JN0-664 Valid Test Pattern | JN0-664 Reliable Study Materials
Posted at 1/14/2026 19:28:05
View144
Replies1
BONUS!!! Download part of PassLeader JN0-664 dumps for free: https://drive.google.com/open?id=1iIlSlMC4Mo5ueNEiPRnv6fJb71YUtonv
Having a good command of processional knowledge in this line, they devised our high quality and high effective JN0-664 study materials by unremitting effort and studious research. They are meritorious and unsuspecting experts with professional background. By concluding quintessential points into JN0-664 Preparation engine, you can pass the exam with the least time while huge progress. And our pass rate of the JN0-664 exam questions is high as 98% to 100%.
As we always want to do better in this career, our research center has formed a group of professional experts responsible for researching new technology of the JN0-664 study materials. The technology of the JN0-664 practice prep will be innovated every once in a while. As you can see, we never stop innovating new version of the JN0-664 Exam Questions. We really need your strong support. We always adopt the kind and useful advices of our loyal customers who wrote to us and gave us their opinions on their study.
JN0-664 Reliable Study Materials - Detailed JN0-664 Study DumpsOur JN0-664 learning guide allows you to study anytime, anywhere. If you are concerned that your study time cannot be guaranteed, then our JN0-664 learning guide is your best choice because it allows you to learn from time to time and make full use of all the time available for learning. Our online version of JN0-664 learning guide does not restrict the use of the device. You can use the computer or you can use the mobile phone. You can choose the device you feel convenient at any time.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q85-Q90):NEW QUESTION # 85
Exhibit.
Referring to the exhib.t, what must be changed to establish a Level 1 adjacency between routers R1 and R2?
- A. Change the level l disable parameter under the R1 protocols isis interface lo0.0 hierarchy to the level 2 disable parameter.
- B. Add IP addresses to the interface ge-l/2/3 unit 0 family iso hierarchy on both R1 and R2.
- C. Remove the level i disable parameter under the R2 protocols isis interface loo . 0 configuration hierarchy.
- D. Change the level 1 disable parameter under the R2 protocols isis interface ge-1/2/3 .0 hierarchy to the level 2 disable parameter
IS-IS routers can form Level 1 or Level 2 adjacencies depending on their configuration and network topology.
Level 1 routers are intra-area routers that share the same area address with their neighbors. Level 2 routers are inter-area routers that can connect different areas. Level 1-2 routers are both intra-area and inter-area routers that can form adjacencies with any other router.
In the exhibit, R1 and R2 are in different areas (49.0001 and 49.0002), so they cannot form a Level 1 adjacency. However, they can form a Level 2 adjacency if they are both configured as Level 1-2 routers. R1 is already configured as a Level 1-2 router, but R2 is configured as a Level 1 router only, because of the level 1 disable command under the lo0.0 interface. This command disables Level 2 routing on the loopback interface, which is used as the router ID for IS-IS.
Therefore, to establish a Level 1 adjacency between R1 and R2, the level 1 disable command under the R2 protocols isis interface lo0.0 hierarchy must be removed. This will enable Level 2 routing on R2 and allow it to form a Level 2 adjacency with R1.
NEW QUESTION # 86
Exhibit
A network designer would like to create a summary route as shown in the exhibit, but the configuration is not working.
Which three configuration changes will create a summary route? (Choose three.)
- A. set policy-options policy-statement leak-v6 term DC-routes then reject
- B. delete policy-options policy-statement leak-v6 term DC-routes from route-filter 2001: db9 :a: fa00 : :/6l longer
- C. set policy-options policy-statement leak-v6 term DC-routes from route-filter 2001:db9:a:faOO::/61 exact
- D. delete protocols isis export summary-v6
- E. set protocols isis import summary-v6
Answer: B,C,D
To create a summary route for IS-IS, you need to configure a policy statement that matches the prefixes to be summarized and sets the next-hop to discard. You also need to configure a summary-address statement under the IS-IS protocol hierarchy that references the policy statement. In this case, the policy statement leak-v6 is trying to match the prefix 2001:db9:a:fa00::/61 exactly, but this prefix is not advertised by any router in the network. Therefore, no summary route is created. To fix this, you need to delete the longer keyword from the route-filter term and change the prefix length to /61 exact. This will match any prefix that falls within the /61 range. You also need to delete the export statement under protocols isis, because this will export all routes that match the policy statement to other IS-IS routers, which is not desired for a summary route.
NEW QUESTION # 87
Your organization manages a Layer 3 VPN for multiple customers To support advanced route than one BGP community on advertised VPN routes to remote PE routers.
Which routing-instance configuration parameter would support this requirement?
- A. vrf-target export
- B. vrf-export
- C. vrf-import
- D. vrf-target import
The vrf-target statement is used in routing-instances to define route-target communities for VPN route import and export policies.
* vrf-target export # Controls which route targets (RTs) are added to advertised routes (used when sending routes to remote PEs).
* vrf-target import # Controls which VPN routes are accepted into the VRF (used when receiving routes from remote PEs).
NEW QUESTION # 88
Referring to the exhibit, which two statements are true? (Choose two.)
- A. The devices advertising this route into EVPN are 10.0.2.12 and 10.0.2.22.
- B. The device advertising this route into EVPN is 192.168.101.5.
- C. This is an EVPN Type-2 route.
- D. This route is learned through EBGP.
NEW QUESTION # 89
Exhibit
The network shown in the exhibit is based on IS-IS
Which statement is correct in this scenario?
- A. The routers are using unnumbered interfaces
- B. The area address is two bytes.
- C. The system IDofR1_2 is 192.168.16.1
- D. The NSEL byte for Area 0001 is 00.
IS-IS is an interior gateway protocol that uses link-state routing to exchange routing information among routers within a single autonomous system. IS-IS uses two types of addresses to identify routers and areas:
system ID and area address. The system ID is a unique identifier for each router in an IS-IS domain. The system ID is 6 octets long and can be derived from the MAC address or manually configured. The area address is a variable-length identifier for each area in an IS-IS domain. The area address can be 1 to 13 octets long and is composed of high-order octets of the address. An IS-IS instance may be assigned multiple area addresses, which are considered synonymous. Multiple synonymous area addresses are useful when merging or splitting areas in the domain1. In this question, we have a network based on IS-IS with four routers (R1_1, R1_2, R2_1, and R2_2) belonging to area 0001. The area address for area 0001 is 49.0001. The NSEL byte for area 0001 is the last octet of the address, which is 01. The NSEL byte stands for Network Service Access Point Selector (NSAP Selector) and indicates the type of service requested from the network layer2.
Therefore, the correct statement in this scenario is that the NSEL byte for area 0001 is 01.
NEW QUESTION # 90
Likewise, Web-Based Juniper JN0-664 exam questions are supported by all the major browsers like Chrome, Opera, Safari, Firefox, and IE. In the same way, the Web-based Service Provider, Professional (JNCIP-SP) pdf exam requires no special plugin. Lastly, the web-based Service Provider, Professional (JNCIP-SP) (JN0-664) practice exam is customizable and requires an active Internet connection.
JN0-664 Reliable Study Materials: https://www.passleader.top/Juniper/JN0-664-exam-braindumps.html
Our Juniper JN0-664 pass-sure cram can satisfy your demands, And you will be surprised to find our superiorities of our JN0-664 exam questioms than the other vendors', You may use the top JN0-664 study resources from PassLeader to prepare for the Service Provider, Professional (JNCIP-SP) exam, Juniper JN0-664 Valid Test Pattern Here you will find best exam material to pass your certification exam in first attempt, Juniper JN0-664 Valid Test Pattern Then you can go to everywhere without carrying your computers.
Interact with processes from the command line, Dragging and Dropping Files in OneNote, Our Juniper JN0-664 pass-sure cram can satisfy your demands, And you will be surprised to find our superiorities of our JN0-664 exam questioms than the other vendors'.
JN0-664 Exam Torrent: Service Provider, Professional (JNCIP-SP) & JN0-664 Practice TestYou may use the top JN0-664 study resources from PassLeader to prepare for the Service Provider, Professional (JNCIP-SP) exam, Here you will find best exam material to pass your certification exam in first attempt.
- Actual JN0-664 Exam Questions - JN0-664 Free Demo - JN0-664 Valid Torrent ⛴ Open ⮆ [url]www.exam4labs.com ⮄ and search for [ JN0-664 ] to download exam materials for free 🚐Reliable JN0-664 Test Sample[/url]
- Certificate JN0-664 Exam 🐃 Reliable JN0-664 Test Sample 🛸 JN0-664 Download Demo 🍘 ⏩ [url]www.pdfvce.com ⏪ is best website to obtain ➤ JN0-664 ⮘ for free download 🐾Latest JN0-664 Exam Cost[/url]
- Pass Guaranteed 2026 Juniper Marvelous JN0-664 Valid Test Pattern 🐗 Enter [url]www.prepawayexam.com and search for ✔ JN0-664 ️✔️ to download for free 🥜JN0-664 Reliable Real Exam[/url]
- Latest JN0-664 Exam Cost 🍩 JN0-664 Latest Exam Registration 🥤 Latest JN0-664 Test Questions ✳ Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for JN0-664 to download for free 🦖JN0-664 Latest Exam Registration[/url]
- Pass Guaranteed Juniper - JN0-664 - Useful Service Provider, Professional (JNCIP-SP) Valid Test Pattern ✔️ Download ➤ JN0-664 ⮘ for free by simply searching on ⏩ [url]www.vceengine.com ⏪ 👛Latest JN0-664 Test Questions[/url]
- Pass Guaranteed Juniper - JN0-664 - Useful Service Provider, Professional (JNCIP-SP) Valid Test Pattern 📇 Open ⏩ [url]www.pdfvce.com ⏪ and search for ➥ JN0-664 🡄 to download exam materials for free 🛌JN0-664 Training Pdf[/url]
- JN0-664 Training Materials: Service Provider, Professional (JNCIP-SP) - JN0-664 Exam Preparatory 🐠 Immediately open ➠ [url]www.prepawaypdf.com 🠰 and search for JN0-664 to obtain a free download 🔹JN0-664 Latest Exam Registration[/url]
- JN0-664 Latest Test Fee 🍧 Reliable JN0-664 Test Sample 🌳 Practice JN0-664 Engine 🐆 ➥ [url]www.pdfvce.com 🡄 is best website to obtain JN0-664 for free download 🎾JN0-664 Exam Study Solutions[/url]
- Free PDF JN0-664 - Reliable Service Provider, Professional (JNCIP-SP) Valid Test Pattern 🧺 Open [url]www.examdiscuss.com and search for ⏩ JN0-664 ⏪ to download exam materials for free 😹JN0-664 Free Exam Dumps[/url]
- Free Valid Juniper JN0-664 Questions Updates and Free Demos 🍉 Go to website ➡ [url]www.pdfvce.com ️⬅️ open and search for ⮆ JN0-664 ⮄ to download for free 🌝New APP JN0-664 Simulations[/url]
- Free Valid Juniper JN0-664 Questions Updates and Free Demos 🔗 Search for ➤ JN0-664 ⮘ and download it for free immediately on ⏩ [url]www.examcollectionpass.com ⏪ 🏑JN0-664 Training Pdf[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that PassLeader JN0-664 dumps now are free: https://drive.google.com/open?id=1iIlSlMC4Mo5ueNEiPRnv6fJb71YUtonv
