Oracle 1z0-1104-25 Reliable Test Pattern & 1z0-1104-25 Dump File
Posted at 1/14/2026 14:17:58
BONUS!!! Download part of SureTorrent 1z0-1104-25 dumps for free: https://drive.google.com/open?id=1XoziaPUpvfMvTBn8rYRppeG68nilp7VA
If you're looking to advance your career, passing the Oracle 1z0-1104-25 Certification Exam is crucial. As with any certification exam, success requires time and effort. While there are many online study materials available, not all of them are accurate or reliable. Many professionals struggle with managing their time and studying effectively, making it difficult to pass the Oracle Cloud Infrastructure 2025 Security Professional (1z0-1104-25) Exam.
Oracle 1z0-1104-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Protecting Data: This section of the exam measures the skills of Cloud Security Professionals and highlights data security practices in OCI. It tests knowledge of using the Key Management Service for encryption keys, managing secrets in the OCI Vault, and applying features of OCI Data Safe to ensure sensitive data remains protected.
| | Topic 2 | - OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
| | Topic 3 | - Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
| | Topic 4 | - Detecting, Remediating, and Monitoring OCI Resources: This section of the exam measures the skills of OCI Administrators and emphasizes monitoring and maintaining security posture across cloud resources. It focuses on the use of Cloud Guard, security zones, and the Security Advisor. Candidates also need to understand how to identify rogue users with threat intelligence, as well as use monitoring, logging, and event services for continuous visibility into performance and security.
| | Topic 5 | - Implementing OS and Workload Protection: This section of the exam measures the skills of OCI Administrators and looks at securing workloads and operating systems. It includes the use of OCI Bastion for time-limited access, vulnerability scanning of hosts and containers, and the use of OS management for automated updates. The goal is to ensure that workloads remain resilient and well-protected.
Oracle 1z0-1104-25 Dump File & 1z0-1104-25 Test Dumps.zipOur 1z0-1104-25 test braindumps are carefully developed by experts in various fields, and the quality is trustworthy. What's more, after you purchase our products, we will update our 1z0-1104-25 exam questions according to the new changes and then send them to you in time to ensure the comprehensiveness of learning materials. We also have data to prove that 99% of those who use our 1z0-1104-25 Latest Exam torrent to prepare for the exam can successfully pass the exam and get Oracle certification. So if you are preparing to take the test, you can rely on our learning materials. You will also be the next beneficiary. After you get Oracle certification, you can get boosted and high salary to enjoy a good life.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q38-Q43):NEW QUESTION # 38
"A business has a hybrid cloud infrastructure with Oracle Linux instances running in OCI and on-premises.
They want to reduce the amount of bandwidth used when patching systems.
Which component of OS Management Hub can help to reduce the bandwidth usage for patching?
- A. Profiles"
- B. Management agents
- C. Management stations
- D. Dynamic groups
NEW QUESTION # 39
"Your company is in the process of migrating its sensitive data to Oracle Cloud Infrastructure (OCI) and is prioritizing the strongest possible security measures. Encryption is a key part of this strategy, but you are particularly concerned about the physical security of the hardware where your encryption keys will be stored.
Which characteristic of OCI Key Management Service (KMS) helps ensure the physical security of your encryption keys?
- A. Centralized key management for simplified administration
- B. Utilization of FIPS 140-2 validated Hardware Security Modules (HSMs)"
- C. Seamless integration with other OCI services for streamlined workflows
- D. Granular customer control over key access permissions
NEW QUESTION # 40
When trying to encrypt plaintext using Command Line Interface (CLI), the developer gets a Service Error.
This is the command the developer tried to run:
What is the reason for this error?
- A. The developer has the wrong endpoint.
- B. The developer forgot to specify the region.
- C. The plaintext needs to be in JSON form.
- D. The user should pass the key version OCID instead of the key OCID.
NEW QUESTION # 41
During your investigation of a load balancer issue, you discovered that all back-end servers associated with one of the affected listeners were reported as unhealthy. However, when you checked the back-end servers, they seemed to be working just fine.
What might be causing this issue?
- A. Incorrect DNS configuration
- B. Misconfigured security rule
- C. Overloaded back-end servers
- D. Incorrect subnet configuration
- E. Misconfigured health check
Answer: E
NEW QUESTION # 42
Task 6: Create Load Balancer and Attach Certificate
Create a Load Balancer with the name PBT-CERT-LB-01 in subnet LB-Subnet-PBT-CERT-SNET-02 Create a Listener for the load balancer, where:
Protocol: HTTPS
Port: 443
Attach the certificate PBT-CERT-01-<username> to the load balancer
Attach the security list PBT-CERT-LB-SL-01 to subnet LB-Subnet-PBT-CERT-SNET-02 See the solution below in Explanation.
Step 1: Create the Load Balancer
* Log in to the OCI Console.
* Navigate toNetworking>Load Balancers.
* ClickCreate Load Balancer.
* Enter the following details:
* Name: PBT-CERT-LB-01
* Compartment: Select your assigned compartment.
* Load Balancer Type: SelectPublic.
* Virtual Cloud Network: Select PBT-CERT-VCN-01.
* Subnet: Select LB-Subnet-PBT-CERT-SNET-02.
* Shape: Choose a shape (e.g., 10 Mbps, adjust based on needs).
* ClickNext.
* Leave backend sets and listeners as default for now (we'll configure the listener next).
* ClickCreate Load Balancerand wait for it to be provisioned.
Step 2: Create a Listener
* Once the load balancer is created, go to theLoad Balancerspage and click on PBT-CERT-LB-01.
* UnderResources, clickListeners.
* ClickCreate Listener.
* Name: PBT-CERT-LB_LTSN_01
* Protocol: SelectHTTPS.
* Port: Enter 443.
* Certificate: ClickAdd Certificate, then select the PBT-CERT-01<username> certificate (e.g., PBT-CERT-0199008677labuser01) created in Task 5.
* Leave other settings (e.g., SSL handling) as default unless specified.
* ClickCreate.
Step 3: Configure the Backend Set
* In the PBT-CERT-LB-01 details page, underResources, clickBackend Sets.
* ClickCreate Backend Set(if not already created).
* Enter basic details (e.g., name like PBT-CERT-BS-01).
* Add a backend server:
* IP Address: Use the private IP of PBT-CERT-VM-01 (find this in the instance details under Compute>Instances).
* Port: 80 (HTTP, as configured on the web server).
* Protocol: HTTP.
* ClickCreate.
Step 4: Attach the Security List to the Subnet
* Navigate toNetworking>Virtual Cloud Networks.
* Select PBT-CERT-VCN-01 and clickSubnets.
* Click on LB-Subnet-PBT-CERT-SNET-02.
* UnderSecurity Lists, ensure PBT-CERT-LB-SL-01 is attached. If not:
* ClickEdit.
* Remove the default security list and add PBT-CERT-LB-SL-01.
* ClickSave Changes.
Step 5: Verify the Configuration
* Ensure the load balancer health status is OK (check underBackend Sets>Health).
* Test by accessing https://<load-balancer-public-ip> in a browser (replace with the public IP from the load balancer details).
NEW QUESTION # 43
If you still desperately cram knowledge and spend a lot of precious time and energy to prepare for passing Oracle certification 1z0-1104-25 exam, and at the same time do not know how to choose a more effective shortcut to pass Oracle Certification 1z0-1104-25 Exam. Now SureTorrent provide you a effective method to pass Oracle certification 1z0-1104-25 exam. It will play a multiplier effect to help you pass the exam.
1z0-1104-25 Dump File: https://www.suretorrent.com/1z0-1104-25-exam-guide-torrent.html
- Oracle 1z0-1104-25 Exam | 1z0-1104-25 Reliable Test Pattern - Provide you Best 1z0-1104-25 Dump File 🐳 Immediately open ✔ [url]www.prepawaypdf.com ️✔️ and search for 「 1z0-1104-25 」 to obtain a free download ⚠1z0-1104-25 Exam Dumps Free[/url]
- Oracle Cloud Infrastructure 2025 Security Professional latest study torrent - Oracle Cloud Infrastructure 2025 Security Professional reliable vce pdf - Oracle Cloud Infrastructure 2025 Security Professional valid training dumps 😊 Search for ☀ 1z0-1104-25 ️☀️ and download it for free on ⮆ [url]www.pdfvce.com ⮄ website 🦕New 1z0-1104-25 Exam Pass4sure[/url]
- 1z0-1104-25 latest Oracle certification exam questions and answers published 🤟 Easily obtain free download of 【 1z0-1104-25 】 by searching on 「 [url]www.prepawaypdf.com 」 👤1z0-1104-25 Accurate Study Material[/url]
- Trustable 1z0-1104-25 Reliable Test Pattern | 100% Free 1z0-1104-25 Dump File ✈ Search for ➠ 1z0-1104-25 🠰 and obtain a free download on ➥ [url]www.pdfvce.com 🡄 😒1z0-1104-25 Valid Test Materials[/url]
- 1z0-1104-25 Valid Test Tips 🎦 Exam 1z0-1104-25 Simulations 👛 1z0-1104-25 Review Guide 😅 Immediately open ➡ [url]www.troytecdumps.com ️⬅️ and search for ⮆ 1z0-1104-25 ⮄ to obtain a free download 🐮1z0-1104-25 Brain Dumps[/url]
- Trustable 1z0-1104-25 Reliable Test Pattern | 100% Free 1z0-1104-25 Dump File 👽 The page for free download of ➽ 1z0-1104-25 🢪 on ▶ [url]www.pdfvce.com ◀ will open immediately 🍼1z0-1104-25 Valid Test Materials[/url]
- 1z0-1104-25 latest Oracle certification exam questions and answers published 🧾 Search for 【 1z0-1104-25 】 and easily obtain a free download on ⮆ [url]www.easy4engine.com ⮄ 🌆Valid 1z0-1104-25 Exam Question[/url]
- 1z0-1104-25 latest Oracle certification exam questions and answers published 🐗 ▛ [url]www.pdfvce.com ▟ is best website to obtain ⏩ 1z0-1104-25 ⏪ for free download 👄1z0-1104-25 Brain Dumps[/url]
- Hot 1z0-1104-25 Reliable Test Pattern | Efficient 1z0-1104-25 Dump File: Oracle Cloud Infrastructure 2025 Security Professional 📈 Search for 「 1z0-1104-25 」 and download it for free immediately on ✔ [url]www.testkingpass.com ️✔️ 🧛Exam 1z0-1104-25 Simulations[/url]
- Latest 1z0-1104-25 VCE Torrent - 1z0-1104-25 Pass4sure PDF - 1z0-1104-25 Latest VCE 💚 Simply search for ✔ 1z0-1104-25 ️✔️ for free download on ☀ [url]www.pdfvce.com ️☀️ 🥃Valid 1z0-1104-25 Exam Materials[/url]
- 1z0-1104-25 Valid Test Materials 😖 1z0-1104-25 Latest Dumps Files 💇 1z0-1104-25 Latest Learning Material 😚 Easily obtain ➽ 1z0-1104-25 🢪 for free download through ( [url]www.exam4labs.com ) 🔍1z0-1104-25 Latest Test Format[/url]
- backloggd.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New 1z0-1104-25 dumps are available on Google Drive shared by SureTorrent: https://drive.google.com/open?id=1XoziaPUpvfMvTBn8rYRppeG68nilp7VA
