New Topic
[Linux] CONFIG_NETFILTER_XT_MATCH_COMMENT not set
19
Linux CONFIG_NETFILTER_XT_MATCH_COMMENT not set
Posted at 9/5/2022 11:11:17      View7469 | Replies16        Print      Only Author   [Copy Link] 1#
because CONFIG_NETFILTER_XT_MATCH_COMMENT is not set, iptables can't use -m comment, k3s faild to set iptables rules. so I need to compile a custom kernel
1. make -j 8   will get a vmlinux, but It's size is 300MB+ /boot space is only 232MB
then how to solve this problem?
Posted at 9/5/2022 11:17:33        Only Author  2#
I'm using linux-5.10.66.tar.gz download from kernel.org, maybe I should use sdk provided by firefly?
Posted at 9/5/2022 14:47:34        Only Author  3#
# strip ./vmlinux solved this problem
Posted at 8/22/2024 12:26:45        Only Author  4#
The linux-5.10.66.tar.gz file is available on kernel.org; however, Firefly provides an SDK that I might want to try out instead.
Posted at 1/13/2025 15:06:54        Only Author  5#
Building unnecessary kernel Worldle features directly into the kernel increases its size.
Posted at 2/11/2025 09:44:10        Only Author  6#
Before compiling the soccer random kernel, you need to install the necessary packages:
sudo apt update
sudo apt install build-essential libncurses-dev bison flex libssl-dev libelf-dev
(If using CentOS/RHEL, run sudo yum groupinstall "Development Tools" and install ncurses-devel, bison, flex, elfutils-libelf-devel.)
Posted at 2/26/2025 11:23:21        Only Author  7#
Enable kernel compression (gzip/xz), remove unnecessary modules via menuconfig, or use objcopy --strip-debug to reduce size.
Chill Guys Clicker
Posted at 3/25/2025 12:11:51        Only Author  8#
The actual files installed to /boot are typically vmlinuz (compressed kernel), System.map, and initramfs, which are much smaller. However, even these might exceed your 232MB free space if /boot already has old kernels or large files.
sprunki retake
Posted at 4/15/2025 22:23:44        Only Author  9#
World Guesser is an excellent educational and entertaining tool. For those who enjoy traveling to new places, this game is ideal.
Posted at 4/23/2025 12:02:55        Only Author  10#
Get ready to swing for the fences in Baseball Bros IO - a lightning-fast, cartoon-style multiplayer baseball game that blends strategy, speed, and pure fun.
Return to List
12
