[General] Confluent Latest CCAAK Exam Materials Exam Instant Download | Updated Valid CCAA
81
General Confluent Latest CCAAK Exam Materials Exam Instant Download | Updated Valid CCAA
Posted at 1/14/2026 22:24:58      View172 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that BraindumpsVCE CCAAK dumps now are free: https://drive.google.com/open?id=1oefyAEiVUr6JZQfeK7V6SCHft2IJfWSO
BraindumpsVCE offers the CCAAK exam questions in a convenient PDF format, allowing you to easily download them on your PC, laptop, Mac, tablet, or smartphone. With this accessibility, you can access the Confluent CCAAK PDF questions anytime and from anywhere. Having all the information about the Confluent Certified Administrator for Apache Kafka (CCAAK) Exam at your fingertips enhances your studying experience, making it easier and more effective, whether you're at home or on the go.
We have technicians to check the website every day, and therefore if you choose us, you can enjoy a safe online shopping environment. In addition, CCAAK exam materials are compiled and verified by professional specialists, and therefore the questions and answers are valid and correct. CCAAK learning materials cover most of knowledge points for the exam, and you can master them as well as improve your professional ability in the process of learning. You can receive the download link and password within ten minutes after paying for CCAAK Exam Dumps, if you dont receive, you can contact us, and we will solve this problem for you.
How You Can Ace Your Exam Preparation With BraindumpsVCE CCAAK Exam Questions?The CCAAK practice questions that are best for you will definitely make you feel more effective in less time. The cost of CCAAK studying materials is really very high. Selecting our study materials is definitely your right decision. Of course, you can also make a decision after using the trial version. With our CCAAK Real Exam, we look forward to your joining. And our CCAAK exam braindumps will never let you down.
Confluent CCAAK Exam Syllabus Topics:
  • Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
  • Apache Kafka® Fundamentals: This section of the exam measures skills of a Kafka Administrator and covers core concepts such as Kafka architecture, components, and data flow. It assesses the candidates understanding of topics like topics and partitions, brokers, producers, consumers, and message retention.
  • Troubleshooting: This section of the exam measures skills of a Kafka Administrator and includes diagnosing common issues in Kafka clusters. It covers problem areas such as performance bottlenecks, message delivery failures, replication issues, and consumer lag, along with techniques to resolve them effectively.
  • Observability: This section of the exam measures skills of a Site Reliability Engineer and focuses on monitoring Kafka clusters. It assesses knowledge of metrics, logging, and alerting tools, including how to use them to maintain cluster health and performance visibility.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q20-Q25):NEW QUESTION # 20
You are managing a cluster with a large number of topics, and each topic has a lot of partitions. A team wants to significantly increase the number of partitions for some topics.
Which parameters should you check before increasing the partitions?
  • A. Check the producer batch size and buffer size.
  • B. Check the max open file count on brokers.
  • C. Check if compression is being used.
  • D. Check if acks=all is beina used.
Each Kafka partition maps to multiple log segment files, and each segment results in open file descriptors on the broker. When the number of partitions increases significantly, it can exceed the OS-level limit for open files per broker process, leading to failures or degraded performance. Therefore, it is essential to check and possibly increase the ulimit -n (max open files) setting on the broker machines.
NEW QUESTION # 21
Your organization has a mission-critical Kafka cluster that must be highly available. A Disaster Recovery (DR) cluster has been set up using Replicator, and data is continuously being replicated from source cluster to the DR cluster. However, you notice that the message on offset 1002 on source cluster does not seem to match with offset 1002 on the destination DR cluster.
Which statement is correct?
  • A. The offsets for the messages on the source, destination cluster may not match.
  • B. The message on DR cluster got over-written accidently by another application.
  • C. The message was updated on source cluster, but the update did not flow into destination DR cluster and errored.
  • D. The DR cluster is lagging behind updates; once the DR cluster catches up, the messages will match.
When using Confluent Replicator (or MirrorMaker), offsets are not preserved between the source and destination Kafka clusters. Messages are replicated based on content, but they are assigned new offsets in the DR (destination) cluster. Therefore, offset 1002 on the source and offset 1002 on the DR cluster likely refer to different messages, which is expected behavior.
NEW QUESTION # 22
Kafka Connect is running on a two node cluster in distributed mode. The connector is a source connector that pulls data from Postgres tables (users/payment/orders), writes to topics with two partitions, and with replication factor two. The development team notices that the data is lagging behind.
What should be done to reduce the data lag*?
The Connector definition is listed below:
"name": "confluent-postgresql-source",
"connector class": "PostgresSource",
"topic.prefix": "postgresql_",
& nbsp;& nbsp;& nbsp;...
"db.name": "postgres",
"table.whitelist": "users.payment.orders",
"timestamp.column.name": "created_at",
"output.data format": "JSON",
"db.timezone": "UTC",
"tasks.max": "1"
  • A. Increase the number of Connect Tasks (tasks max value).
  • B. Increase the number of Connect Nodes.
  • C. Increase the replication factor and increase the number of Connect Tasks.
  • D. Increase the number of partitions.
The connector is currently configured with "tasks.max": "1", which means only one task is handling all tables (users, payment, orders). This can create a bottleneck and lead to lag. Increasing tasks.max allows Kafka Connect to parallelize work across multiple tasks, which can pull data from different tables concurrently and reduce lag.
NEW QUESTION # 23
Which model does Kafka use for consumers?
  • A. Publish
  • B. Enrollment
  • C. Pull
  • D. Push
Kafka uses a pull model for consumers, where consumers poll the broker to retrieve messages at their own pace. This model gives consumers more control over flow and backpressure, improving scalability and reliability.
NEW QUESTION # 24
Which statements are correct about partitions? (Choose two.)
  • A. A partition in Kafka will be represented by a single segment on a disk.
  • B. All partition segments reside in a single directory on a broker disk.
  • C. A partition is comprised of one or more segments on a disk.
  • D. A partition size is determined after the largest segment on a disk.
NEW QUESTION # 25
Preparing for the CCAAK exam can be a daunting task, but with real CCAAK exam questions, it can be a lot easier. The importance of actual Confluent Certified Administrator for Apache Kafka (CCAAK) questions cannot be overemphasized. CCAAK Real Questions are crucial for passing the CCAAK exam. When candidates have access to the updated Confluent CCAAK practice test questions, they are better prepared to succeed.
Valid CCAAK Exam Answers: https://www.braindumpsvce.com/CCAAK_exam-dumps-torrent.html
BTW, DOWNLOAD part of BraindumpsVCE CCAAK dumps from Cloud Storage: https://drive.google.com/open?id=1oefyAEiVUr6JZQfeK7V6SCHft2IJfWSO
Posted at 2/3/2026 17:21:00        Only Author  2#
This article has helped me see things from different angles, encouraging deeper reflection. Free Latest vce C_BCSPM_2502 test simulator shared to boost your IT skills. Best of luck with your preparations!
