Online 1Z0-1072-25 Tests | 1Z0-1072-25 Prepaway Dumps
89
Posted at 1/14/2026 07:11:55      View151 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest VCEEngine 1Z0-1072-25 PDF Dumps and 1Z0-1072-25 Exam Engine Free Share: https://drive.google.com/open?id=1ByGQyOE4R_s5TPxzSXnAco0zr3r4_ixJ
Our 1Z0-1072-25 exam questions have three versions: the PDF, Software and APP online. Also, there will have no extra restrictions to your learning because different versions have different merits. All in all, you will not be forced to buy all versions of our 1Z0-1072-25 Study Materials. You have the final right to select. Please consider our 1Z0-1072-25 learning quiz carefully and you will get a beautiful future with its help.
Oracle 1Z0-1072-25 Exam Syllabus Topics:
  • Identity and Access Management (IAM): This domain validates skills of security architects implementing granular access controls, emphasizing IAM policy creation, compartment organization, and dynamic group configuration. It covers identity domain management, network source restrictions, and tag-based access mechanisms to enforce least-privilege principles across OCI resources
  • Compute: This section measures skills of cloud architects responsible for designing scalable and resilient infrastructure, covering compute instance configuration, autoscaling policies, and OS management. It evaluates understanding of OCI compute image options, infrastructure maintenance processes, and strategies for optimizing instance performance across availability domains.
  • Storage: Designed for storage administrators managing enterprise data solutions, this section tests proficiency in deploying Block
  • File
  • Object Storage with lifecycle management, cross-region replication, and tiered storage strategies. It includes configuring volume groups, snapshots, versioning, and security controls while analyzing storage performance metrics and cost optimization techniques.
  • Networking: Targeting network architects designing secure cloud architectures, this domain focuses on Virtual Cloud Network (VCN) implementation, including subnet design, IP address management, and routing through gateways (NAT, service, internet). It assesses expertise in VPN
  • FastConnect deployment, DNS configuration, load balancer setup, and advanced tools like Network Path Analyzer for troubleshooting latency or connectivity issues.
Three formats of Oracle 1Z0-1072-25 practice exams meet the diverse needsOur 1Z0-1072-25 practice tests have established impressive recognition throughout the industry, diversified modes of learning enables the 1Z0-1072-25 exam candidates to capture at the real exam scenario. Tremendous quality of our 1Z0-1072-25 products makes the admirable among the professionals. Our practice tests are on demand, attending the needs of 1Z0-1072-25 Exams more comprehensively and dynamically as well. Lift up your learning tendency with VCEEngine practice tests training. Conceptual understanding matters the most for your success, technical excellence is certain with VCEEngine training as our experts keep it on high priority.
Oracle Cloud Infrastructure 2025 Architect Associate Sample Questions (Q13-Q18):NEW QUESTION # 13
Which statement is true about instance configurations and instance pools in OCI?
  • A. You can delete an instance configuration if it is associated with an instance pool.
  • B. An instance pool can have multiple instance configurations associated with it.
  • C. You cannot reuse the same instance configuration for multiple instance pools.
  • D. You can only delete an instance configuration if it is not associated with any instance pool.
NEW QUESTION # 14
By default, OCI IAM policies follow the principle of least privilege. What does this principle mean in the context of policy creation?
  • A. Policies should grant all possible permissions to simplify access control.
  • B. Policies should be written in a complex and technical manner to enhance security.
  • C. Policies should be identical for all users within a tenancy.
  • D. Policies should provide only the minimum set of permissions required for users to perform their tasks effectively.
The principle of least privilege is a security best practice that dictates that users should only be granted the minimum set of permissions necessary to perform their tasks. This principle helps to minimize the risk of accidental or malicious actions that could compromise security.
IAM Policies in OCI: When creating IAM policies in OCI, you should carefully evaluate the required permissions and only grant those that are absolutely necessary for the users or groups to perform their specific roles. This helps to reduce the attack surface and prevent unauthorized access to sensitive resources.
Oracle Cloud Infrastructure Documentation: Identity and Access Management (IAM) Best Practices
NEW QUESTION # 15
A financial firm is designing an application architecture for its online trading platform that should have high availability and fault tolerance. What should the architect do to avoid any costly service disruptions and ensure data durability?
  • A. Create a lifecycle policy to regularly send data from the Standard to Archive storage.
  • B. Copy the Object Storage bucket to a block volume.
  • C. Create a replication policy to send data to a different bucket in another OCI region.
  • D. Create a new Object Storage bucket in another region and configure recycle policy to move data every 5 days.
For an online trading platform requiring high availability and fault tolerance, it's critical to ensure data durability and avoid any costly service disruptions. In Oracle Cloud Infrastructure (OCI), Object Storage is often used to store critical data, such as transaction logs or user data, due to its scalability, durability, and reliability.
Option B is the most suitable approach for ensuring data durability and availability across regions. Here's why:
Cross-Region Replication (CRR): OCI offers a feature called Cross-Region Replication for Object Storage. This feature allows you to automatically and asynchronously replicate objects in a bucket from one OCI region to another. This setup ensures that even if one region experiences a failure, the data is still available in another region, thereby meeting the requirements for high availability and fault tolerance.
Data Durability: By replicating data to another region, you protect against regional outages. OCI guarantees 99.95% availability for replicated data, which is critical for a financial firm's trading platform where data consistency and durability are paramount.
Disaster Recovery: With data replicated in another region, the trading platform can quickly switch to using the data in the secondary region in case of a disaster in the primary region. This setup significantly reduces recovery time objectives (RTO) and ensures business continuity.
Oracle Cloud Infrastructure Documentation: Cross-Region Replication for Object Storage Oracle Whitepaper: High Availability and Disaster Recovery in Oracle Cloud Infrastructure Explanation of Incorrect Options:
Option A: Creating a new Object Storage bucket in another region and configuring a recycle policy to move data every 5 days does not provide real-time data availability or the fault tolerance required for a financial application. Recycle policies are intended for managing the lifecycle of data, not for high availability or disaster recovery.
Option C: While lifecycle policies are useful for moving less frequently accessed data to a more cost-effective storage tier (e.g., from Standard to Archive), they do not address cross-region redundancy or real-time availability, which are critical for this use case.
Option D: Copying an Object Storage bucket to a block volume is not a recommended practice for ensuring data durability and fault tolerance. Block volumes are used for persistent storage attached to compute instances, and copying object storage data to block volumes does not achieve the same level of redundancy and cross-region availability as replication policies.
Thus, Option B is the correct and most efficient method for ensuring high availability and fault tolerance in this scenario.
NEW QUESTION # 16
Which statement is TRUE about delegating an existing domain to the Oracle Cloud Infrastructure (OCI) DNS service?
  • A. All domains can be retrieved to OCI DNS via DYN.
  • B. Domains can be delegated to OCI DNS from the Domain Registrar's self-service portal.
  • C. Domains can be self-delegated to OCI DNS from its own service portal.
  • D. Domains can be delegated to OCI DNS via FastConnect partners.
To delegate a domain to the Oracle Cloud Infrastructure (OCI) DNS service, the domain needs to be pointed to OCI's DNS servers. This can be done through the Domain Registrar's self-service portal, where you update the name servers for your domain to OCI's DNS servers.
Process: You typically log into the domain registrar where your domain is registered and replace the existing name servers with the name servers provided by OCI DNS. Once this is done, DNS queries for your domain will be directed to OCI DNS.
Oracle Cloud Infrastructure Documentation: Managing DNS Zones
NEW QUESTION # 17
Which statement is NOT correct regarding the Oracle Cloud Infrastructure (OCI) File System snapshots?
  • A. Snapshots are accessible under the root directory of the file system at .snapshot/name.
  • B. Even if nothing has changed within the file system since the last snapshot was taken, a new snapshot consumes more storage.
  • C. Snapshots are a consistent, point-in-time view of your file systems.
  • D. Before you can clone a file system, at least one snapshot must exist for the file system.
In OCI File Storage, snapshots are point-in-time, read-only copies of a file system that do not immediately consume additional storage beyond the space needed to track changes.
Incorrect Statement: The statement that a new snapshot consumes more storage even if nothing has changed is incorrect. Snapshots are space-efficient; they only consume additional storage as changes are made to the file system after the snapshot is taken. If no changes are made between snapshots, the storage consumption remains minimal.
Correct Statements:
B . Before cloning a file system, at least one snapshot must exist, as the clone operation relies on this snapshot to create a copy.
C . Snapshots are accessible under the .snapshot directory, allowing users to view and restore files from specific snapshots.
D . Snapshots provide a consistent, point-in-time view of the file system, ensuring data integrity.
Oracle Cloud Infrastructure Documentation: Managing File System Snapshots
NEW QUESTION # 18
We stress the primacy of customers interests, and make all the preoccupation based on your needs. We assume all the responsibilities our practice materials may bring. They are a bunch of courteous staff waiting for offering help 24/7. You can definitely contact them when getting any questions related with our 1Z0-1072-25 practice materials. If you haplessly fail the exam, we treat it as our blame then give back full refund and get other version of practice material for free.
1Z0-1072-25 Prepaway Dumps: https://www.vceengine.com/1Z0-1072-25-vce-test-engine.html
BTW, DOWNLOAD part of VCEEngine 1Z0-1072-25 dumps from Cloud Storage: https://drive.google.com/open?id=1ByGQyOE4R_s5TPxzSXnAco0zr3r4_ixJ
Posted at 1/15/2026 07:03:05        Only Author  2#
Im loving thislike, here it comes. The Reliable CIPT test experience content is amazing, and you can get it for free.
Posted at 2/1/2026 13:39:46        Only Author  3#
This article has provided great inspiration, thank you! Thanks to the Latest test Workday-Pro-Compensation camp materials, I achieved a promotion and salary boost. Now its free for all. Best wishes in reaching your career goals!
