Valid 312-96 Pdf Braindumps & Leading Provider in Qualification Exams &
Posted at 1/14/2026 21:18:56
What's more, part of that Prep4pass 312-96 dumps now are free: https://drive.google.com/open?id=1IHKEuFBdYLtdHa3QrlaJjyffTahadC7P
All these three Prepare for your Certified Application Security Engineer (CASE) JAVA (312-96) exam questions formats are specifically designed for quick and complete ECCouncil 312-96 exam preparation. The 312-96 PDF Dumps file is the collection of real, valid, and updated Prepare for your Certified Application Security Engineer (CASE) JAVA (312-96) exam practice test questions that are being presented in PDF format. This Certified Application Security Engineer (CASE) JAVA (312-96) PDF file comes with some top features such as being very easy to download and use.
EC-Council 312-96 Exam Syllabus Topics:| Topic | Details | Weights | | Security Requirements Gathering | -Understand the importance of gathering security requirements
-Explain Security Requirement Engineering (SRE) and its phases
-Demonstrate the understanding of Abuse Cases and Abuse Case Modeling
- Demonstrate the understanding of Security Use Cases and Security Use Case Modeling
-Demonstrate the understanding of Abuser and Security Stories
-Explain Security Quality Requirements Engineering (SQUARE) Model
-Explain Operationally Critical Threat, Asset, and Vulnerability Evaluation (OCTAVE) Model | 8% | | Secure Coding Practices for Authentication and Authorization | - Understand authentication concepts
-Explain authentication implementation in Java
-Demonstrate the knowledge of authentication weaknesses and prevention
-Understand authorization concepts
-Explain Access Control Model
-Explain EJB authorization
-Explain Java Authentication and Authorization (JAAS)
-Demonstrate the knowledge of authorization common mistakes and countermeasures
-Explain Java EE security
-Demonstrate the knowledge of authentication and authorization in Spring Security Framework
-Demonstrate the knowledge of defensive coding practices against broken authentication and authorization | 4% | | Secure Application Design and Architecture | - Understand the importance of secure application design
-Explain various secure design principles
-Demonstrate the understanding of threat modeling
-Explain threat modeling process
-Explain STRIDE and DREAD Model
-Demonstrate the understanding of Secure Application Architecture Design | 12% | | Secure Coding Practices for Input Validation | - Understand the need of input validation
-Explain data validation techniques
-Explain data validation in strut framework
-Explain data validation in Spring framework
-Demonstrate the knowledge of common input validation errors
-Demonstrate the knowledge of common secure coding practices for input validation | 8% | | Secure Coding Practices for Cryptography | - Understand fundamental concepts and need of cryptography In Java
-Explain encryption and secret keys
-Demonstrate the knowledge of cipher class Implementation
-Demonstrate the knowledge of digital signature and Its Implementation
-Demonstrate the knowledge of Secure Socket Layer ISSUand Its Implementation
-Explain Secure Key Management
-Demonstrate the knowledgeofdigital certificate and its implementation
- Demonstrate the knowledge of Hash implementation
-Explain Java Card Cryptography
-Explain Crypto Module in Spring Security
-Demonstrate the understanding of Do's and Don'ts in Java Cryptography | 6% |
Start ECCouncil 312-96 Exam Preparation Today And Get SuccessNow it is a society of abundant capable people, and there are still a lot of industry is lack of talent, such as the IT industry is quite lack of technical talents. ECCouncil certification 312-96 exam is one of testing IT technology certification exams. Prep4pass is a website which provide you a training about ECCouncil Certification 312-96 Exam related technical knowledge.
EC-Council CASE Java Exam Certification Details:
ECCouncil Certified Application Security Engineer (CASE) JAVA Sample Questions (Q47-Q52):NEW QUESTION # 47
Alice works as a Java developer in Fygo software Services Ltd. He is given the responsibility to design a bookstore website for one of their clients. This website is supposed to store articles in .pdf format. Alice is advised by his superior to design ArticlesList.jsp page in such a way that it should display a list of all the articles in one page and should send a selected filename as a query string to redirect users to articledetails.jsp page.
Alice wrote the following code on page load to read the file name.
String myfilename = request.getParameter("filename");
String txtFileNameVariable = myfilename;
String locationVariable = request.getServletContext().getRealPath("/"); String PathVariable = ""; PathVariable = locationVariable + txtFileNameVariable; BufferedInputStream bufferedInputStream = null; Path filepath = Paths.get(PathVariable); After reviewing this code, his superior pointed out the security mistake in the code and instructed him not repeat the same in future. Can you point the type of vulnerability that may exist in the above code?
- A. Directory Traversal vulnerability
- B. Form Tampering vulnerability
- C. URL Tampering vulnerability
- D. XSS vulnerability
NEW QUESTION # 48
Oliver is a web server admin and wants to configure the Tomcat server in such a way that it should not serve index pages in the absence of welcome files. Which of the following settings in CATALINA_HOME/conf/ in web.xml will solve his problem?
- A. < servlet > < servlet-name > default < servlet-name > < servlet-class > org.apache.catalina.servlets.DefaultServlet < /servlet-class > < init-param > < param-name > debug <
/param-name> < param-value > 0 < /param-value > < /init-param > < init-param > < param-name > listings < /param-name > < param-value > true < /param-value > < /init-param > < load-on-startup > l <
/load-on-startup > < /servlet > - B. < servlet > < servlet-name > default < /servlet-name > < servlet-class > org.apache.catalina.servlets.DefaultServlet < /servlet-class > < init-param > < param-name > debug <
/param-name>< param-value> 0 < /param value>< /init-param > < init-param > < param-name> listings
< /param-name > < param-value > enable < /param-value > < /init-param > < load-on-startup> 1 <
/load-on-startup > < /servlet > - C. < servlet > < servlet-name > default < /servlet-name > < servlet-class > org.apache.catalina.servlets.DefaultServlet < /servlet-class > < init-param > < param-name > debug <
/param-name > < param-value > 0 < /param-value > < /init-param > < init-param > < param-name > listings < /param-name > < param-value > false < /param-value > < /init-param > < load-on-startup > 1
< /load-on-startup > < servlet > - D. < servlet > < servlet-name > default < /servlet-name > < servlet-class > org.apache.catalina.servlets.DefaultServlet < /servlet-class > < init-param > < param-name > debug <
/param-name > < param-value > 0 < /param-value > < /init-param > < init-param > < param-name > listings < /param-name > < param-value > disable < /param-value> < /init-param > < load-on-startup > 1
< /load-on-startup> < /servlet >
To prevent the Tomcat server from serving index pages in the absence of welcome files, the <servlet> configuration for the DefaultServlet needs to be modified. The listings parameter controls whether directory listings are shown. When set to false, it ensures that directory listings are not provided, which includes not serving index pages when welcome files are absent.
Here's the breakdown of the configuration:
* <servlet-name>default</servlet-name>: This specifies the name of the servlet.
* <servlet-class>org.apache.catalina.servlets.DefaultServlet</servlet-class>: This indicates the servlet class that is being configured.
* <init-param>: This tag is used to define initialization parameters for the servlet.
* <param-name>listings</param-name>: The listings parameter name is used to control the display of directory listings.
* <param-value>false</param-value>: Setting this value to false disables the directory listings.
* <load-on-startup>1</load-on-startup>: This indicates the servlet should be loaded at startup.
The correct configuration to solve Oliver's problem is:
XML
<servlet>
<init-param>
</init-param>
</servlet>
AI-generated code. Review and use carefully. More info on FAQ.
This configuration will ensure that if a welcome file is not present, the server will not default to serving an index page, thus addressing the security concern.
References:For further details on Tomcat server configuration, please refer to the official Apache Tomcat documentation and configuration guides which provide comprehensive instructions on server setup and security best practices12. These resources are essential for any web server admin like Oliver to configure and secure their Tomcat server effectively.
NEW QUESTION # 49
The software developer has implemented encryption in the code as shown in the following screenshot.
However, using the DES algorithm for encryption is considered to be an insecure coding practice as DES is a weak encryption algorithm. Which of the following symmetric encryption algorithms will you suggest for strong encryption?
- A. MD5
- B. AES
- C. Triple DES
- D. SHA-1
The DES algorithm has been considered insecure for some time due to its short key length and susceptibility to brute-force attacks. When seeking a more secure symmetric encryption algorithm, AES (Advanced Encryption Standard) is the recommended choice. AES is widely recognized for its strength and efficiency, particularly in its most common configuration of a 128-bit block size with key sizes of 128, 192, or 256 bits123.
AES is used by the U.S. government for securing classified information and is implemented in software and hardware throughout the world to encrypt sensitive data. Its security is based on the difficulty of the AES problem in cryptography, which involves the AES block cipher algorithm. The algorithm's design and strength against all known attacks make it suitable for highly sensitive data protection.
References: For a strong encryption algorithm, AES is often recommended in security guidelines and courses, including those provided by the EC-Council for Application Security Engineers specializing in Java. While I cannot provide direct references to EC-Council's proprietary materials, the use of AES for secure coding practices is a standard recommendation across various cybersecurity training programs and documents. For detailed study, one would refer to EC-Council's CASE Java courses and study guides that cover encryption and secure coding practices.
NEW QUESTION # 50
Which of the threat classification model is used to classify threats during threat modeling process?
- A. STRIDE
- B. RED
- C. SMART
- D. DREAD
STRIDE is a threat classification model used during the threat modeling process. It stands for Spoofing, Tampering, Repudiation, Information Disclosure, Denial of Service, and Elevation of Privilege. These categories represent the types of threats that can be posed to software systems. STRIDE helps in identifying potential security threats to a system and is commonly used to classify threats in threat modeling.
The STRIDE model is particularly useful because it covers a broad range of security threats and is designed to be easy to understand and apply. Each category of STRIDE addresses a specific area of security concern:
* Spoofing: Impersonating something or someone else.
* Tampering: Modifying data or code.
* Repudiation: Claiming not to have performed an action.
* Information Disclosure: Exposing information to someone not authorized to see it.
* Denial of Service (DoS): Interrupting access to resources.
* Elevation of Privilege: Gaining capabilities without proper authorization.
By using STRIDE, security professionals can systematically identify and address potential vulnerabilities within an application.
References:For detailed information and learning resources, please refer to the EC-Council's Certified Application Security Engineer (CASE) JAVA courses and study guides, which provide extensive coverage on threat modeling and the STRIDE methodology12. These resources will offer a comprehensive understanding of the application of STRIDE in threat modeling. Additionally, the OWASP Foundation provides valuable insights into the threat modeling process, including the use of STRIDE13.
NEW QUESTION # 51
Which of the following Spring Security Framework configuration setting will ensure the protection from session fixation attacks by not allowing authenticated user to login again?
- A. session-fixation-protection ="newSessionlD"
- B. session-fixation-protection =".
- C. session-fixation-protection =".
- D. session-fixation-protection ="enabled"
Spring Security provides built-in protection against session fixation attacks. It does this by invalidating the existing session and creating a new one when a user authenticates. This behavior can be configured using the sessionManagement() method in the Java configuration. The newSession strategy, which is the default, changes the session ID upon authentication to protect against session fixation.
Here's an example of how it can be configured:
Java
http.sessionManagement()
sessionFixation().migrateSession();
This configuration ensures that a new session is created, and the old one is invalidated when the user logs in, thus providing protection against session fixation attacks.
References:The information provided is based on the standard configuration practices for Spring Security to protect against session fixation attacks. For more detailed information, you can refer to the official Spring Security documentation123 and other authoritative resources on Spring Security session management.
NEW QUESTION # 52
Exam 312-96 Collection: https://www.prep4pass.com/312-96_exam-braindumps.html
- Quiz 2026 312-96: The Best Certified Application Security Engineer (CASE) JAVA Pdf Braindumps 🤵 Search on ➡ [url]www.prep4away.com ️⬅️ for 《 312-96 》 to obtain exam materials for free download 💍Real 312-96 Exam Dumps[/url]
- New ECCouncil 312-96 Dumps Get Ready With 312-96 Exam Questions 🧩 Simply search for ➽ 312-96 🢪 for free download on “ [url]www.pdfvce.com ” 🚓Real 312-96 Exam Dumps[/url]
- Real 312-96 Exam 🕋 312-96 Valid Dumps Ppt 🎃 Real 312-96 Exam 🧓 Go to website ➽ [url]www.prepawaypdf.com 🢪 open and search for ⏩ 312-96 ⏪ to download for free 🎥312-96 Reliable Test Pdf[/url]
- Latest 312-96 Exam Notes ⚗ Real 312-96 Exam Dumps 🕐 Reliable 312-96 Exam Book 🚥 Open ⮆ [url]www.pdfvce.com ⮄ and search for 《 312-96 》 to download exam materials for free 💭Valid Exam 312-96 Braindumps[/url]
- 100% Pass 2026 312-96: High-quality Certified Application Security Engineer (CASE) JAVA Pdf Braindumps 🕍 Search for ➤ 312-96 ⮘ and easily obtain a free download on ⏩ [url]www.troytecdumps.com ⏪ 🗯Reliable 312-96 Exam Book[/url]
- 2026 312-96 Pdf Braindumps - Certified Application Security Engineer (CASE) JAVA Unparalleled Exam Collection 🦄 Search on 《 [url]www.pdfvce.com 》 for ☀ 312-96 ️☀️ to obtain exam materials for free download 🍢312-96 Upgrade Dumps[/url]
- 2026 312-96 Pdf Braindumps - Certified Application Security Engineer (CASE) JAVA Unparalleled Exam Collection 🌙 Copy URL ➡ [url]www.pdfdumps.com ️⬅️ open and search for ▶ 312-96 ◀ to download for free 🐓Reliable 312-96 Dumps Pdf[/url]
- 312-96 Upgrade Dumps 🔅 Interactive 312-96 EBook 🤱 Real 312-96 Exam Dumps 🧒 Open ✔ [url]www.pdfvce.com ️✔️ enter 【 312-96 】 and obtain a free download 🐭312-96 Test Vce Free[/url]
- 2026 Excellent 312-96 – 100% Free Pdf Braindumps | Exam Certified Application Security Engineer (CASE) JAVA Collection 🌵 Easily obtain free download of ➠ 312-96 🠰 by searching on ✔ [url]www.vce4dumps.com ️✔️ 🏳Reliable 312-96 Dumps Pdf[/url]
- Real 312-96 Exam 🧖 312-96 Test Vce Free 🍎 Real 312-96 Exam 🐌 Copy URL 【 [url]www.pdfvce.com 】 open and search for ▶ 312-96 ◀ to download for free ℹ312-96 Valid Dumps Ppt[/url]
- 312-96 Upgrade Dumps 📈 312-96 Exam Cram Pdf ⌚ Valid Exam 312-96 Braindumps 👊 Search for ➤ 312-96 ⮘ and download exam materials for free through ⇛ [url]www.prepawaypdf.com ⇚ 🎊312-96 Dump Check[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, fulcrumcourses.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 ECCouncil 312-96 dumps are available on Google Drive shared by Prep4pass: https://drive.google.com/open?id=1IHKEuFBdYLtdHa3QrlaJjyffTahadC7P
