[Linux] compile ubuntu 18.04
56
Linux compile ubuntu 18.04
Posted at 9/1/2022 14:17:44      View3671 | Replies5        Print      Only Author   [Copy Link] 1#
Hello,I have some problems with compiling firmware on AIO-3568J board. I'm using AIO-3568J_Ubuntu18.04-MLU220-r21199_v1.3.0a_220817 firmware taken from google drive link from https://en.t-firefly.com/doc/download/89.html. I'm use this manual https://wiki.t-firefly.com/en/Core-3568J/index.html and at "Compile Ubuntu firmware" step introduction link "Firefly Ubuntu User Manual" (https://wiki.t-firefly.com/en/Core-3568J/ubuntu_manual ;  Not Found. The requested URL /en/Core-3568J/ubuntu_manual was not found on this server.)  doesn't work. Besides i have problems with Ethernet connection. May be its because i have not install any drivers for this, but i haven't such folders and files like at https://wiki.t-firefly.com/en/Core-3568J/driver_ethernet.html# .
Posted at 9/2/2022 11:55:15        Only Author  2#
The "Firefly Ubuntu User Manual" is here now. WiKi-> Firefly Linux User Guide -> Ubuntu manual
https://wiki.t-firefly.com/en/Fi ... /manual_ubuntu.html
Maybe you don't have sync code yet.
https://wiki.t-firefly.com/en/Co ... inux.html#sync-code
The gitlab: https://gitlab.com/firefly-linux ... 8-firefly-port.dtsi
Posted at 9/5/2022 14:59:45        Only Author  3#
ʱĺ Posted at 9/2/2022 11:55
http ...
Thank you for the answer. Now have another problem. At step 2.2.4 of https://wiki.t-firefly.com/en/Co ... tomatic-compilation have error:
ERROR: No configs/firefly_rk3568_defconfig
ERROR: Running build_uboot failed!
ERROR: exit code 1 from line 643:
         ./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
I have .BoardConfig.mk same as 2.2.1 (Configuration content) (https://wiki.t-firefly.com/en/Co ... mpile-configuration)
Partial compilation have same error for u-boot.
For build kernel:
sudo ./build.sh extboot  (Because I have Linux SDK v1.3.0)
ERROR: Running build_extboot  failed!
ERROR: exit code 2 from line 775:
         make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j $RK_JOBS
May be i haven't some files, but i don't know where take them.
Posted at 9/7/2022 14:37:56        Only Author  4#
Suhach Posted at 9/5/2022 14:59
Thank you for the answer. Now have another problem. At step 2.2.4 of https://wiki.t-firefly.com/en ...
I'm afraid your configuration file has changed. Do not change the files in the device/rockchip/ repository.
'ERROR: No configs/firefly_rk3568_defconfig'
In fact, uboot's configuration file is `u-boot/configs/firefly-rk3568_defconfig`.
1Prestige +10 Money +11 Contribution +12 Pack up reason
Suhach + 10 + 11 + 12 ܸ!
View all ratings
Posted at 1/25/2026 11:25:58        Only Author  5#
Your article was incredibly refreshing, I really appreciate it. Exam FCSS_SDW_AR-7.6 simulator fee offers rich material, available for free to support your learning goals.
Posted at 1/29/2026 16:48:58        Only Author  6#
The article gave me a whole new outlook on things. The QSSA2021 test tutorial test led to my promotion and salary increase. Today, Im giving it away for free to help you too!
