[General] 1z0-1033-25熱門題庫 - 1z0-1033-25測試題庫
86
【General】 1z0-1033-25熱門題庫 - 1z0-1033-25測試題庫
Posted at 1/13/2026 22:34:14      View:122 | Replies:2        Print      Only Author   [Copy Link] 1#
Oracle 1z0-1033-25 認證試題庫學習資料根據最新的知識點以及輔導資料進行整編,覆蓋面廣,蘊含了眾多最新的 Oracle 考試知識點。如果你正在準備 1z0-1033-25 考試並且像我一樣急需通過,那 1z0-1033-25 認證試題剛好可以幫助你。因為完善的 1z0-1033-25 學習資料資料覆蓋 Oracle 考試所有知識點,減少你考試的時間成本和經濟成本,助你輕松通過考試
人生充滿選擇,選擇不一定給你帶來絕對的幸福,但選擇給了你絕對的機會,而一旦錯過選擇,只能凝望。 VCESoft Oracle的1z0-1033-25考試培訓資料是每個IT人士通過IT認證必須的培訓資料,有了這份考試資料就等於手握利刃,所有的考試難題將迎刃而解。 VCESoft Oracle的1z0-1033-25考試培訓資料是針對性強,覆蓋面廣,更新快,最完整的培訓資料,有了它,所有的IT認證都不要害怕,你都會順利通過的。
1z0-1033-25測試題庫 & 1z0-1033-25考古題更新如果你仍然在努力學習為通過Oracle的1z0-1033-25考試認證,我們VCESoft為你實現你的夢想。我們為你提供Oracle的1z0-1033-25考試考古題,通過了實踐的檢驗,Oracle的1z0-1033-25教程及任何其他相關材料,最好的品質,以幫助你通過Oracle的1z0-1033-25考試認證,成為一個實力雄厚的IT專家。
最新的 Oracle CPQ Cloud 1z0-1033-25 免費考試真題 (Q70-Q75):問題 #70
Identify three types of activities that are captured in Administration logs. (Choose three.)
  • A. uploading of files in File Manager
  • B. creation of configuration objects
  • C. modification of Commerce process objects
  • D. deployment of configuration product families
  • E. migrations with the site as target
  • F. creation of data tables
答案:C,D,E
問題 #71
Which two statements about BMQL (BigMachines Query Language) are FALSE?
  • A. BMQL is a SQL-based query language.
  • B. BMQL cannot be used to update data tables.
  • C. BMQL queries can be written to fetch data from Commerce attributes.
  • D. BMQL does not support Aggregate Functions.
答案:C,D
問題 #72
To add items (parts) to a configuration, Recommended Item rules are used. Which two statements are true when using Recommended Item rules?
  • A. If multiple Recommended Item rules recommend the same item (part), the item (part) price is picked from the rule that is last in the order.
  • B. Recommended Item rules can show only the base prices defined in the customer specific module.
  • C. If multiple Recommended Item rules return the same item (part), the quantity of the item (part) is a total of all quantities returned by each rule.
  • D. Recommended Item rules can return only the base price of an item (part) and cannot use dynamic prices based off data tables.
答案:A,B
解題說明:
Reference:http://www.oracle.com/partners/e ... ner-faq-2231083.pdf
問題 #73
Your customer wants to bulk download information about Parts, Serial Numbers, and Data Tables and save it to their workstation.
What is the correct procedure to accomplish this task?
  • A. Click Download on the Admin home page, click the Parts radio button, click the Next button, choose Download Format, choose any Search criteria, and click the Download button. After the download is complete, your customer can click the Part link on the Download Status page to save the downloaded data to their workstation. This process should then be repeated for both Serial Numbers and Data Tables.
  • B. Click Download on the Admin home page, click the Parts radio button, click the Next button, choose Download Format, choose any Search criteria, and click the Download button. This process should then be repeated for both Serial Numbers and Data Tables.
  • C. Click Download on the Admin home page, click the Parts radio button, and click the Download button. After the download is complete, your customer can click the Part link on the Download Status page to save the downloaded data to their workstation. This process should then be repeated for both Serial Numbers and Data Tables.
  • D. Click Download on the Admin home page, select the Parts, Serial Numbers, and Data Tables options, click the Next button, choose Download Format, choose any Search criteria, and click the Download button. After the download is complete, your customer can click the File link on the Download Status page to save the downloaded data to their workstation.
答案:D
問題 #74
When a user clicks Save within Commerce of CPQ, the user gets the following error: "insufficient access on cross reference id." Why?
  • A. The user does not have the ability to see and edit any object in Salesforce that the user is trying to edit.
  • B. Upon installing Salesforce Managed Package, the flag "Allow Quote Creation" is not checked.
  • C. The user does not exist in Salesforce Managed Package.
  • D. The user does not have CPQ access.
答案:A
問題 #75
每每談及到 VCESoft 網站的 1z0-1033-25 考題,很多人都稱贊其出題率是很高的,讓許多人的 Oracle 證照之路沒有後顧之憂。“萬事俱備,只欠東風。”如果你沒有最新的 1z0-1033-25 考題作參照,再多的努力,是沒有用的,畢竟我們的 1z0-1033-25 考題可以作為真實考題題型的參照,讓大家順利進入了理想的單位。
1z0-1033-25測試題庫: https://www.vcesoft.com/1z0-1033-25-pdf.html
Oracle 1z0-1033-25測試題庫專業認證1z0-1033-25測試題庫專業認證要求通過4門具有壹定難度的考試,以證實在Oracle數據庫管理領域內的熟練程度:專家級技能和技術知識考試,通過這種考試之後,說明此人可以管理大型數據庫,或者能夠開發可以部署到整個企業的強大應用,1z0-1033-25是Oracle CPQ Cloud認證Oracle CPQ 2025 Implementation Professional官方考試科目,包含75道題目.為了幫助Oracle 1z0-1033-25考生順利通過考試,VCESoft考題網在10月28日進行更新,Oracle 1z0-1033-25熱門題庫 其實現在有很多方法可以幫你彌補你的知識不足的,一樣能通過IT認證考試,也許比那些專業知識相當全面的人花的時間和精力更少,正所謂條條大路通羅馬,VCESoft 1z0-1033-25測試題庫可以幫助你實現這一願望。
畢竟妖劍山每日都會派妖怪出征,自然能得到許多關於百嶺之地的1z0-1033-25情報,按道理來說楊光有真氣了,應該是可以修煉的啊,Oracle專業認證Oracle CPQ Cloud專業認證要求通過4門具有壹定難度的考試,以證實在Oracle數據庫管理領域內的熟練1z0-1033-25考古題更新程度:專家級技能和技術知識考試,通過這種考試之後,說明此人可以管理大型數據庫,或者能夠開發可以部署到整個企業的強大應用。
信任1z0-1033-25熱門題庫,獲得Oracle CPQ 2025 Implementation Professional相關信息1z0-1033-25是Oracle CPQ Cloud認證Oracle CPQ 2025 Implementation Professional官方考試科目,包含75道題目.為了幫助Oracle 1z0-1033-25考生順利通過考試,VCESoft考題網在10月28日進行更新,其實現在有很多方法可以幫你彌補你的知識不足的,一樣能通過IT認證考試,也許比那些專業知識相當全面的人花的時間和精力更少,正所謂條條大路通羅馬。
VCESoft可以幫助你實現這一願望,我們應該選擇由業內資深老師編寫的1z0-1033-25問題集,這樣所有的1z0-1033-25問題的答案的準確度才會有保障。
Posted at 2/17/2026 01:19:41        Only Author  2#
今は時間がそんなに重要な社会でもっとも少ないお時間を使ってC_TS462_2023試験に合格するのは一番よいだと思います。CertShikenが短期な訓練を提供し、一回に君のC_TS462_2023試験に合格させることができます。試験に失敗したら、全額で返金いたします。
Posted at 2/19/2026 07:20:17        Only Author  3#
I sincerely thank you for sharing; the article is truly fantastic! The New braindumps C-CPI-2506 book test was a key factor in my professional growth, and now I’m sharing it with you for free!
