[Hardware] 新版Nutanix NCP-MCA題庫上線,NCP-MCA認證資料
【Hardware】 新版Nutanix NCP-MCA題庫上線,NCP-MCA認證資料
Posted at 1/14/2026 13:07:48      View:133 | Replies:3        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載Fast2test NCP-MCA考試題庫的完整版:https://drive.google.com/open?id=135fofilYlQaBNC_nx6IF7C4WJHdyNsaO
在如今互聯網如此發達社會裏,選擇線上培訓已經是很普遍的現象。Fast2test就是眾多線上培訓網站之一。Fast2test的線上培訓有著多年的經驗,可以為參加Nutanix NCP-MCA 認證考試的考生提供高品質的學習資料,來能滿足考生的所有需求。
NCP-MCA認證考試涵蓋了與多云自動化有關的一系列主題。這些主題包括Nutanix Calm,即Nutanix的應用自動化和編排解決方案,以及其他Nutanix技術,例如Prism Central,AHV和XI Cloud Services。該考試評估了個人對這些技術的知識,以及它們使用它們來自動化IT操作的能力。該考試還涵蓋了與DevOps方法和實踐有關的主題,例如連續集成和連續部署(CI/CD),以及基礎架構(IAC)(IAC)和自動化框架。
NCP-MCA認證考試涵蓋了廣泛的主題,包括自動化和協調、虛擬化、網絡、安全和雲計算。該考試旨在測試候選人對管理和自動化復雜的多雲環境相關核心概念和技術的理解。
根據最新的考試大綱更新得到的NCP-MCA考古題 - 是最完整的NCP-MCA - Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10)題庫資料通過Nutanix NCP-MCA 認證考試的方法有很多種,花大量時間和精力來復習Nutanix NCP-MCA 認證考試相關的專業知識是一種方法,通過少量時間和金錢選擇使用Fast2test的針對性訓練和練習題也是一種方法。
最新的 Nutanix Certified Professional NCP-MCA 免費考試真題 (Q90-Q95):問題 #90
The VM appSAP01dev is a SAP development environment application and it is common to have memory constrained alerts on this VM, but the administrator wants to avoid adding memory to development VMs like this one, since this is normally done for only production VMs.
Which two actions should the administrator take to avoid adding memory to the development VMs? (Choose two.)
  • A. Disable the Alert in Prism Central
  • B. Modify the Alert by adding the correct category
  • C. Assign the category Environmentevelopment to development VMs
  • D. Assign the category Environmentroduction to the production VMs
答案:B,C
解題說明:
The administrator should modify the alert by adding the correct category and assign the category Environmentevelopment to development VMs. By doing this, they can filter out alerts for development VMs that are expected to have memory constrained alerts and focus on those that are critical, such as production VMs. This is based on the general practices in managing alerts in a multicloud environment, as well as the specific features and requirements of Nutanix Calm and Prism Central. References:
* How to create custom alert policies | Prism central | Nutanix Community
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5 Exam Blueprint Guide, Section 3: Validate Blueprints, Runbooks, Playbooks, and Automation Settings, Objective 3.1:
Determine the causes of a Blueprint or Runbook deployment failure
* Nutanix Multicloud Automation Administration (NMCAA) course, Module 4: Nutanix Calm Governance, Lesson 1: Nutanix Calm Governance
問題 #91
Which statement best describes Categories in Self-Service (formerly Calm)?
  • A. Categories are the VM instances existing machines or bare-metal machines.
  • B. Categories are metadata labels that are assigned to cloud resources.
  • C. Categories are part of a templating language for Self-Service scripts.
  • D. Categories provide a way to access the values of variables that are set on entities.
答案:B
解題說明:
Categories in Self-Service (formerly Calm) are metadata labels that are assigned to cloud resources. These categories help organize and manage resources by tagging them with specific attributes, making it easier to apply policies and manage the infrastructure.
Nutanix Calm documentation on Using Categories.
Nutanix Best Practices for Category Management.
問題 #92
After deploying a blueprint in Self-Service, an administrator notices that the invoked Playbook did not execute as expected. The blueprint deploys the VMs correctly, but no categories are applied and no notifications are sent.
What is the most likely cause of this issue?
  • A. The Playbook was not published to the Marketplace.
  • B. The VMs were deployed in Prism Element instead of in Prism Central.
  • C. The Playbook was not properly called by the blueprint's Create task.
  • D. The blueprint was not assigned to a Self-Service Project.
答案:C
解題說明:
When a Blueprint is designed to trigger external automation (like a Playbook via Webhook or API) or perform post-deployment actions (like applying categories via script), these actions must be explicitly defined asTaskswithin the Blueprint's lifecycle.
* The Symptom:The VM provisioning (Substrate) succeeded, but the subsequent logic (Categories
/Notifications) failed to happen.
* The Cause:In Self-Service, simply creating a Blueprint does not automatically link it to an Intelligent Operations Playbook. The developer must add a specific task (e.g., an HTTP Request task targeting the Playbook trigger, or a specific "Execute Playbook" action) to theService Profile(specifically the Post- Create or Create phase).
* If this task is missing, disabled, or misconfigured (e.g., wrong URL or payload), the VM will deploy, but the call to the Playbook will never occur, resulting in missing categories and notifications.
* Option A is incorrect because deployment would not start at all without a Project. Option D is incorrect because Playbooks are not published to the Marketplace (Blueprints are).
問題 #93
An administrator is trying to deploy a VM from an image onto a newly-built cluster, but the image is unavailable. The administrator is able to deploy the image onto other clusters with no issue. Image placement policies have already been created within Prism Central.
Why is the image unavailable for deployment on the cluster?
  • A. The image does not have the proper category assigned for the placement policy,
  • B. The image is corrupted.
  • C. The image has not been directly uploaded to the cluster
  • D. The cluster does not have the proper category assigned for the placement policy,
答案:A,D
解題說明:
The image is unavailable for deployment on the cluster because the cluster and the image do not have the proper categories assigned for the placement policy. A placement policy is a set of rules that determines which clusters and images are available for VM deployment based on the categories and values assigned to them. If the cluster and the image do not match the placement policy criteria, they will not be shown as options for VM deployment. Therefore, the administrator needs to assign the appropriate categories and values to the cluster and the image to make them compatible with the placement policy. Reference: Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Exam Blueprint Guide, page 12; Nutanix NCP-MCA Questions, question 111.
問題 #94
A customer has decided to enable Calm Showback feature but started to receive an alert in Prism Central stating that Calm showback is not able to reach beam service.
Which two configuration items should the administrator check to ensure Calm can communicate with Beam? (Choose two.)
  • A. DNS configuration in Prism Central
  • B. Flow is enabled in the same Prism Central
  • C. Prism Element is configured with Proxy settings
  • D. Ensure Pulse is enabled
答案:A,C
解題說明:
The alert in Prism Central indicates that Calm showback is not able to reach the beam service. This could be due to network connectivity issues or incorrect configurations. The administrator should check the DNS configuration in Prism Central (Option A) to ensure that it is correctly configured to allow communication with the Beam service. Additionally, checking if Prism Element is configured with Proxy settings (Option C) is essential as it can also affect the communication between Calm and Beam. Pulse (Option B) and Flow (Option D) are not related to the Calm showback feature and do not impact its functionality.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5, Section 2 - Deploy and Configure Nutanix Calm and Related Components, Objective 2.4 - Identify required configuration settings for a Nutanix Calm deployment Enabling and Disabling Showback in Calm | Nutanix Community
問題 #95
我們提供的產品是可以100%把你推上成功,那麼IT行業的巔峰離你又近了一步。如果你還沒有通過考試的信心,在這裏向你推薦一個最優秀的參考資料。在上面你可以免費下載我們提供的關於 Nutanix NCP-MCA 題庫的部分考題及答案測驗我們的可靠性。只需要短時間的學習就可以通過考試的最新的 NCP-MCA 考古題出現了。選擇最新的 NCP-MCA 考題會將對你有很大幫助,你需要考前用考試模擬題隨機做練習,重複做上幾次。
NCP-MCA認證資料: https://tw.fast2test.com/NCP-MCA-premium-file.html
從Google Drive中免費下載最新的Fast2test NCP-MCA PDF版考試題庫:https://drive.google.com/open?id=135fofilYlQaBNC_nx6IF7C4WJHdyNsaO
Posted at 1/20/2026 04:08:04        Only Author  2#
The content is awesome, so I’m giving it a like. This New PSE-Cortex-Pro-24 test test helped me get a promotion and salary hike. I’m now making it available for free. Wishing you all career success!
Posted at 1/23/2026 08:44:04        Only Author  3#
This article has helped me understand many complex concepts, and I’ve gained a lot. Free New Plat-Arch-204 exam sample materials are here. Best of luck in your exams!
Posted at 1/23/2026 15:33:24        Only Author  4#
The article is truly inspiring, thank you for posting it! Examcode materials are available free of charge. Best of luck to everyone! C-P2W22-2504 valid test collection pdf
