JN0-664 exam guide: Service Provider, Professional (JNCIP-SP) & JN0-664 actu
Posted at 1/14/2026 12:10:26
BTW, DOWNLOAD part of Pass4suresVCE JN0-664 dumps from Cloud Storage: https://drive.google.com/open?id=1xiBIR9_1QeG14OCh7xg1SMqrVYWyyAr2
We have three different versions of our JN0-664 exam questions which can cater to different needs of our customers. They are the versions: PDF, Software and APP online. The PDF version of our JN0-664 exam simulation can be printed out, suitable for you who like to take notes, your unique notes may make you more profound. The Software version of our JN0-664 Study Materials can simulate the real exam. Adn the APP online version can be applied to all electronic devices.
The JN0-664 Exam covers a wide range of topics related to service provider routing and switching technologies, including Border Gateway Protocol (BGP), Intermediate System to Intermediate System (IS-IS), Routing Information Protocol (RIP), and Open Shortest Path First (OSPF). Additionally, the exam also covers advanced topics such as multicast, MPLS, and layer 2 VPNs.
JN0-664 Exam Exam Lab Questions- Realistic JN0-664 PDF Questions Pass SuccessThe Pass4suresVCE is one of the top-rated and reliable platforms that has been helping the Juniper JN0-664 exam candidates for many years. Over this long time period, countless JN0-664 exam candidates have passed their Juniper exam with good scores. In their success one thing is common and that is the usage of Pass4suresVCE JN0-664 Exam Practice test questions.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q93-Q98):NEW QUESTION # 93
Which three mechanisms are used by Junos platforms to evaluate incoming traffic for CoS purposes? (Choose three )
- A. traffic shapers
- B. rewrite rules
- C. behavior aggregate classifiers
- D. fixed classifiers
- E. multifield classifiers
Answer: C,D,E
Junos platforms use different mechanisms to evaluate incoming traffic for CoS purposes, such as:
* Behavior aggregate classifiers: These classifiers use a single field in a packet header to classify traffic into different forwarding classes and loss priorities based on predefined or user-defined values.
* Fixed classifiers: These classifiers use a fixed field in a packet header to classify traffic into different forwarding classes and loss priorities based on predefined values.
* Multifield classifiers: These classifiers use multiple fields in a packet header to classify traffic into different forwarding classes and loss priorities based on user-defined values and filters.
Rewrite rules and traffic shapers are not used to evaluate incoming traffic for CoS purposes, but rather to modify or shape outgoing traffic based on CoS policies.
NEW QUESTION # 94
Exhibit
You are examining an L3VPN route that includes the information shown in the exhibit Which statement is correct in this scenario?
- A. The information shows a Type 1 route distinguisher.
- B. The information shows a route target
- C. The information shows a Type 0 route distinguisher
- D. The information shows a Type 2 route distinguisher.
Type 1: When Type value is 1, the Administrator field is 4-bytes and Assigned Number field is 2-bytes. The Administrator field should be set to the IP address (public IP addresses should be used). The Assigned Number field contains a number from a numbering space that is administered by the enterprise to which the IP address has been assigned by the appropriate authority.
NEW QUESTION # 95
Which two statements are correct about the customer interface in an LDP-signaled pseudowire?
(Choose two.)
- A. When the encapsulation is vlan-ccc or extended-vlan-ccc, the configured VLAN tag is not included in the control plane LDP advertisement.
- B. When the encapsulation is vlan-ccc or extended-vlan-ccc, the configured VLAN tag is included in the control plane LDP advertisement.
- C. When the encapsulation is ethernet-ccc, only frames without a VLAN tag are accepted in the data plane.
- D. When the encapsulation is ethernet-ccc, tagged and untagged frames are both accepted in the data plane.
NEW QUESTION # 96
Exhibit.
Referring to the exhib.t, what must be changed to establish a Level 1 adjacency between routers R1 and R2?
- A. Change the level 1 disable parameter under the R2 protocols isis interface ge-1/2/3 .0 hierarchy to the level 2 disable parameter
- B. Remove the level i disable parameter under the R2 protocols isis interface loo . 0 configuration hierarchy.
- C. Add IP addresses to the interface ge-l/2/3 unit 0 family iso hierarchy on both R1 and R2.
- D. Change the level l disable parameter under the R1 protocols isis interface lo0.0 hierarchy to the level 2 disable parameter.
IS-IS routers can form Level 1 or Level 2 adjacencies depending on their configuration and network topology.
Level 1 routers are intra-area routers that share the same area address with their neighbors. Level 2 routers are inter-area routers that can connect different areas. Level 1-2 routers are both intra-area and inter-area routers that can form adjacencies with any other router.
In the exhibit, R1 and R2 are in different areas (49.0001 and 49.0002), so they cannot form a Level 1 adjacency. However, they can form a Level 2 adjacency if they are both configured as Level 1-2 routers. R1 is already configured as a Level 1-2 router, but R2 is configured as a Level 1 router only, because of the level 1 disable command under the lo0.0 interface. This command disables Level 2 routing on the loopback interface, which is used as the router ID for IS-IS.
Therefore, to establish a Level 1 adjacency between R1 and R2, the level 1 disable command under the R2 protocols isis interface lo0.0 hierarchy must be removed. This will enable Level 2 routing on R2 and allow it to form a Level 2 adjacency with R1.
NEW QUESTION # 97
Which origin code is preferred by BGP?
- A. Null
- B. External
- C. Incomplete
- D. Internal
BGP uses several attributes to select the best path for a destination prefix. One of these attributes is origin, which indicates how BGP learned about a route. The origin attribute can have one of three values: IGP, EGP, or Incomplete. IGP means that the route was originated by a network or aggregate statement within BGP or by redistribution from an IGP into BGP. EGP means that the route was learned from an external BGP peer (this value is obsolete since BGP version 4). Incomplete means that the route was learned by some other means, such as redistribution from a static route into BGP. BGP prefers routes with lower origin values, so Incomplete is preferred over EGP, which is preferred over IGP.
NEW QUESTION # 98
They need the opportunity and energy to get past and through information about the Service Provider, Professional (JNCIP-SP) (JN0-664) exam and consequently, they need unbelievable test center around the material. Juniper JN0-664 dumps will clear their requests and let them in on how they can scrutinize up for the Service Provider, Professional (JNCIP-SP) exam. This is the super choice that will save their endeavors and time also in tracking down help for the Juniper JN0-664 Exam.
JN0-664 PDF Questions: https://www.pass4suresvce.com/JN0-664-pass4sure-vce-dumps.html
- Exam Cram JN0-664 Pdf ➖ Dumps JN0-664 Torrent 😟 Exam Cram JN0-664 Pdf 🦺 Search on ➥ [url]www.testkingpass.com 🡄 for 【 JN0-664 】 to obtain exam materials for free download 🚶JN0-664 Valid Exam Pattern[/url]
- Pass Guaranteed JN0-664 - The Best Service Provider, Professional (JNCIP-SP) Exam Lab Questions 🦏 Search for ☀ JN0-664 ️☀️ and easily obtain a free download on ▷ [url]www.pdfvce.com ◁ ✔JN0-664 Real Question[/url]
- JN0-664 Latest Real Test 📨 JN0-664 Valid Test Syllabus 🚎 Exam Cram JN0-664 Pdf 💑 Immediately open ▛ [url]www.pdfdumps.com ▟ and search for ➠ JN0-664 🠰 to obtain a free download 🧊JN0-664 Valid Exam Tips[/url]
- JN0-664 - Service Provider, Professional (JNCIP-SP) –High-quality Exam Lab Questions 🏑 Search for ➠ JN0-664 🠰 and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ 🔽JN0-664 Clearer Explanation[/url]
- JN0-664 Real Question 🙈 JN0-664 Valid Exam Tips 🏋 Test JN0-664 Dumps Pdf 👔 Search for ➤ JN0-664 ⮘ and easily obtain a free download on ➠ [url]www.verifieddumps.com 🠰 😱JN0-664 Exam Simulations[/url]
- 2026 100% Free JN0-664 –Reliable 100% Free Exam Lab Questions | JN0-664 PDF Questions 🗓 Search for ➠ JN0-664 🠰 and download it for free immediately on ✔ [url]www.pdfvce.com ️✔️ 🌀Exam JN0-664 Flashcards[/url]
- JN0-664 Actual Exam Dumps 🦞 JN0-664 Test Preparation 🚝 Exam JN0-664 Topic ⏰ Easily obtain ▛ JN0-664 ▟ for free download through ⏩ [url]www.prepawaypdf.com ⏪ 🍌Valid JN0-664 Test Notes[/url]
- Dump JN0-664 Torrent 🐚 JN0-664 Valid Exam Pattern 🌂 JN0-664 Actual Exam Dumps 🃏 Immediately open ➡ [url]www.pdfvce.com ️⬅️ and search for ➥ JN0-664 🡄 to obtain a free download 🩸Exam JN0-664 Objectives[/url]
- Ensured Success Juniper JN0-664 Exam Questions - 100% Money Back Guarantee 🛒 Download 《 JN0-664 》 for free by simply entering ➠ [url]www.easy4engine.com 🠰 website 🧧Exam JN0-664 Objectives[/url]
- Valid JN0-664 Test Notes 🍯 Exam JN0-664 Flashcards 🦘 JN0-664 Test Preparation 🤛 Enter ➥ [url]www.pdfvce.com 🡄 and search for ➥ JN0-664 🡄 to download for free ⚛JN0-664 Real Question[/url]
- Exam JN0-664 Objectives 🌒 Dump JN0-664 Torrent 🚤 JN0-664 Test Papers 🏐 Search for ▛ JN0-664 ▟ and easily obtain a free download on ➠ [url]www.practicevce.com 🠰 💯Test JN0-664 Dumps Pdf[/url]
- thescholarsakademy.com, rent2renteducation.co.uk, telegra.ph, www.stes.tyc.edu.tw, www.childrenoflife.co.za, bbs.t-firefly.com, www.dandaoluntan.com, www.stes.tyc.edu.tw, tastycraftacademy.com, ralga.jtcholding.com, Disposable vapes
BONUS!!! Download part of Pass4suresVCE JN0-664 dumps for free: https://drive.google.com/open?id=1xiBIR9_1QeG14OCh7xg1SMqrVYWyyAr2
