[General] Latest SCA-C01 Exam Online - Real SCA-C01 Torrent
80
General Latest SCA-C01 Exam Online - Real SCA-C01 Torrent
Posted at 1/13/2026 23:42:55      View204 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of GetValidTest SCA-C01 dumps for free: https://drive.google.com/open?id=1KIqqRpH4jky825W_9GJNYs1HfS1VAga6
Test your knowledge of the SCA-C01 exam dumps with Tableau SCA-C01 practice questions. The software is designed to help with SCA-C01 exam dumps preparation. SCA-C01 practice test software can be used on devices that range from mobile devices to desktop computers. We provide the SCA-C01 Exam Questions in a variety of formats, including a web-based practice test, desktop practice exam software, and downloadable PDF files.
Tableau SCA-C01 is an industry-recognized certification exam for individuals who want to demonstrate their skills in deploying and managing Tableau Server. SCA-C01 exam is designed to test the candidate's ability to manage Tableau Server, including installation, configuration, and maintenance. Successful completion of SCA-C01 Exam demonstrates that the candidate has the skills and knowledge required to manage Tableau Server in a production environment.
SCA-C01 PDF study guide & Tableau SCA-C01 test-kingIf you are still struggling to get the Tableau SCA-C01 exam certification, GetValidTest will help you achieve your dream. GetValidTest's Tableau SCA-C01 exam training materials is the best training materials. We can provide you with a good learning platform. How do you prepare for this exam to ensure you pass the exam successfully? The answer is very simple. If you have the appropriate time to learn, then select GetValidTest's Tableau SCA-C01 Exam Training materials. With it, you will be happy and relaxed to prepare for the exam.
Tableau Server Certified Associate Exam Sample Questions (Q144-Q149):NEW QUESTION # 144
Select the correct statement that describes how to start a performance recording for a view:
  • A. Type :record_performance=yes at the end of the view URL, immediately after the session ID
  • B. Type :record_performance=yes& at the end of the view URL, immediately before the session ID
  • C. Type :record_performance=TRUE& at the end of the view URL, immediately after the session ID
  • D. Type :record_performance=TRUE& at the end of the view URL, immediately before the session ID
Link to Tableau Server documentation:
https://help.tableau.com/current ... d_create_server.htm
NEW QUESTION # 145
You install Tableau Server on a server that has four processor cores. How many instances of each Tableau Server process are installed?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Tableau Server's installer configures process instances based on hardware and deployment type (single-node vs. multi-node). For a single-node installation with 4 cores, we need to consider thedefault process topology.
Let's break this down exhaustively:
* Key Processes:
* Gateway: Handles incoming requests (1 instance).
* Application Server (VizPortal): Manages UI and sessions (1 instance).
* VizQL Server: Renders visualizations (2 instances).
* Backgrounder: Runs extract refreshes, subscriptions (1 instance).
* Data Server: Manages data connections (1 instance).
* File Store: Stores extracts (1 instance).
* Repository: Metadata database (1 instance, active).
* Cluster Controller, Cache Server, etc.: Supporting processes (typically 1 each).
* Default Configuration:
* On a single-node install, Tableau sets1 instance per processunless specified otherwise, except for VizQL, which defaults to 2.
* The installer doesn't scale instances linearly with cores (e.g., 4 cores # 4 instances). Post-install, TSM can adjust this (e.g., tsm topology set-process), but the question asks for theinstalled default
* Minimum hardware (8 cores, 32 GB RAM) suggests higher defaults, but 4 cores still triggers a minimal setup.
* Option B (1): Correct with Caveat.
* Most processes (e.g., Backgrounder, Gateway, Data Server) default to 1 instance on install, regardless of 4 cores.
* VizQL defaults to 2, but the question's phrasing ("each process") implies a general rule.
Historically (and per docs), 1 is the baseline for most, with VizQL as the exception.
* Interpretation: Assuming "each" means the typical case, 1 fits most processes on a 4-core single- node setup.
* Option A (2): Incorrect. Only VizQL defaults to 2; others don't.
* Option C (8): Incorrect. Far exceeds defaults-8 cores might justify more, but not 4.
* Option D (4): Incorrect. Not tied to core count by default; manual config would be needed.
Why This Matters: Understanding defaults aids capacity planning-4 cores is below production minimum (8), so performance tuning may be needed post-install.
NEW QUESTION # 146
Which of the following is the correct statement about site roles that can manage the licenses and site roles in Tableau Server?
  • A. Server administrators can create site role limits to set a maximum number of licenses of each type (Creator, Explorer, or Viewer) that can be consumed on a given site.
  • B. Server administrators and site administrators can create site role limits to set a maximum number of licenses of each type (Creator, Explorer, or Viewer) that can be consumed on a given site.
Link to Tableau Server documentation: https://help.tableau.com/current/server/en-us/site_role_limit.htm
NEW QUESTION # 147
You have an existing group subscription. You add a user to the group. What statement correctly describes the result?
  • A. The administrator receives a notice to approve or deny adding the user to the subscription
  • B. The subscription updates automatically to include the new user
  • C. The subscription will continue to include only the members of the group at the time the subscription was made
  • D. The creator of the subscription receives notice of the change and must manually edit the subscription to reflect the new group membership
Subscriptions in Tableau Server deliver workbook views to users via email on a schedule. Group subscriptions apply to all group members-let's unpack this:
* Group Subscription Mechanics:
* Created viaWorkbooks > Actions > Subscribe > Select Group.
* Delivers content to all users in the group at the time the subscription runs (e.g., daily PDF).
* Dynamic: Membership updates (additions/removals) are reflected automatically on the next run.
* Option C (The subscription updates automatically to include the new user): Correct.
* Details: When you add a user to the group (e.g., viaUsers > Groups > Add Users), Tableau Server's subscription process queries the group's current membership at runtime. The new user receives the subscription on the next scheduled delivery-no manual action needed.
* Example: Group "Sales" has a 9 AM subscription. Add a user at 8 AM-they get the email tomorrow at 9 AM.
* Option A (Admin receives notice to approve/deny): Incorrect.
* Why: No approval workflow exists for group membership changes in subscriptions-it's automatic.
* Option B (Creator must manually edit): Incorrect.
* Why: Subscriptions are tied to the group, not a static user list-manual edits aren't required for membership changes.
* Option D (Only members at creation time): Incorrect.
* Why: This would be true for individual subscriptions (static list), but group subscriptions are dynamic.
Why This Matters: Dynamic group subscriptions streamline content delivery as teams evolve, reducing admin overhead.
NEW QUESTION # 148
Select the correct Tableau Server monitoring tool that is being described:
* A "point-and-run" load and performance testing tool specifically designed to work easily with Tableau Server
* Used to inform scalability and capacity needs for Tableau Server
* Used to establish a baseline for server performance and test deployments before pushing them to production environments
  • A. TabJolt
  • B. TabMon
  • C. Scout
  • D. Replayer
https://help.tableau.com/current/server/en-us/perf_resources.htm
NEW QUESTION # 149
The online SCA-C01 practice exam has all specifications of the desktop software. It is compatible with Chrome, Firefox, MS Edge, Safari, Opera, etc. The Tableau Server Certified Associate Exam (SCA-C01) practice exam will save your progress and give you an overview of your mistakes, which will benefit your overall preparation. All operating systems support this Tableau Server Certified Associate Exam (SCA-C01) practice test.
Real SCA-C01 Torrent: https://www.getvalidtest.com/SCA-C01-exam.html
DOWNLOAD the newest GetValidTest SCA-C01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1KIqqRpH4jky825W_9GJNYs1HfS1VAga6
Posted at 1/19/2026 09:58:07        Only Author  2#
What a fantastic article, thank you for sharing such an amazing piece! With the L4M1 test tutorial, I achieved career growth through a promotion and salary increase. Now, its free for everyone. Best of luck!
Posted at 2/24/2026 09:00:30        Only Author  3#
Your article was so unique, thank you for sharing this fresh perspective. Free New test PEGACPRSA22V1 questions explanations available to enhance your IT expertise. Good luck!
