[General] Device doesn't enter MaskRom upgrade mode
56
General Device doesn't enter MaskRom upgrade mode
Posted at 9/6/2022 21:36:36      View31636 | Replies8        Print      Only Author   [Copy Link] 1#
I'm use AIO-3568J and have 2 Core-3568J core boards. One of them works normally, but second is bricked. I tried to enter bricked one in MaskRom mode using this manual https://wiki.t-firefly.com/en/Core-3568J/04-maskrom_mode.html , but device don't enter MaskRom mode (RKDevTool still writing "No Devices found"). So i tried enter Maskrom mode on working one, but it doesn't enter MaskRom mode too. All wires were tested with multimeter. I use original USB data cable and power supply from standart package. All drivers installed on PC by DriverAssistant. Have you any ideas about this issue?
Posted at 9/7/2022 11:20:03        Only Author  2#
the wiki is not very articulate
First connect the usb cable, then short two test points on core board and hold it, then connect the power
After few seconds, stop shorting the test points, then see if RKDevTool is reporting a maskrom device.
1Prestige +7 Money +7 Contribution +7 Pack up reason
Suhach + 7 + 7 + 7 ܸ!
View all ratings
Posted at 9/7/2022 13:42:02        Only Author  3#
Liuth Posted at 9/7/2022 11:20
First connect the usb cable, then short two test points on core boa ...
Thank you for the answer. It helped a lot
Posted at 1/8/2026 16:34:29        Only Author  4#
This is such an uplifting article, thanks for sharing! Im about to take the Reliable DA0-002 braindumps book exam. Wish me good fortune!
Posted at 1/10/2026 17:38:02        Only Author  5#
Trotzdem sagen viele Menschen, dass das Ergebniss nicht wichtig und der Prozess am allerwichtigsten ist. Aber diese Darstellung passt nicht in der Microsoft AZ-140 Prfung, denn die Zertifizierung der Microsoft AZ-140 können Ihnen im Arbeitsleben in der IT-Branche echte Vorteile mitbringen. Wenn Sie Entschluss haben, die Prfung zu bestehen, dann sollten Sie unsere Microsoft AZ-140 Prfungssoftware benutzen wegen ihrer anspruchsvollen Garantie. Wenn Sie noch zögern, können Sie zuerst unsere kostenlose Demo der Microsoft AZ-140 probieren. Dadurch werden Sie empfinden die Konfidenz frs Bestehen, die wir It-Pruefung Ihnen mitbringen!
Posted at 1/23/2026 18:09:10        Only Author  6#
Um die HITRUST CCSFP Zertifizierungsprfung zu bestehen, wählen Sie doch unseren Fast2test. Sie werden sicher nicht bereuen, dass Sie mit so wenigem Geld die Prfung bestehen können. Unser Fast2test wird Ihnen helfen, sich auf die Prfung gut vorzubereiten und die HITRUST CCSFP Zertifizierungsprfung (Certified CSF Practitioner 2025 Exam) erfolgreich zu bestehen. Außerdem bieten wir Ihnen kostenlos einen einjährigen Update-Service.
Posted at 1/26/2026 08:16:29        Only Author  7#
Im all in on this content, hitting like right away. Sharing free New C-P2WFI-2023 test cram pdf study materials. Wishing you the best of luck!
Posted at 2/6/2026 07:10:44        Only Author  8#
ڤʤ褦ˤä٤ʤʹäƴ󤭤ɹȡä뤿JpexamxkƤJpexamPMI-PMOCPԇY}һg˟oϤʥ`ӥ¤ޤ
Posted at 2/17/2026 01:46:50        Only Author  9#
enjoyed reading through the discussion in this thread its helpful to see how people are sharing experiences and tips, especially when tackling similar questions or challenges. Threads like this make it easier to learn from others perspectives. When I take a short break from reading forum posts like this, I sometimes switch gears with a quick creative pause on Fargeleggingssider.com to relax my mind before diving back into the conversation. Thanks for the useful insights!
