[General] 312-96 Sure Pass & 312-96 Valid Exam Fee
108
【General】 312-96 Sure Pass & 312-96 Valid Exam Fee
Posted at 1/14/2026 14:06:57      View:174 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest TroytecDumps 312-96 PDF Dumps and 312-96 Exam Engine Free Share: https://drive.google.com/open?id=1GoXdT2mudEhsc1LBgsubDAkjgXV00cfs
If you buy our 312-96 study materials, then you can enjoy free updates for one year. After you start learning, I hope you can set a fixed time to check emails. If the content of the 312-96 practice guide or system is updated, we will send updated information to your e-mail address. Of course, you can also consult our e-mail on the status of the product updates. I hope we can work together to make you better use our 312-96 simulating exam.
EC-Council 312-96 Exam Syllabus Topics:
TopicDetailsWeights
Secure Coding Practices for Session Management- Explain session management in Java
-Demonstrate the knowledge of session management in Spring framework
-Demonstrate the knowledge of session vulnerabilities and their mitigation techniques
-Demonstrate the knowledge of best practices and guidelines for secure session management
10%
Understanding Application Security, Threats, and Attacks-Understand the need and benefits of application security
-Demonstrate the understanding of common application-level attacks
-Explain the causes of application-level vulnerabilities
-Explain various components of comprehensive application security
-Explain the need and advantages of integrating security in Software Development Life Cycle (SDLQ)
-Differentiate functional vs security activities in SDLC
-Explain Microsoft Security Development Lifecycle (SDU)
-Demonstrate the understanding of various software security reference standards, models, and frameworks
18%
Secure Coding Practices for Authentication and Authorization- Understand authentication concepts
-Explain authentication implementation in Java
-Demonstrate the knowledge of authentication weaknesses and prevention
-Understand authorization concepts
-Explain Access Control Model
-Explain EJB authorization
-Explain Java Authentication and Authorization (JAAS)
-Demonstrate the knowledge of authorization common mistakes and countermeasures
-Explain Java EE security
-Demonstrate the knowledge of authentication and authorization in Spring Security Framework
-Demonstrate the knowledge of defensive coding practices against broken authentication and authorization
4%
Secure Coding Practices for Cryptography- Understand fundamental concepts and need of cryptography In Java
-Explain encryption and secret keys
-Demonstrate the knowledge of cipher class Implementation
-Demonstrate the knowledge of digital signature and Its Implementation
-Demonstrate the knowledge of Secure Socket Layer ISSUand Its Implementation
-Explain Secure Key Management
-Demonstrate the knowledgeofdigital certificate and its implementation
- Demonstrate the knowledge of Hash implementation
-Explain Java Card Cryptography
-Explain Crypto Module in Spring Security
-Demonstrate the understanding of Do's and Don'ts in Java Cryptography
6%
Security Requirements Gathering-Understand the importance of gathering security requirements
-Explain Security Requirement Engineering (SRE) and its phases
-Demonstrate the understanding of Abuse Cases and Abuse Case Modeling
- Demonstrate the understanding of Security Use Cases and Security Use Case Modeling
-Demonstrate the understanding of Abuser and Security Stories
-Explain Security Quality Requirements Engineering (SQUARE) Model
-Explain Operationally Critical Threat, Asset, and Vulnerability Evaluation (OCTAVE) Model
8%
312-96 Valid Exam Fee | 312-96 Latest Test DiscountWith years of experience in compiling top-notch relevant ECCouncil 312-96 dumps questions, we also offer the ECCouncil 312-96 practice test (online and offline) to help you get familiar with the actual exam environment. Therefore, if you have struggled for months to pass ECCouncil 312-96 Exam, be rest assured you will pass this time with the help of our ECCouncil 312-96 exam dumps. Every 312-96 exam candidate who has used our exam preparation material has passed the exam with flying colors.
ECCouncil Certified Application Security Engineer (CASE) JAVA Sample Questions (Q30-Q35):NEW QUESTION # 30
Which of the following is used to mapCustom Exceptions to Statuscode?
  • A. @ResponseStatus
  • B. @ResponseStatusCode
  • C. @ScacusCode
  • D. @ResponseCode
In Spring MVC, the @ResponseStatus annotation is used to map custom exceptions to specific HTTP status codes. When an exception is thrown, you can use this annotation to indicate which status code should be returned. For example, if you have a custom exception that represents a resource not found scenario, you can annotate it with @ResponseStatus and specify HttpStatus.NOT_FOUND as the status code. This will result in a 404 status code being returned when the exception is thrown.
References:The use of @ResponseStatus is covered in the EC-Council's Certified Application Security Engineer (CASE) JAVA training and certification program, which emphasizes the importance of secure application development practices across the Software Development Lifecycle (SDLC). The annotation is also widely documented in Spring MVC resources and tutorials, such as those available on Baeldung and Stack Overflow12.
NEW QUESTION # 31
Which line of the following example of Java Code can make application vulnerable to a session attack?
  • A. Line No. 3
  • B. Line No. 5
  • C. Line No. 4
  • D. Line No. 1
In general, session management is a critical aspect of application security. A common vulnerability related to session management is the improper handling of session tokens, which can lead to session hijacking or fixation attacks. Without seeing the specific code, it's difficult to determine which line would be vulnerable. However, typical issues include:
* Line No. 1: If this line declares the servlet without proper security configuration, it could be vulnerable.
* Line No. 3: If this line involves the creation or handling of a session token without secure attributes (such as HttpOnly or Secure flags), it could make the application vulnerable.
* Line No. 4: If this line sets the session token's expiration too long, it could increase the risk of token theft.
* Line No. 5: If this line sends the session token to the client without encryption, it could be intercepted.
References:For verified answers and detailed explanations, please refer to the official EC-Council Application Security Engineer (CASE) JAVA study guides and courses. You can find more information and resources on their official website and iClass platform.
NEW QUESTION # 32
Which of the following configuration settings in server.xml will allow Tomcat server administrator to impose limit on uploading file based on their size?
  • A. < connector... maxPostSize="file size" / >
  • B. < connector... maxPostSize="0"/>
  • C. < connector... maxFileSize="file size" / >
  • D. < connector... maxFileLimit="file size" / >
NEW QUESTION # 33
Oliver, a Server Administrator (Tomcat), has set configuration in web.xml file as shown in the following screenshot. What is he trying to achieve?
  • A. He wants to transfer the entire data over encrypted channel
  • B. He wants to transfer only Session cookies over encrypted channel
  • C. He wants to transfer only response parameter data over encrypted channel
  • D. He wants to transfer only request parameter data over encrypted channel
NEW QUESTION # 34
A developer to handle global exception should use _________ annotation along with @ExceptionHandler method annotation for any class
  • A. @ControllerAdvice
  • B. @GlobalAdvice
  • C. @Advice
  • D. @globalControllerAdvice
The @ControllerAdvice annotation is used in Spring Framework to handle exceptions globally across the whole application, not just to an individual controller. It allows you to handle exceptions across multiple @Controllers. This annotation is used alongside @ExceptionHandler to define a global exception handling mechanism.
Here's how it works:
* The @ExceptionHandler annotation is used to define methods in your @ControllerAdvice class that will handle exceptions.
* When an exception is thrown, the Spring Framework checks for a matching @ExceptionHandler method in a @ControllerAdvice class.
* If a match is found, the exception is handled by the method annotated with @ExceptionHandler.
References:For more detailed information and learning resources, you should refer to the official EC-Council Application Security Engineer (CASE) JAVA study guides and courses, which can be found on their official website and iClass platform.
NEW QUESTION # 35
We believe that you can buy our 312-96 demo PDF torrent without any misgivings, Firstly, we have a strong experts team who are devoted themselves to research of the technology, which ensure the high-quality of our 312-96 Dump guide, TroytecDumps offers Certified Application Security Engineer (CASE) JAVA 312-96 free Updates. It is no exaggeration to say that the value of the certification training materials is equivalent to all exam related reference books.
312-96 Valid Exam Fee: https://www.troytecdumps.com/312-96-troytec-exam-dumps.html
Posted at 1/15/2026 09:17:14        Only Author  2#
I gained immense value from that article. Wish me all the best for the Valid exam L5M8 vce free exam coming up!
Posted at 1/20/2026 15:28:07        Only Author  3#
Your article is magnificent, thank you for sharing it with us! Improve your IT skills—free New test camp A1000-182 file is shared! Best of luck with everything!
