[Hardware] C_TS4FI_2023 Reliable Test Camp - Test C_TS4FI_2023 Pass4sure
83
【Hardware】 C_TS4FI_2023 Reliable Test Camp - Test C_TS4FI_2023 Pass4sure
Posted at 1/14/2026 13:24:07      View:158 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Real4test C_TS4FI_2023 PDF Dumps and C_TS4FI_2023 Exam Engine Free Share: https://drive.google.com/open?id=1dL0KAgx4Pm6-teT--P57wUE0jQc2DWFO
In order to facilitate the user's offline reading, the C_TS4FI_2023 study braindumps can better use the time of debris to learn, especially to develop PDF mode for users. In this mode, users can know the C_TS4FI_2023 prep guide inside the learning materials to download and print, easy to take notes on the paper, and weak link of their memory, at the same time, every user can be downloaded unlimited number of learning, greatly improve the efficiency of the users with our C_TS4FI_2023 Exam Questions. Besides that, the C_TS4FI_2023 exam questions in PDF version is quite portable.
In the course of your study, the test engine of C_TS4FI_2023 actual exam will be convenient to strengthen the weaknesses in the learning process. This can be used as an alternative to the process of sorting out the wrong questions of C_TS4FI_2023 learning guide in peacetime learning, which not only help you save time, but also makes you more focused in the follow-up learning process with our C_TS4FI_2023 learning materials.
Test C_TS4FI_2023 Pass4sure, Reliable C_TS4FI_2023 Exam CampIf you want to pass the C_TS4FI_2023 exam in the lest time with the lest efforts, then you only need to purchase our C_TS4FI_2023 learning guide. You can own the most important three versioons of our C_TS4FI_2023 practice materials if you buy the Value Pack! Also you can only choose the one you like best. As you know, the best for yourself is the best. Choosing the best product for you really saves a lot of time! C_TS4FI_2023 Actual Exam look forward to be your best partner.
SAP C_TS4FI_2023 Exam Syllabus Topics:
  • Managing Clean Core: It explores clean core principles in ERP systems to maximize business process agility, reduce adaptation efforts, and accelerate innovation within the organization.
  • Organizational Assignments and Process Integration: It focuses on managing organizational units, currencies, validations, document types, and number ranges. It also involves utilizing reporting tools and configuring substitutions.
  • General Ledger Accounting: Under this topic, the focus is on creating and maintaining general ledger accounts, bank master data, and house banks.
SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Financial Accounting Sample Questions (Q25-Q30):NEW QUESTION # 25
What is the prerequisite for a G/L account to switch off open item management for it?
  • A. It has a zero balance.
  • B. It has not been posted to.
  • C. It has been blocked against postings.
  • D. It has no open items.
Comprehensive Detailed Explanation with all SAP S/4HANA Cloud References In SAP S/4HANA, open item management is a feature used for G/L accounts that require reconciliation of outstanding items, such as vendor accounts, customer accounts, or bank clearing accounts. To switch off open item management for a G/L account, the account must meet specific prerequisites. Let's analyze each option to determine the correct answer.
Explanation of Each Option:
* Correct : The primary prerequisite for switching off open item management for a G/L account is that the account must have no open items . Open item management tracks uncleared transactions (e.g., unpaid invoices or unreconciled payments), and these must be cleared before the feature can be deactivated. If open items exist, the system will not allow you to switch off open item management.
* Reference : According to SAP documentation, open item management can only be switched off if there are no uncleared items in the account.
A. It has not been posted to.
* Incorrect : While an account that has never been posted to can have open item management switched off, this is not a strict requirement. The critical factor is the absence of open items, regardless of whether postings have occurred. Accounts with postings but no open items can still have open item management deactivated.
* Reference : The absence of postings is not a prerequisite; the focus is on clearing all open items.
B. It has a zero balance.
* Incorrect : Having a zero balance is not sufficient to switch off open item management. Even if the account balance is zero, it may still contain open items that need to be cleared. Open item management focuses on reconciling individual line items, not just the overall balance.
* Reference : A zero balance does not guarantee that all items in the account are cleared, so this is not a valid prerequisite.
* Incorrect : Blocking an account against postings prevents further transactions but does not address the presence of open items. Open item management cannot be switched off unless all open items are cleared, regardless of whether the account is blocked for postings.
* Reference : Blocking an account is unrelated to the process of deactivating open item management.
Key References to SAP S/4HANA Documentation:
* SAP S/4HANA Finance for General Ledger Accounting : Explains the concept of open item management and its prerequisites for activation or deactivation.
* SAP Help Portal - Open Item Management : Provides detailed guidance on managing open items and the conditions for switching off this feature.
* G/L Account Configuration : Describes how to configure and modify G/L account settings, including open item management.
* Reconciliation Accounts : Highlights the importance of clearing open items for accounts managed under open item management.
NEW QUESTION # 26
Which fields are maintained on the chart of accounts level of a G/L account? Note: There are 3 correct answers to this question.
  • A. Alternative account number
  • B. Short text
  • C. Account group
  • D. Group account number
  • E. Field status group
Answer: B,C,D
NEW QUESTION # 27
You want to prepare a consolidated financial report for your corporate group consisting of 15 legal entities. You have 10 company codes defined in your SAP S/4HANA system in a single client. The others use separate legacy systems.
How many companies should you define in your SAP S/4HANA system to accommodate the consolidation scenario?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
NEW QUESTION # 28
You are trying to extend a G/L account to a new company code but are getting an error for incomplete data. All customizable in the field status.
Which fields must you always maintain when extending a G/L account?
  • A. Field status group
  • B. Sort key
  • C. Account number
  • D. Account currency
NEW QUESTION # 29
You notice that in the entry view of a document you have fewer items than in the general ledger view. What is the reason for this?
  • A. The sub-ledger accounts are shown in details in the general ledger view.
  • B. The sales tax is posted in details in the general ledger view.
  • C. Document splitting has been activated.
  • D. An extension ledger has been configured.
NEW QUESTION # 30
Have you been many years at your position but haven't got a promotion? Or are you a new comer in your company and eager to make yourself outstanding? Our C_TS4FI_2023 exam materials can help you. With our C_TS4FI_2023 exam questions, you can study the most latest and specialized knowledge to deal with the problems in you daily job as well as get the desired C_TS4FI_2023 Certification. You can lead a totally different and more successfully life latter on.
Test C_TS4FI_2023 Pass4sure: https://www.real4test.com/C_TS4FI_2023_real-exam.html
BONUS!!! Download part of Real4test C_TS4FI_2023 dumps for free: https://drive.google.com/open?id=1dL0KAgx4Pm6-teT--P57wUE0jQc2DWFO
Posted at 1/16/2026 13:22:19        Only Author  2#
So much wisdom in this article, thank you for sharing it! Using the New SC-200 test questions answers, I achieved a promotion and salary boost. It’s free for everyone now. Wishing you all success in your career paths!
