[General] Microsoft AZ-500 Exam Dumps For Ultimate Success 2026
93
General Microsoft AZ-500 Exam Dumps For Ultimate Success 2026
Posted at 1/14/2026 18:33:55      View109 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft AZ-500 dumps are available on Google Drive shared by ExamPrepAway: https://drive.google.com/open?id=1RKXuKJiN7fJLV52aPLWigFZryEZ3daCN
It is quite clear that many people would like to fall back on the most authoritative company no matter when they have any question about preparing for AZ-500 exam or met with any problem. I am proud to tell you that our company is definitely one of the most authoritative companies in the international market for AZ-500 Exam. What's more, we will provide the most considerate after sale service for our customers in twenty four hours a day seven days a week, therefore, our company is really the best choice for you to buy the AZ-500 training materials.
Microsoft AZ-500 exam is a challenging certification test that requires candidates to have hands-on experience with Microsoft Azure security solutions. AZ-500 exam measures the candidate's knowledge of Azure security concepts, tools, and best practices. Microsoft Azure Security Technologies certification is recognized globally and is highly valued by employers. Earning the Microsoft AZ-500 certification demonstrates one's commitment to cloud security and can open up new career opportunities in the IT industry.
To be successful on the AZ-500 exam, candidates should have a strong understanding of cloud security concepts, as well as experience working with Microsoft Azure security technologies. They should also be familiar with security operations, incident response, and compliance. Those who pass the exam will be able to demonstrate their ability to design, implement, and manage security solutions in the Azure platform.
Microsoft AZ-500 Certification Exam is a highly sought-after credential for IT professionals who are looking to specialize in cloud security. AZ-500 exam is designed to test the candidate's knowledge and skills in implementing and managing security controls, identifying and mitigating security risks, and maintaining security compliance in Microsoft Azure.
Latest AZ-500 Dumps Ebook, Pass AZ-500 RateWith the help of the Microsoft AZ-500 brain dumps and preparation material provided by ExamPrepAway, you will be able to get Microsoft Microsoft Azure Security Engineer Associate certified at the first attempt. Our Microsoft experts have curated an amazing AZ-500 exam guide for passing the AZ-500 Exam. You can get the desired outcome by preparing yourself from the AZ-500 exam dumps material provided by ExamPrepAway. We frequently update our AZ-500 exam preparation material to reflect the latest changes in the AZ-500 exam syllabus.
Microsoft Azure Security Technologies Sample Questions (Q490-Q495):NEW QUESTION # 490
You have an Azure Active Directory (Azure AD) tenant that contains the users shown in the following table.
The tenant contains the named locations shown in the following table.
You create the conditional access policies for a cloud app named App1 as shown in the following table.
NEW QUESTION # 491
From Azure AD Privileged Identity Management (PIM), you configure the settings for the Security Administrator role as shown in the following exhibit.
From PIM, you assign the Security Administrator role to the following groups:
Group1: Active assignment type, permanently assigned
Group2: Eligible assignment type, permanently eligible
Box 1: Yes
Eligible Type: A role assignment that requires a user to perform one or more actions to use the role. If a user has been made eligible for a role, that means they can activate the role when they need to perform privileged tasks. There's no difference in the access given to someone with a permanent versus an eligible role assignment. The only difference is that some people don't need that access all the time.
You can choose from two assignment duration options for each assignment type (eligible and active) when you configure settings for a role. These options become the default maximum duration when a user is assigned to the role in Privileged Identity Management.
Use the Activation maximum duration slider to set the maximum time, in hours, that a role stays active before it expires. This value can be from one to 24 hours.
Box 2: Yes
Active Type: A role assignment that doesn't require a user to perform any action to use the role. Users assigned as active have the privileges assigned to the role Box 3: Yes User3 is member of Group2.
https://docs.microsoft.com/en-us ... ement/pim-configure
https://docs.microsoft.com/bs-cy ... /pim-resource-roles
NEW QUESTION # 492
You plan to deploy an app that will modify the properties of Azure Active Directory (Azure AD) users by using Microsoft Graph. You need to ensure that the app can access Azure AD. What should you configure first?
  • A. an app registration
  • B. an external identity
  • C. a custom role-based access control (RBAC) role
  • D. an Azure AD Application Proxy
https://docs.microsoft.com/en-us ... lications-are-added
NEW QUESTION # 493
You have an Azure subscription.
You need to create and deploy an Azure policy that meets the following requirements:
* When a new virtual machine is deployed, automatically install a custom security extension.
* Trigger an autogenerated remediation task for non-compliant virtual machines to install the extension.
What should you include in the policy? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... remediate-resources
NEW QUESTION # 494
Lab Task
use the following login credentials as needed:
To enter your username, place your cursor in the Sign in box and click on the username below.
To enter your password. place your cursor in the Enter password box and click on the password below.
Azure Username: Userl -28681041@ExamUsers.com
Azure Password: GpOAe4@lDg
If the Azure portal does not load successfully in the browser, press CTRL-K to reload the portal in a new browser tab.
The following information is for technical support purposes only:
Lab Instance: 28681041
Task 4
You need to ensure that a user named user2-28681041 can manage the properties of the virtual machines in the RG1lod28681041 resource group. The solution must use the principle of least privilege.
see the task answer with step by step below:Check below steps in explanation for Task.
To ensure that a user named user2-28681041 can manage the properties of the virtual machines in the RG1lod28681041 resource group using the principle of least privilege, you can follow these steps:
In the Azure portal, search for and select the resource group named RG1lod28681041.
In the left pane, select Access control (IAM).
Select Add.
In the Add role assignment pane, enter the following information:
Role: Select the appropriate role for your scenario. For example, Virtual Machine Contributor.
Assign access to: Select User, group, or service principal.
Select: Enter the name of the user you want to assign the role to. For example, user2-28681041.
Select Save.
https://docs.microsoft.com/en-us ... -assignments-portal
NEW QUESTION # 495
By using the AZ-500 desktop practice exam software, you can sit in real exam like scenario. This AZ-500 practice exam simulates the complete environment of the actual test so you can overcome your fear about appearing in the Microsoft AZ-500 Exam. ExamPrepAway has designed this software for your Windows laptops and computers.
Latest AZ-500 Dumps Ebook: https://www.examprepaway.com/Microsoft/braindumps.AZ-500.ete.file.html
2026 Latest ExamPrepAway AZ-500 PDF Dumps and AZ-500 Exam Engine Free Share: https://drive.google.com/open?id=1RKXuKJiN7fJLV52aPLWigFZryEZ3daCN
