[Hardware] Particular signals for Core-3588j SoM
24
Hardware Particular signals for Core-3588j SoM
Posted at 9/15/2022 04:09:20      View3929 | Replies1        Print      Only Author   [Copy Link] 1#
Hello everyone!
I am going to make a custom motherboard with this SoM Core-3588J,
and I found than the description of some signals at Specifcation is not so clear for me.
They are:
30 PWRON_L PWRON_L RK806-1 POWER EN, Active L 5V
32 VDC_EXT VDC_EXT RK806-1 VDC IN(DC IN Auto Power ON 3~5V
34 PMIC_EXT_EN_OUT PMIC_EXT_EN_OUT PMIC_EXT_EN_OUTPUT, Active H 5V
36 VCCA_RK806 VCC_5V_S PMIC Power supply of PLDO6 and system 5V
As for signal 30 PWRON_L PWRON_L RK806-1 POWER EN, Active L 5V , I understand more or less ok that this signal is used for POWER ON the SOM module, except that the signal into 5 volt domain, but the rest is a little bit enigma for me.
I was wondering if anybody could explain the meaning of each signal for me, include the power domain of 5 volts.
Thans a lot.
restricted members
Posted at 1/20/2026 15:08:16        Only Author  2#
Your article is truly amazing, thank you for sharing! I received a promotion and raise thanks to the Reliable exam Workday-Pro-Talent-and-Performance passing score. Now its free for everyone. Wishing you success in your career!
