ISO-IEC-27001-Lead-Auditor熱門認證 - ISO-IEC-27001-Lead-Auditor最新試題
Posted at 1/14/2026 22:09:57
BONUS!!! 免費下載KaoGuTi ISO-IEC-27001-Lead-Auditor考試題庫的完整版:https://drive.google.com/open?id=1fzoD9kMDYDaO5_ffCjZn-VaF6l3cmPGU
KaoGuTi長年以來一直向大家提供關于IT認證考試相關的學習資料。PECB的ISO-IEC-27001-Lead-Auditor題庫由世界各地的資深IT工程師組成的專業團隊制作完成,包含最新的考試試題,并附有全部正確的答案,幫助考生通過他們認為很難的ISO-IEC-27001-Lead-Auditor考試。這樣可以節約考生的時間和金錢,大多數的考生都選擇這樣的方式來獲得ISO-IEC-27001-Lead-Auditor認證,并節省了很多的時間和努力。您需要是在反復練習這份真題的基礎上,多思考,多總結,通過ISO-IEC-27001-Lead-Auditor考試就沒有問題了。
作為PECB相關認證考試大綱的主要供應商,KaoGuTi的ISO-IEC-27001-Lead-Auditor專家一直不斷地提供品質較高的產品,不斷為客戶提供免費線上客戶服務,並以最快的速度更新考試大綱。
ISO-IEC-27001-Lead-Auditor最新試題 - ISO-IEC-27001-Lead-Auditor資訊在KaoGuTi的幫助下,你不需要花費大量的金錢參加相關的補習班或者花費很多時間和精力來復習相關知識就可以輕鬆通過考試。PECB ISO-IEC-27001-Lead-Auditor考試軟體是KaoGuTi研究過去的真實的考題開發出來的。KaoGuTi提供的PECB ISO-IEC-27001-Lead-Auditor考試練習題和答案和真實的考試練習題和答案有很大的相似性。
最新的 ISO 27001 ISO-IEC-27001-Lead-Auditor 免費考試真題 (Q234-Q239):問題 #234
Which two of the following standards are used as ISMS third-party certification audit criteria?
- A. ISO/IEC 27002
- B. ISO 19011
- C. ISO/IEC 27001
- D. ISO/IEC 17021-1
- E. ISO/IEC 20000-1
- F. Relavent legal, statutory, and regulatory requirements
答案:C,F
解題說明:
The two standards that are used as ISMS third-party certification audit criteria are ISO/IEC 27001 and relevant legal, statutory, and regulatory requirements. ISO/IEC 27001 specifies the requirements for establishing, implementing, maintaining, and continually improving an information security management system (ISMS)1. Relevant legal, statutory, and regulatory requirements are those that apply to the organization's information security aspects and objectives2. The other options are either not standards (E) or not directly related to the ISMS certification audit criteria (A, B, C, F). References: 1: ISO/IEC 27001:2022, Information technology - Security techniques - Information security management systems - Requirements, Clause 1 2: ISO/IEC 27001:2022, Information technology - Security techniques - Information security management systems - Requirements, Clause 4.2
問題 #235
Please match the following situations to the type of audit required.
答案:
解題說明:
問題 #236
You are an experienced ISMS audit team leader providing instruction to a class of auditors in training. The subject of today's lesson is the management of information security risk in accordance with the requirements of ISO/IEC 27001:2022.
You provide the class with a series of activities. You then ask the class to sort these activities into the order in which they appear in the standard.
What is the correct sequence they should report back to you?
答案:
解題說明:
The correct sequence of activities for the management of information security risk in accordance with the requirements of ISO/IEC 27001:2022 is as follows:
1st: Create and maintain information security risk criteria 2nd: Identify the risks that need to be considered when planning for the information security management system 3rd: Assess the potential consequences that would arise if the risk were to materialise 4th: Select appropriate risk treatment options 5th: Carry out information security risk assessments at planned intervals 6th: Consider the results of risk assessment and the status of the risk treatment plan at management review This sequence is based on the information security risk management process described in ISO/IEC 27001:
2022 clause 6.1, which includes the following activities:
* establishing and maintaining information security risk criteria;
* ensuring that repeated information security risk assessments produce consistent, valid and comparable results;
* identifying the information security risks;
* analyzing the information security risks;
* evaluating the information security risks;
* treating the information security risks;
* accepting the information security risks and the residual information security risks;
* communicating and consulting with stakeholders throughout the process;
* monitoring and reviewing the information security risks and the risk treatment plan.
* ISO/IEC 27001:2022, clause 6.1
* [PECB Candidate Handbook ISO/IEC 27001 Lead Auditor], pages 14-15
* ISO 27001 Risk Management in Plain English
問題 #237
You are performing an ISMS audit at a residential nursing home (ABC) that provides healthcare services. The next step in your audit plan is to verify the information security of ABC's healthcare mobile app development, support, and lifecycle process. During the audit, you learned the organization outsourced the mobile app development to a professional software development company with CMMI Level 5, ITSM (ISO/IEC 20000-1), BCMS (ISO
22301) and
ISMS (ISO/IEC 27001) certified.
The IT Manager presented the software security management procedure and summarised the process as following:
The mobile app development shall adopt "security-by-design" and "security-by-default" principles, as a minimum.
The following security functions for personal data protection shall be available:
Access control.
Personal data encryption, i.e., Advanced Encryption Standard (AES) algorithm, key lengths: 256 bits; and Personal data pseudonymization.
Vulnerability checked and no security backdoor
You sample the latest Mobile App Test report, details as follows:
The IT Manager explains the test results should be approved by him according to the software security management procedure. The reason why the encryption and pseudonymisation functions failed is that these functions heavily slowed down the system and service performance. An extra 150% of resources are needed to cover this. The Service Manager agreed that access control is good enough and acceptable. That's why the Service Manager signed the approval.
You are preparing the audit findings. Select the correct option.
- A. There is a nonconformity (NC). The Service Manager does not comply with the software security management procedure. (Relevant to clause 8.1, control A.8.30)
- B. There is a nonconformity (NC). The organisation and developer perform security tests that fail.
(Relevant to clause 8.1, control A.8.29) - C. There is NO nonconformity (NC). The Service Manager makes a good decision to continue the service.
(Relevant to clause 8.1, control A.8.30) - D. There is a nonconformity (NC). The organisation and developer do not perform acceptance tests.
答案:A
問題 #238
You are an ISMS audit team leader who has been assigned by your certification body to carry out a follow-up audit of a client. You are preparing your audit plan for this audit.
Which two of the following statements are true?
- A. Corrections should be verified first, followed by corrective actions and finally opportunities for improvement
- B. Opportunities for improvement should be verified first, followed by corrections and finally corrective actions
- C. Verification should focus on whether any action undertaken has been undertaken effectively
- D. Verification should focus on whether any action undertaken is complete
- E. Corrective actions should be reviewed first, followed by corrections and finally opportunities for improvement
- F. Verification should focus on whether any action undertaken taken has been undertaken efficiently
答案:C,D
解題說明:
According to ISO 27001:2022 clause 9.1.2, the organisation shall conduct internal audits at planned intervals to provide information on whether the information security management system conforms to the organisation's own requirements, the requirements of ISO 27001:2022, and is effectively implemented and maintained12 According to ISO 27001:2022 clause 10.1, the organisation shall react to the nonconformities and take action, as applicable, to control and correct them and deal with the consequences. The organisation shall also evaluate the need for action to eliminate the causes of nonconformities, in order to prevent recurrence or occurrence.
The organisation shall implement any action needed, review the effectiveness of any corrective action taken, and make changes to the information security management system, if necessary12 A follow-up audit is a type of internal audit that is conducted after a previous audit to verify whether the nonconformities and corrective actions have been addressed and resolved, and whether the information security management system has been improved12 Therefore, the following statements are true for preparing a follow-up audit plan:
* Verification should focus on whether any action undertaken is complete. This means that the auditor should check whether the organisation has implemented all the planned actions to correct and prevent the nonconformities, and whether the actions have been documented and communicated as required12
* Verification should focus on whether any action undertaken has been undertaken effectively. This means that the auditor should check whether the organisation has achieved the intended results and objectives of the actions, and whether the actions have eliminated or reduced the nonconformities and their causes and consequences12 The following statements are false for preparing a follow-up audit plan:
* Verification should focus on whether any action undertaken has been undertaken efficiently. This is false because efficiency is not a criterion for verifying the actions taken to address the nonconformities and corrective actions. Efficiency refers to the optimal use of resources to achieve the desired outcomes, but it is not a requirement of ISO 27001:2022. The auditor should focus on the effectiveness and completeness of the actions, not on the efficiency12
* Corrections should be verified first, followed by corrective actions and finally opportunities for improvement. This is false because there is no prescribed order for verifying the corrections, corrective actions, and opportunities for improvement. The auditor should verify all the actions taken by the organisation, regardless of their sequence or priority. The auditor may choose to verify the actions based on their relevance, significance, or impact, but this is not a mandatory requirement12
* Opportunities for improvement should be verified first, followed by corrections and finally corrective actions. This is false because there is no prescribed order for verifying the opportunities for improvement, corrections, and corrective actions. The auditor should verify all the actions taken by the organisation, regardless of their sequence or priority. The auditor may choose to verify the actions based on their relevance, significance, or impact, but this is not a mandatory requirement12
* Corrective actions should be reviewed first, followed by corrections and finally opportunities for improvement. This is false because there is no prescribed order for reviewing the corrective actions, corrections, and opportunities for improvement. The auditor should review all the actions taken by the organisation, regardless of their sequence or priority. The auditor may choose to review the actions based on their relevance, significance, or impact, but this is not a mandatory requirement12 References:
1: ISO/IEC 27001:2022 Lead Auditor (Information Security Management Systems) Course by CQI and IRCA Certified Training 1 2: ISO/IEC 27001 Lead Auditor Training Course by PECB 2
問題 #239
你用過KaoGuTi的ISO-IEC-27001-Lead-Auditor考古題嗎?這個考古題是最近剛更新的資料,包括了真實考試中可能出現的所有問題,保證你一次就可以通過考試。這個考古題可以讓你看到你意想不到的成果。如果你考試失敗KaoGuTi將會全額退款,所以請放心使用。利用KaoGuTi的考試資料,你肯定可以得到你想要的成功。
ISO-IEC-27001-Lead-Auditor最新試題: https://www.kaoguti.com/ISO-IEC-27001-Lead-Auditor_exam-pdf.html
我們的試題是來自全世界不同地區有超過10年以上經驗的技技術專家編寫,囊括了所有該注意的PECB Certified ISO/IEC 27001 Lead Auditor exam考試知識點和考點,我們的專家每天都會檢查更新我們所有得題庫產品,如果更新了會發送給每位購買的客戶PECB ISO-IEC-27001-Lead-Auditor-PECB Certified ISO/IEC 27001 Lead Auditor exam新版題庫,已確保購買了PECB Certified ISO/IEC 27001 Lead Auditor exam題庫的客戶更高準確率地通過考試並拿到高分數,不用擔心,有KaoGuTi PECB的ISO-IEC-27001-Lead-Auditor考試培訓資料在手,任何IT考試認證都變得很輕鬆自如,做題、弄懂題,只要你使用過一次KaoGuTi ISO-IEC-27001-Lead-Auditor最新試題的資料,你就肯定還想用第二次,我們承諾,如果你使用了我們最新的 ISO-IEC-27001-Lead-Auditor 認證考試練習題和答案卻考試失敗,我們公司將會全額退款給你。
而且為什麽我血的顏色不是鮮紅的,白衣青年們大吼道:簡直是癡人說夢,我ISO-IEC-27001-Lead-Auditor們的試題是來自全世界不同地區有超過10年以上經驗的技技術專家編寫,囊括了所有該注意的PECB Certified ISO/IEC 27001 Lead Auditor exam考試知識點和考點,我們的專家每天都會檢查更新我們所有得題庫產品,如果更新了會發送給每位購買的客戶PECB ISO-IEC-27001-Lead-Auditor-PECB Certified ISO/IEC 27001 Lead Auditor exam新版題庫,已確保購買了PECB Certified ISO/IEC 27001 Lead Auditor exam題庫的客戶更高準確率地通過考試並拿到高分數。
PECB ISO-IEC-27001-Lead-Auditor熱門認證:PECB Certified ISO/IEC 27001 Lead Auditor exam壹次通過考試不用擔心,有KaoGuTi PECB的ISO-IEC-27001-Lead-Auditor考試培訓資料在手,任何IT考試認證都變得很輕鬆自如,做題、弄懂題,只要你使用過一次KaoGuTi的資料,你就肯定還想用第二次,我們承諾,如果你使用了我們最新的 ISO-IEC-27001-Lead-Auditor 認證考試練習題和答案卻考試失敗,我們公司將會全額退款給你。
- 最新的PECB ISO-IEC-27001-Lead-Auditor:PECB Certified ISO/IEC 27001 Lead Auditor exam熱門認證 - 權威的[url]www.newdumpspdf.com ISO-IEC-27001-Lead-Auditor最新試題 🤠 在➥ www.newdumpspdf.com 🡄搜索最新的➡ ISO-IEC-27001-Lead-Auditor ️⬅️題庫ISO-IEC-27001-Lead-Auditor考題資源[/url]
- 值得信賴的ISO-IEC-27001-Lead-Auditor熱門認證和資格考試中的領先提供者與最新的ISO-IEC-27001-Lead-Auditor最新試題 💿 複製網址⮆ [url]www.newdumpspdf.com ⮄打開並搜索➠ ISO-IEC-27001-Lead-Auditor 🠰免費下載ISO-IEC-27001-Lead-Auditor最新題庫資源[/url]
- 最新ISO-IEC-27001-Lead-Auditor試題 🤯 ISO-IEC-27001-Lead-Auditor在線考題 🔒 最新ISO-IEC-27001-Lead-Auditor考題 🦀 透過【 tw.fast2test.com 】輕鬆獲取“ ISO-IEC-27001-Lead-Auditor ”免費下載ISO-IEC-27001-Lead-Auditor考試證照
- Newdumpspdf ISO-IEC-27001-Lead-Auditor熱門認證 - 立即獲取 👷 【 [url]www.newdumpspdf.com 】上的( ISO-IEC-27001-Lead-Auditor )免費下載只需搜尋ISO-IEC-27001-Lead-Auditor證照考試[/url]
- 高通過率的ISO-IEC-27001-Lead-Auditor熱門認證&資格考試與真實材料的領導者-PECB PECB Certified ISO/IEC 27001 Lead Auditor exam 🕔 ⮆ [url]www.pdfexamdumps.com ⮄網站搜索➤ ISO-IEC-27001-Lead-Auditor ⮘並免費下載ISO-IEC-27001-Lead-Auditor考試備考經驗[/url]
- ISO-IEC-27001-Lead-Auditor考試備考經驗 🔹 ISO-IEC-27001-Lead-Auditor最新題庫資源 🧉 ISO-IEC-27001-Lead-Auditor認證 😮 開啟「 [url]www.newdumpspdf.com 」輸入▶ ISO-IEC-27001-Lead-Auditor ◀並獲取免費下載新版ISO-IEC-27001-Lead-Auditor考古題[/url]
- ISO-IEC-27001-Lead-Auditor考題資源 ⚡ ISO-IEC-27001-Lead-Auditor考古題介紹 🏥 ISO-IEC-27001-Lead-Auditor測試題庫 🧹 在《 [url]www.newdumpspdf.com 》網站下載免費▷ ISO-IEC-27001-Lead-Auditor ◁題庫收集ISO-IEC-27001-Lead-Auditor考試大綱[/url]
- 完美的ISO-IEC-27001-Lead-Auditor熱門認證和認證考試的領導者材料和完整的ISO-IEC-27001-Lead-Auditor最新試題 😘 來自網站⏩ [url]www.newdumpspdf.com ⏪打開並搜索“ ISO-IEC-27001-Lead-Auditor ”免費下載ISO-IEC-27001-Lead-Auditor在線考題[/url]
- 完美的ISO-IEC-27001-Lead-Auditor熱門認證和認證考試的領導者材料和完整的ISO-IEC-27001-Lead-Auditor最新試題 👐 免費下載⇛ ISO-IEC-27001-Lead-Auditor ⇚只需進入✔ [url]www.newdumpspdf.com ️✔️網站新版ISO-IEC-27001-Lead-Auditor考古題[/url]
- 新版ISO-IEC-27001-Lead-Auditor考古題 🏆 新版ISO-IEC-27001-Lead-Auditor考古題 📝 ISO-IEC-27001-Lead-Auditor考試資訊 🔸 在☀ [url]www.newdumpspdf.com ️☀️上搜索【 ISO-IEC-27001-Lead-Auditor 】並獲取免費下載ISO-IEC-27001-Lead-Auditor真題[/url]
- 最新的PECB ISO-IEC-27001-Lead-Auditor:PECB Certified ISO/IEC 27001 Lead Auditor exam熱門認證 - 權威的[url]www.testpdf.net ISO-IEC-27001-Lead-Auditor最新試題 📤 立即在【 www.testpdf.net 】上搜尋➥ ISO-IEC-27001-Lead-Auditor 🡄並免費下載最新ISO-IEC-27001-Lead-Auditor考題[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.188ym.cc, courses.sspcphysics.com, infocode.uz, wjhsd.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. KaoGuTi在Google Drive上分享了免費的、最新的ISO-IEC-27001-Lead-Auditor考試題庫:https://drive.google.com/open?id=1fzoD9kMDYDaO5_ffCjZn-VaF6l3cmPGU
