100% Pass Quiz Marvelous Analytics-DA-201 New Salesforce Certified Tableau Data
64
Posted at 1/14/2026 18:47:25      View171 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Analytics-DA-201 dumps are available on Google Drive shared by VCEPrep: https://drive.google.com/open?id=1_DbuPhHzLDmzuURFM7-lv0ugaJaUJO3y
Our Analytics-DA-201 learning materials help you to easily acquire the Analytics-DA-201 certification even if you have never touched the relative knowledge before. With our Analytics-DA-201 exam questions, you will easily get the favor of executives and successfully enter the gates of famous companies. You will have higher wages and a better development platform. What are you waiting for? Come and buy Analytics-DA-201 Study Guide now!
Salesforce Analytics-DA-201 Exam Syllabus Topics:
  • ABAP RESTful Application Programming Model: This section of the exam evaluates the capabilities of the SAP S
  • 4HANA Technical Consultant in using the ABAP RESTful Application Programming Model (RAP). It focuses on understanding the structure and components of RAP, including behavior definitions, service bindings, and metadata extension. The goal is to validate the ability to develop modern and scalable applications using RAP.
  • ABAP Core Data Services and Data Modeling: This section of the exam measures the skills of the SAP ABAP Cloud Developer and covers the fundamental understanding of core data services (CDS) and how to design data models in the SAP ABAP environment. Candidates are expected to know how to define, consume, and optimize CDS views effectively to support application development in the cloud.
  • SAP Clean Core Extensibility and ABAP Cloud: This part of the exam targets the SAP S
  • 4HANA Technical Consultant and covers concepts of clean core extensibility using ABAP in the cloud. The focus is on in-app and side-by-side extensibility techniques, ensuring that custom code complies with cloud-readiness principles and does not compromise the upgrade stability of core systems.
Latest New Analytics-DA-201 Test Practice - Find Shortcut to Pass Analytics-DA-201 ExamDesktop Salesforce Certified Tableau Data Analyst (Analytics-DA-201) practice test software is the first format available at VCEPrep. This format can be easily used on Windows PCs and laptops. The Salesforce Analytics-DA-201 practice exam software works without an internet connection, with the exception of license verification. One of the excellent features of this Salesforce Certified Tableau Data Analyst (Analytics-DA-201) desktop-based practice test software is that it includes multiple mock tests that have Salesforce Analytics-DA-201 practice questions identical to the actual exam, providing users with a chance to get Salesforce Certified Tableau Data Analyst (Analytics-DA-201) real exam experience before even attempting it.
Salesforce Certified Tableau Data Analyst Sample Questions (Q107-Q112):NEW QUESTION # 107
You are creating an annual report in Microsoft Word.
In Tableau Desktop, you build a chart in a worksheet.
You want to create an image of the chart that you can add to the annual report.
What are two ways to create the image? Choose two.
  • A. From the Worksheet menu, use the Export option.
  • B. From the File menu, use the Export As Version option.
  • C. From the Dashboard menu, use the Export Image option.
  • D. From the Dashboard menu, use the Copy Image option.
  • E. From the Worksheet menu, use the Copy option.
Answer: A,E
To create an image of the chart that you can add to the annual report, you can use either the Export option or the Copy option from the Worksheet menu. The Export option will allow you to save the image as a file in a specified location, name, and format. The Copy option will allow you to copy the image to the clipboard and paste it into another application, such as Microsoft Word. Both options will let you choose which elements to include in the image, such as title, caption, legend, etc. References:
* Export Views from Tableau Desktop to Another Application
* Copy and Paste Views from Tableau Desktop to Another Application
NEW QUESTION # 108
You have the following table.
You need each record to alternate between grey and white.
What should you change in the Format Shading pane?
  • A. the column banding size to 3
  • B. the row banding size to 1
  • C. the column banding size to 1
  • D. the row banding size to 3
To have each record alternate between grey and white, you should change the row banding size to 1 in the Format Shading pane. This setting will ensure that each row has a different shading from the one above and below it, creating an alternating pattern of grey and white rows. References: The answer can be verified through practical application within Tableau or by consulting Tableau's official learning resources, such as Tableau Help: Format Shading or Tableau Training Pass: Formatting.
NEW QUESTION # 109
You have the following dataset in Microsoft Excel.
You are using Data interpreter to cleans the dataset. Data interpreter provides the following results.
How many rows of data will be ingested into Tableau as values?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Data interpreter is a feature that helps you clean and structure your data in Excel before importing it into Tableau. It detects and removes any headers, footers, subtotals, or other elements that are not part of the actual data. It also splits any merged cells and fills in any missing values. In this case, data interpreter provides the following results:
* It removes the first three rows and the last two rows that contain headers and footers.
* It splits the merged cells in column A and fills in the missing values with "Fiction" or "Non-Fiction".
* It does not remove or change any other rows or cells.
Therefore, the number of rows of data that will be ingested into Tableau as values is 17, which is the number of rows left after removing the headers and footers. References: https://help.tableau.com/current/pro/desktop
/en-us/importing_cleaning_up_data.htm https://help.tableau.com/current/pro/desktop/en-us
/importing_data_interpreter.htm
Based on the Data Interpreter's results and the provided Excel dataset screenshot, the number of rows of data that will be ingested into Tableau as values is 17. The Data Interpreter has identified and excluded headers and footers, and the rows with actual data are considered for analysis.
NEW QUESTION # 110
How are the colors configured for the map?
  • A. A diverging color palette that has six stepped colors
  • B. A diverging color palette that has five stepped colors
  • C. A single color gradient
  • D. A sequential color gradient
NEW QUESTION # 111
A Data Analyst has the following two tables named Orders and Returns.
The analyst needs to get the Customer ID and Customer Name for only the orders that were returned. Orders will be the leading table.
Which type of join should the analyst perform in Tableau Prep?
  • A. Left join
  • B. Full join
  • C. Unmatched only join
  • D. Inner join
NEW QUESTION # 112
The Salesforce Certified Tableau Data Analyst PDF practice material contains actual Salesforce Analytics-DA-201 Exam Questions compiled by certified experts around the globe to benefit candidates. The criteria and pattern of the Salesforce Certified Tableau Data Analyst exam often change, and hence it is essential to use the updated exam study material for preparation. VCEPrep provides free updates after purchase so that you get the latest Salesforce Exam Questions for the exam.
Vce Analytics-DA-201 Format: https://www.vceprep.com/Analytics-DA-201-latest-vce-prep.html
What's more, part of that VCEPrep Analytics-DA-201 dumps now are free: https://drive.google.com/open?id=1_DbuPhHzLDmzuURFM7-lv0ugaJaUJO3y
