[Linux] GPU drivers missing vulkan support
29
Linux GPU drivers missing vulkan support
Posted at 9/15/2022 19:10:03      View6951 | Replies6        Print      Only Author   [Copy Link] 1#
Dear Firefly
I'm attempting to test the RK3588 Mali GPU using vulkan API on Ubuntu 20.04 LTS using Firefly Linux SDK, but the vulkan ICD loader is failing. By investigation I find no vulkan symbols in the libmali library provided by Firefly (git.t-firefly.com:8022/rk-linux/external/libmali)
$ grep vk_icd libmali-valhall-g610-g6p0-*
#no match
Example from other drivers (this is Odroid N2+ userspace from arm.com)
$ grep vk_icd libmali.so.0.39.0
grep: libmali.so.0.39.0: Binary file matches
Please recompile/update your Mali-G610 GPU libmali userspace drivers with vulkan support enabled. It is a vital feature.
Thank you
super moderator
Rank: 8Rank: 8
Posted at 9/16/2022 11:48:39        Only Author  2#
Please provide the log of the failure of the vulkan ICD loader.
Posted at 9/17/2022 00:59:52        Only Author  3#
$ vulkaninfo
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Attempt to retrieve either 'vkGetInstanceProcAddr' or 'vk_icdGetInstanceProcAddr' from ICD libmali.so failed.
Cannot create Vulkan instance.
This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.
/build/vulkan-tools-_ynL0i/vulkan-tools-1.2.131.1+dfsg1/vulkaninfo/vulkaninfo.h:371: failed with ERROR_INCOMPATIBLE_DRIVER
So the vulkan ICD loader is looking for specific vk* symbols in the GPU userspace library, but they are not there. I have checked all the relevant libraries and they are completely missing. So the problem is not the loader but the GPU driver libraries. The libmali libraries have not been compiled with vulkan support enabled.
Posted at 3/11/2025 12:16:01        Only Author  4#
I also encountered the same error. And I solved it. You can read more information at GunSpin site.
Posted at 4/10/2025 12:18:29        Only Author  5#
Hopefully, Firefly will update lib mali to support Vulkan soon, as this is an essential feature for anyone agario who wants to get the most out of the GPU power on the RK3588
Posted at 2/1/2026 02:39:16        Only Author  6#
Im thankful for your article, it made a lasting impression. Here are the free JN0-336 exam sample online materials! Best of luck to everyone!
Posted at 2/22/2026 22:24:54        Only Author  7#
Viele IT-Leute sind sich einig, dass Peoplecert ITIL-4-CDS Zertifikat ein Sprungbrett zu dem Höhepunkt der IT-Branche ist. Deshalb kmmern sich viele IT-Experten um die Peoplecert ITIL-4-CDS Zertifizierungsprfung.
