[General] SAP C_ACDET_2506 PDFC_ACDET_2506}d
85
General SAP C_ACDET_2506 PDFC_ACDET_2506}d
Posted at 1/14/2026 00:26:25      View301 | Replies4        Print      Only Author   [Copy Link] 1#
Fast2test SAPC_ACDET_2506ԇӖYϵõVķQuѽˣfFast2test SAPC_ACDET_2506ԇӖYŵ^_ԎVͨ^ԇ׌]֮nFast2test SAPC_ACDET_2506ԇӖYϕNͬһֱbbIȣȵõVMߵJɣڱȻfҪ SAPC_ACDET_2506ԇsoMFast2test@WվһõҪģe^ͲڣɞI˲ĿITңǾsoُ܇ɡ
Ҫͨ^C_ACDET_2506JCԇKǃHHcԇPĕͿkġcäĿ،WԇҪP֪RһЩЃrֵԇ}һЧʵĿ}ǴҜʂ俼ԇrزٵĹߡԣcُIFast2testC_ACDET_2506}ɡ@һʺܸߵĿ}κΌWЧǿԱ֤һξͳɹѵõϡ
C_ACDET_2506}d & C_ACDET_2506ԇcFast2testLԁһֱṩcSAPJCԇPC_ACDET_2506Y@һVz^ľWվṩõĿԇ}Fast2testȫ汣C棬õ˴ҵһºuңFast2testҲǮǰЈֵهľWվ
µ SAP Certified Associate C_ACDET_2506 Mԇ} (Q44-Q49):} #44
You want to apply a preset filter to a custom field so that it only shows valid values based on the value of another field. What do you use to apply predefined filter criteria for a field?
  • A. Enable field property "Use relationship chooser" in the Advanced tab
  • B. Load Relation types and Relation entries
  • C. Populate the "Relation Name" and "NameTableConstraintFieldPath" in the Advanced tab
  • D. Enable field property "Enable for Template Field Setter" in the Advanced tab
  • E. Define a Visibility Condition in the Conditions tab
𰸣C
} #45
𰸣C
}f
To filter a custom field's available values based on another field's value in SAP Ariba, youpopulate the
"Relation Name" and "NameTableConstraintFieldPath" properties in the field's Advanced tab. This configuration links the field to a predefined relation type and specifies the constraint field used for filtering.
Simply loading relation types (B) is a prerequisite but does not configure filtering on the field itself. Visibility conditions (C) control whether a field is shown, not the filtering of its values. Enabling "Use relationship chooser" (D) is necessary but insufficient alone without defining the relation and constraint field. The "Enable for Template Field Setter" (E) option is unrelated to filtering.
This filtering enables dynamic picklists where options depend on another field's selection, improving data accuracy and user experience.
} #46
When performing migration to production for a greenfield customer, which item needs to be made available in production prior to creating the migration in ICM?
  • A. Approval Rules
  • B. Locations
  • C. Users
  • D. Translations
𰸣C
} #47
You need to revise a published form template. What steps do you follow?
  • A. Create a new version, edit, test, and publish
  • B. Clone and change ID
  • C. Edit directly in production
  • D. Delete and recreate
𰸣A
}f
SAP Ariba requires that revisions to published form templates be handled throughcreating a new version of the template, then editing and testing the draft version before publishing it. The system maintains the prior published version active while you work on the new draft, ensuring no disruption. Cloning and changing IDs is unnecessary and not best practice. Direct edits on published templates are not permitted, and deleting and recreating loses version history and control. This versioning mechanism supports safe, auditable template changes.
} #48
While migrating form templates, you successfully exported all templates from the Test site.
However, when trying to import them into Production, you cannot find the correct folder.
What should you do to proceed without errors?
  • A. Skip the import and inform the team the templates cannot be migrated.
  • B. Modify the form template files locally to bypass folder restrictions.
  • C. Upload the templates to any existing folder regardless of its purpose.
  • D. Manually create the required folder in the Production site before importing
𰸣D
} #49
ԓЩ挍ŵ}ṩC_ACDET_2506}Yϣ@ӌͨ^ԇǸŶȸߵSAP C_ACDET_2506}Ɏͨ^JCԇFast2test˾@ֵهxC_ACDET_2506}Yеÿ}҂IˆTz錏ˣ鿼ṩƷ|Ŀ}ϣڶ̕rgȫ@SAP C_ACDET_2506JChҲFast2testõĮaƷˡ
C_ACDET_2506}d: https://tw.fast2test.com/C_ACDET_2506-premium-file.html
ڻ“WҲԿׂҲṩPӖľWվ^֮ᣬ͕lFFast2testPSAP C_ACDET_2506 JCԇӖ^ᘌԣHƷ|ߵģ҃ȫģ䌍Ԓȡʩһͨ^JCFast2test SAPC_ACDET_2506ԇ}ӖYǂex񣬱վ̓MľW·Ӗʹn̰ゃҪĿ}ȫ׌ゃͨ^JCxFast2test㲻Hͨ^SAP C_ACDET_2506JCԇ߀Fast2testṩһM·գSAP C_ACDET_2506SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite濼ԇĿFast2test C_ACDET_2506}dṩ@ЩᘌԵӖͨ^Pԇ׵öࡣ
Լ]ץFУܟoʰlйɣ¾Ǟ˫Iħڻ“WҲԿׂҲṩPӖľWվ^֮ᣬ͕lFFast2testPSAP C_ACDET_2506 JCԇӖ^ᘌԣHƷ|ߵģ҃ȫġ
ʹSAP C_ACDET_2506 PDFpɵͨ^SAP C_ACDET_2506ԇ䌍Ԓȡʩһͨ^JCFast2test SAPC_ACDET_2506ԇ}ӖYǂex񣬱վ̓MľW·Ӗʹn̰ゃҪĿ}ȫ׌ゃͨ^JCxFast2test㲻Hͨ^SAP C_ACDET_2506JCԇ߀Fast2testṩһM·ա
SAP C_ACDET_2506SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite濼ԇĿFast2testṩ@ЩᘌԵӖͨ^Pԇ׵öࡣ
Posted at 1/15/2026 16:40:43        Only Author  2#
The article is truly moving, thank you for sharing! Wishing you all the best on your exams! Free SPI guaranteed passing questions available now!
Posted at 2/20/2026 07:18:34        Only Author  3#
hΤShikenPASSˤ륳Х`ǤȫƤSalesforceNP-Con-102Salesforce Certified Nonprofit Cloud Consultant (NPC)ԇYϷdz˴ФǤg٤˰kչƤrˡShikenPASSϤФһĤǤǤϤʤۤȤɤˡShikenPASSxΤǤShikenPASSṩ놖}YϤϽ~ʤԇYܤ뤳Ȥ뤫ǤShikenPASSṩYϤ¤Υȥ`˥󥰥ĩ`뤬˥åץǩ`ȤJ^ԇYĿˤQνYǤShikenPASS Ϥʤ¤ԇYоYϤṩޤ顢ShikenPASS SalesforceNP-Con-102}֤äƤ顢ԇYֱ椹Ť˜뤳ȤǤϸ񤷤ʤʤȫȻ䤹뤳ȤϤʤݘSԇYܤ뤳ȤǤޤ
Posted at 3/7/2026 10:09:35        Only Author  4#
The article is really inspiring; thank you for sharing! The content in C_BCBDC_2505 latest practice exam fee is rich and free, available to aid you in your learning journey.
Posted at 4/19/2026 13:32:24        Only Author  5#
Your article was absolutely enlightening, thank you! CSC2 exam sims provides great resources, and they are completely free.
