound agreements?
- A. EDI Interchange ID
- B. Application Partner ID
- C. EDI Interchange Internal Sub ID
- D. EDI Group ID Qualifier
In OIC B2B, outbound agreements use theEDI Interchange ID (B)as the implicit identifier. This ID, part of the EDI header, uniquely identifies the sender in transactions (e.g., X12 or EDIFACT standards).
Option A:Internal Sub ID is a secondary identifier, not implicit for all outbound flows.
Option C:Application Partner ID is specific to application-level config, not EDI.
Option D:Group ID Qualifier defines document grouping, not the primary outbound identifier.
The Interchange ID ensures consistency in B2B communication.
NEW QUESTION # 98
Which Oracle Integration Cloud (OIC) service role does NOT have permission to run an OIC integration flow?
- A. ServiceAdministrator
- B. ServiceInvoker
- C. ServiceUser
- D. ServiceDeveloper
The ServiceInvoker role is primarily designed for invoking integrations programmatically via REST/SOAP APIs and cannot manually run integrations from the OIC console.
NEW QUESTION # 99
If you also need to take the 1Z0-1042-25 exam and want to get the related certification, you can directly select our study materials. We can promise that our 1Z0-1042-25 study question has a higher quality than other study materials in the market. If you want to keep making progress and transcending yourself, we believe that you will harvest happiness and growth. So if you buy and use the 1Z0-1042-25 test dump from our company, we believe that our study materials will make study more interesting and colorful, and it will be very easy for a lot of people to pass their exam and get the related certification if they choose our 1Z0-1042-25 Test Dump and take it into consideration seriously. Now we are willing to introduce the 1Z0-1042-25 exam reference guide from our company to you in order to let you have a deep understanding of our study materials. We believe that you will benefit a lot from our 1Z0-1042-25 study question.
1Z0-1042-25 Guaranteed Success: https://www.actualcollection.com/1Z0-1042-25-exam-questions.html
- 2026 Oracle The Best 1Z0-1042-25: Cost Effective Oracle Cloud Infrastructure 2025 Application Integration Professional Dumps 🤒 Search for ▛ 1Z0-1042-25 ▟ and download exam materials for free through [ [url]www.examcollectionpass.com ] 📐1Z0-1042-25 Valid Test Bootcamp[/url]
- 2026 Oracle The Best 1Z0-1042-25: Cost Effective Oracle Cloud Infrastructure 2025 Application Integration Professional Dumps 🧝 Search on ➽ [url]www.pdfvce.com 🢪 for { 1Z0-1042-25 } to obtain exam materials for free download 🦧New 1Z0-1042-25 Dumps Questions[/url]
- 1Z0-1042-25 Exam Quizzes 🆘 1Z0-1042-25 New Dumps Sheet 🕣 Valid 1Z0-1042-25 Test Topics 🔲 Enter [url]www.vce4dumps.com and search for ➠ 1Z0-1042-25 🠰 to download for free 🦊Key 1Z0-1042-25 Concepts[/url]
- 1Z0-1042-25 Cheap Dumps 🐳 1Z0-1042-25 Test Assessment 📶 Free 1Z0-1042-25 Practice Exams 🚪 Easily obtain ➤ 1Z0-1042-25 ⮘ for free download through ▶ [url]www.pdfvce.com ◀ 😵Study 1Z0-1042-25 Materials[/url]
- Valid 1Z0-1042-25 Test Topics 📐 Free 1Z0-1042-25 Practice Exams 🥚 1Z0-1042-25 Reliable Dump 🚌 Open website ▷ [url]www.torrentvce.com ◁ and search for 1Z0-1042-25 for free download 🏙Valid 1Z0-1042-25 Test Topics[/url]
- Hot Cost Effective 1Z0-1042-25 Dumps 100% Pass | Reliable 1Z0-1042-25: Oracle Cloud Infrastructure 2025 Application Integration Professional 100% Pass 🩲 Download 1Z0-1042-25 for free by simply entering ✔ [url]www.pdfvce.com ️✔️ website 🤧1Z0-1042-25 Reliable Dump[/url]
- Quiz 2026 High-quality Oracle Cost Effective 1Z0-1042-25 Dumps 📠 Search for 1Z0-1042-25 on ➡ [url]www.pdfdumps.com ️⬅️ immediately to obtain a free download 🐋Test 1Z0-1042-25 Testking[/url]
- 2026 Oracle The Best 1Z0-1042-25: Cost Effective Oracle Cloud Infrastructure 2025 Application Integration Professional Dumps 🍉 Open { [url]www.pdfvce.com } and search for ▷ 1Z0-1042-25 ◁ to download exam materials for free 😻Latest 1Z0-1042-25 Test Notes[/url]
- 1Z0-1042-25 New Dumps Sheet 👾 Certification 1Z0-1042-25 Dumps 🌀 Latest 1Z0-1042-25 Test Notes 🏺 Search for { 1Z0-1042-25 } and obtain a free download on [url]www.prep4sures.top 🕢1Z0-1042-25 Latest Test Cost[/url]
- 1Z0-1042-25 Exam Quizzes 📲 1Z0-1042-25 Reliable Dump 🧵 Reliable 1Z0-1042-25 Test Cost 🐱 Open website [url]www.pdfvce.com and search for ▶ 1Z0-1042-25 ◀ for free download 📮1Z0-1042-25 Valid Test Bootcamp[/url]
- 1Z0-1042-25 Valid Test Bootcamp 🤏 1Z0-1042-25 Test Answers 🍰 Free 1Z0-1042-25 Practice Exams 🥂 Search for ✔ 1Z0-1042-25 ️✔️ on ⇛ [url]www.exam4labs.com ⇚ immediately to obtain a free download 🏉Study 1Z0-1042-25 Materials[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.quora.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, shortcourses.russellcollege.edu.au, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, forcc.mywpsite.org, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of ActualCollection 1Z0-1042-25 dumps for free: https://drive.google.com/open?id=1OeRe7pdLIFdntDS3XBvC7D06uVwsgmnL
