[General] Oracle 1Z0-1123-25 100% Correct Answers & Exam 1Z0-1123-25 Sample
87
【General】 Oracle 1Z0-1123-25 100% Correct Answers & Exam 1Z0-1123-25 Sample
Posted at 1/14/2026 19:19:08      View:167 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1Z0-1123-25 dumps are available on Google Drive shared by 2Pass4sure: https://drive.google.com/open?id=1tVo--c9htLsZDDegsZ956t1rQkvmUtI4
In order to gain the 1Z0-1123-25 certification quickly, people have bought a lot of 1Z0-1123-25 study materials, but they also find that these materials don't suitable for them and also cannot help them. If you also don't find the suitable 1Z0-1123-25 test guide, we are willing to recommend that you should use our 1Z0-1123-25 Study Materials. Because our products will help you solve the problem, it will never let you down if you decide to purchase and practice our 1Z0-1123-25 latest question. And our 1Z0-1123-25 exam questions have a high pass rate of 99% to 100%.
Oracle 1Z0-1123-25 Exam Syllabus Topics:
  • Migrate Oracle Databases to OCI Database Services: This section tests the knowledge of Database Migration Specialists in planning and executing successful database migrations to OCI. It covers database migration strategies, different OCI database services, and the available methods for transferring databases to the cloud. Candidates will learn how to analyze existing database workloads and select the most efficient migration approach for maintaining data integrity and performance.
  • Design and Implement Migrations Using Oracle Cloud VMware Solution (OCVS):This section measures the skills of VMware Cloud Engineers in migrating on-premises VMware environments to OCI. It covers source discovery to assess existing infrastructure, designing the target OCVS environment, and understanding migration prerequisites. Candidates will also explore Hybrid Cloud Extension as a tool for seamless migration and integration between VMware workloads and OCI.
  • Fundamentals of Cloud Migrations: This section of the exam measures the skills of Cloud Migration Engineers in understanding the core principles of cloud migrations. It covers the key drivers behind cloud adoption, the benefits of moving to Oracle Cloud Infrastructure (OCI), and the challenges businesses may face during migration. Candidates will gain insights into the different migration strategies and methodologies used to ensure seamless transitions from on-premises environments to the cloud.
  • OCI Networking Services for Migrations: This section evaluates the knowledge of Cloud Network Architects in utilizing OCI networking services for cloud migrations. It covers the fundamentals of OCI networking, including Virtual Cloud Networks (VCN), subnets, gateways, and connectivity options. The focus is on ensuring secure and optimized networking configurations that support smooth data migration and integration between on-premises and OCI environments.
Exam 1Z0-1123-25 Sample & 1Z0-1123-25 Exam DetailsTo pass the Oracle Cloud Infrastructure 2025 Migration Architect Professional (1Z0-1123-25) certification exam you need to prepare well with the help of top-notch 1Z0-1123-25 exam questions which you can download from 2Pass4sure platform. On this platform, you will get valid, updated, and real 2Pass4sure 1Z0-1123-25 Dumps for quick exam preparation.
Oracle Cloud Infrastructure 2025 Migration Architect Professional Sample Questions (Q40-Q45):NEW QUESTION # 40
You have been tasked with provisioning an Oracle Cloud Infrastructure Container Engine for Kubernetes (OKE) cluster to deploy new applications and manage existing ones. Which two statements are FALSE?
  • A. To access the cluster using kubectl, you have to set up a Kubernetes configuration file stored in the $HOME/.kube directory
  • B. The only available option when a cluster's Kubernetes API endpoint has a public IP address is to control the cluster locally using kubectl and the Kubernetes Dashboard
  • C. When a cluster's Kubernetes API endpoint has a public IP address, you can access the cluster in Cloud Shell by setting up a kubeconfig file
  • D. To access the cluster using kubectl, you have to set up a Kubernetes manifest file stored in the $HOME/.manifest directory
Setting up a Kubernetes manifest file in the $HOME/.manifest directory is not a standard practice for accessing a Kubernetes cluster using kubectl. Manifest files are used to define and manage Kubernetes resources, such as pods, deployments, and services, but they are not used for configuring access to the cluster.
While controlling the cluster locally using kubectl and the Kubernetes Dashboard is one way to interact with a cluster, it is not the only available option when a cluster's Kubernetes API endpoint has a public IP address. You can also access and manage the cluster remotely using kubectl from any environment that has network connectivity to the cluster.
NEW QUESTION # 41
One of your customers is planning to consolidate many of their single-instance databases into a suitable database solution in OCI. Their goal is to optimize resource utilization and reduce maintenance and management overhead. What would you suggest as a migration architect?
  • A. Use Oracle Estate Explorer to identify databases that can be migrated to Autonomous Database and the recommended method for migration
  • B. Consolidate all databases into Exadata Database on Dedicated Infrastructure using Zero Downtime Migration
  • C. Group and migrate related databases into OCI Base Database service on multitenant architecture
  • D. Group related databases and use the cloud premigration advisor tool to get consolidation recommendation
Grouping and migrating related databases into OCI Base Database service on multitenant architecture allows for efficient resource utilization and reduced management overhead.
NEW QUESTION # 42
Which Hybrid Cloud Extension (HCX) migration type is designed for large-scale migration of workloads that cannot afford downtime?
  • A. HCX OS Assisted Replication
  • B. HCX Bulk Migration
  • C. HCX Replication Assisted vMotion
  • D. HCX vMotion
HCX Replication Assisted vMotion is designed for large-scale migrations of workloads that cannot afford downtime. It allows for continuous replication of data while the workload is running, ensuring minimal disruption during the migration process.
NEW QUESTION # 43
Which two are options for provisioning of Oracle Autonomous Database in the public cloud?
  • A. Exadata Database on Dedicated Infrastructure
  • B. Serverless
  • C. Base Database
  • D. Dedicated Exadata Infrastructure
Serverless and Dedicated Exadata Infrastructure are valid options for provisioning Oracle Autonomous Database in the public cloud.
NEW QUESTION # 44
Which statement describes the transferring phase in the Delta Cycle of Oracle Cloud Infrastructure (OCI) File System replication?
  • A. Data is committed to the target file system during this phase
  • B. It focuses solely on capturing differentiated data in the source snapshot
  • C. The replication process remains idle without capturing or applying data
  • D. The replication captures as well as commits snapshot data
The transferring phase in the Delta Cycle of OCI File System replication involves capturing and committing snapshot data from the source to the target file system. This ensures that the changes in the source snapshot are replicated accurately to the target.
NEW QUESTION # 45
We know that the standard for most workers become higher and higher; so we also set higher goal on our 1Z0-1123-25 guide questions. Our training materials put customers' interests in front of other points, committing us to the advanced 1Z0-1123-25 learning materials all along. Until now, we have simplified the most complicated 1Z0-1123-25 Guide questions and designed a straightforward operation system, with the natural and seamless user interfaces of 1Z0-1123-25 exam question grown to be more fluent, we assure that our practice materials provide you a total ease of use.
Exam 1Z0-1123-25 Sample: https://www.2pass4sure.com/Oracle-Cloud-Infrastructure/1Z0-1123-25-actual-exam-braindumps.html
What's more, part of that 2Pass4sure 1Z0-1123-25 dumps now are free: https://drive.google.com/open?id=1tVo--c9htLsZDDegsZ956t1rQkvmUtI4
Posted at 1/17/2026 12:36:42        Only Author  2#
I’m so thankful for your article, it really made me think. Here’s the C-BCWME-2504 latest study questions sheet test that contributed to my promotion and salary increase. It’s free for everyone today—hope you all achieve your career goals soon!
Posted at 2/3/2026 05:35:12        Only Author  3#
What a remarkable article, I’m so thankful for your share. This Latest AACE-PSP exam online set helped me climb the career ladder and get a salary raise. Now, it’s available for free to all. Wishing you all the best in your professional growth!
Posted at 2/16/2026 16:27:20        Only Author  4#
I felt like I walked away from that article with so much more knowledge. Free C_HRHPC_2505 latest test notes exam materials—good luck to everyone!
