[General] Pass-Sure H35-211_V2.5 Braindumps - Pass H35-211_V2.5 in One Time - Latest H35-2
88
【General】 Pass-Sure H35-211_V2.5 Braindumps - Pass H35-211_V2.5 in One Time - Latest H35-2
Posted at 1/15/2026 00:57:29      View:194 | Replies:3        Print      Only Author   [Copy Link] 1#
When you select to use Itcerttest's products, you have set the first foot on the peak of the IT industry and the way to your dream is one step closer. The practice questions of Itcerttest can not only help you pass Huawei Certification H35-211_V2.5 Exam and consolidate your professional knowledge, but also provide you one year free update service.
The Huawei H35-211_V2.5 exam format for Huawei H35-211_V2.5: HCIP-Access V2.5 is objective type, consisting of multiple-choice, multiple responses, and drag-and-drop questions. H35-211_V2.5 exam duration is two hours, and the passing score is 60%. Huawei recommends that candidates should have at least three years of experience in the access network field before taking H35-211_V2.5 exam.
Huawei H35-211_V2.5 (HCIP-Access V2.5) Exam is an ideal certification for IT professionals who are interested in pursuing a career in access network technologies. H35-211_V2.5 Exam covers a broad range of topics related to access network technologies and is designed to help candidates develop the skills and knowledge required to design, deploy, and manage access networks that meet the needs of modern businesses. Passing H35-211_V2.5 exam is a key requirement for becoming a Huawei Certified ICT Professional (HCIP).
H35-211_V2.5 Real Exam Answers - Exam H35-211_V2.5 TopicsDo you want to pass H35-211_V2.5 exam easily? H35-211_V2.5 exam training materials of Itcerttest is a good choice, which covers all the content and answers about H35-211_V2.5 exam dumps you need to know. Then you can master the difficult points in a limited time, pass the H35-211_V2.5 Exam in one time, improve your professional value and stand more closely to success.
Huawei H35-211_V2.5: HCIP-Access V2.5 exam is designed for professionals who wish to validate their skills and knowledge in the field of network access technology. The HCIP-Access V2.5 certification recognizes the ability of an individual to install, configure, maintain and troubleshoot network access solutions.
Huawei HCIP-Access V2.5 Sample Questions (Q67-Q72):NEW QUESTION # 67
An ODN network must use single-mode fibers.
  • A. FALSE
  • B. TRUE
NEW QUESTION # 68
Deploying an Ethernet port protection group in the upstream direction of the OLT can improve the reliability and the bandwidth of the uplink.
  • A. TRUE
  • B. FALSE
An Ethernet port protection group is a 1:1 protection mechanism that improves reliability through active
/standby switching. It does not aggregate bandwidth-the standby port does not forward traffic unless a switchover occurs. If increased bandwidth is required, technologies such as LACP are used instead.
References: HCIP-Access V2.5 - Uplink Protection vs. Link Aggregation; OLT Ethernet Port Protection Group Feature Description.
NEW QUESTION # 69
(Radio) 10G GPON system downlink wavelength is:
  • A. 1577 nm
  • B. 1490 nm
  • C. 1310 nm
  • D. 1270 nm
In Huawei's 10G GPON (Gigabit-capable Passive Optical Network) system, different optical wavelengths are used for upstream and downstream transmission to ensure bidirectional communication over a single fiber.
According to the ITU-T G.987.x series and Huawei's Access Network Technical Documentation, the wavelength plan for 10G GPON (XG-PON) is as follows:
Downstream (OLT # ONU): 1577 nm
Upstream (ONU # OLT): 1270 nm
This separation of wavelengths allows both transmission directions to occur simultaneously using WDM (Wavelength Division Multiplexing) on the same optical fiber, minimizing interference.
Huawei OLTs such as the MA5800 and EA5800 series follow this standard exactly - supporting 10G GPON (XG-PON) with downstream at 1577 nm and upstream at 1270 nm.Hence, the correct answer is 1577 nm.
References (Aligned with HCIP-Access V2.5 and Huawei Technical Sources):
HCIP-Access V2.5 Study Guide - "Huawei Campus Network Overview" Chapter, Section: PON Technology Overview Huawei 10G GPON (XG-PON) Technical White Paper ITU-T G.987.2: 10-Gigabit-capable Passive Optical Networks (XG-PON): Physical Media Dependent (PMD) Layer Specification Huawei MA5800 Product Description - 10G GPON Port Wavelength Specifications
NEW QUESTION # 70
(Multi-select) VLAN planning principles need to be considered:
  • A. Customer type and number of users
  • B. Uplink networking mode
  • C. Type and quantity of services
  • D. The networking topology of the OLT
  • E. The total number of VLANs
Answer: A,B,C,D,E
Huawei VLAN planning considers overall VLAN scale, user categories and volume, service types (HSI/IPTV
/VoIP) and their isolation, uplink/aggregation mode (e.g., QinQ, VXLAN interwork), and device/topology constraints (e.g., OLT slot/board distribution). All listed factors affect VLAN count, tagging scheme, and scalability.
References: HCIP-Access V2.5 Study Guide (Campus and access VLAN design principles; service isolation and scalability).
NEW QUESTION # 71
In the evolution of EPON to 10g EPON, a smooth transition is achieved at the local end by adding AWDM
WDM module, and Odn coexists.
  • A. False
  • B. True
NEW QUESTION # 72
H35-211_V2.5 Real Exam Answers: https://www.itcerttest.com/H35-211_V2.5_braindumps.html
Posted at 1/29/2026 17:06:32        Only Author  2#
I’m in awe of your article, thank you so much for sharing! I got a promotion and raise with the AP-204 valid test questions explanations. Now it’s available for everyone. Wishing you all success in your promotions!
Posted at 2/5/2026 20:53:03        Only Author  3#
That piece was both thought-provoking and enriching. The L5M9 new study notes content is highly informative, and it's offered at no cost.
Posted at 2/7/2026 07:25:53        Only Author  4#
Your article was truly remarkable, thank you for sharing it. Sharing Virginia-Life-Annuities-and-Health-Insurance reliable exam dumps exam content with you for free—good luck!
