[General] Free PDF 2026 F5 F5CAB4: Fantastic BIG-IP Administration Control Plane Administr
92
General Free PDF 2026 F5 F5CAB4: Fantastic BIG-IP Administration Control Plane Administr
Posted at 1/15/2026 01:55:44      View227 | Replies3        Print      Only Author   [Copy Link] 1#
With the F5 F5CAB4 exam practice test questions, you can easily speed up your F5CAB4 exam preparation and be ready to solve all the final F5 F5CAB4 exam questions. As far as the top features of F5 F5CAB4 Exam Practice test questions are concerned, these F5CAB4 exam questions are real and verified by experience exam trainers.
We provide you free demo with you to help you have a deeper understanding about F5CAB4 study materials. Free demo can be found in our website, and we recommend you to have a try before buying. Furthermore, F5CAB4 exam materials of us have the questions and answers, and you can have a convenient check of your answers after you finish practicing. We are pass guarantee and money back guarantee for your failure after purchasing F5CAB4 Study Materials. You just need to give your failure scanned and we will give you full refund. Choose us, and we can help you to pass the exam successfully.
Reliable F5CAB4 Test Syllabus & F5CAB4 Relevant AnswersAs long as you study with our F5CAB4 exam braindump, you can find that it is easy to study with the F5CAB4 exam questions. Therefore, even ordinary examiners can master all the learning problems without difficulty. In addition, F5CAB4 candidates can benefit themselves by using our test engine and get a lot of test questions like exercises and answers. They will help them modify the entire syllabus in a short time. The most important thing is that our F5CAB4 Practice Guide can help you obtain the certification without difficulty.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q19-Q24):NEW QUESTION # 19
Which log file should the BIG-IP Administrator check to determine if a specific user tried to log in to the BIG-IP Configuration Utility? (Choose one answer)
  • A. /var/log/ltm
  • B. /var/log/httpd
  • C. /var/log/pam/tallylog
  • D. /var/log/secure
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents:
On BIG-IP systems, all authentication attempts for administrative access-including logins to the Configuration Utility (GUI)-are logged in /var/log/secure. This log file records:
Successful and failed login attempts
The username used
The authentication method (local, LDAP, RADIUS, etc.)
Access denials and PAM authentication errors
/var/log/pam/tallylog tracks account lockouts and failed attempt counters, not detailed login attempts.
/var/log/ltm logs traffic management events, not administrative authentication.
/var/log/httpd logs web server activity but does not record authentication success or failure for BIG-IP administrative users.
Therefore, the correct log file to verify whether a user attempted to log in to the BIG-IP Configuration Utility is /var/log/secure.
NEW QUESTION # 20
The BIG-IP Administrator runs the command:
netstat -an | grep 443
and sees the following output:
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
What does this output indicate about the service on port 443? (Choose one answer)
  • A. The service indicates no connections to the LISTEN port.
  • B. The service is in a standby state and unable to accept connections.
  • C. The service is actively listening only on the loopback interface.
  • D. The service is actively listening on all interfaces for HTTPS traffic.
In netstat output:
0.0.0.0:443 means the service is bound to all available IPv4 interfaces on the system.
LISTEN indicates the service is actively waiting for incoming connection requests.
Therefore, this output confirms that a service (commonly HTTPS/443, such as the BIG-IP Configuration Utility or an application listener) is actively listening on all interfaces, making B the correct answer.
A would show 127.0.0.1:443 if it were loopback-only.
C is incorrect because LISTEN explicitly indicates readiness to accept connections.
D is unrelated; standby state does not affect socket binding shown by netstat.
Hence, the correct answer is B.
NEW QUESTION # 21
A BIG-IP Administrator needs to fall over the active device. The administrator logs into the Configuration Utility and navigates to Device Management > Traffic Group. However, "Force to Standby" is greyed out. What is causing this issue?
  • A. The BIG-IP Administrator is on the Standby Device
  • B. The BIG-IP Administrator is NOT logged into command line to tail over
  • C. The BIG-IP Administrator is logged in as root
  • D. The BIG-IP Administrator is logged in as administrator
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: In a High Availability pair, the "Force to Standby" action is a Control Plane command used to trigger a manual failover. This option is only logical and available on the device that is currently in the Active state. If the button is greyed out, it indicates that the administrator is already logged into the Standby unit, which has no active traffic groups to relinquish.
NEW QUESTION # 22
A BIG-IP Administrator finds the following log entry: tnm tmm[7141]: 011e0002:4: sweeper_update: aggressive mode activated. Which action should the BIG-IP Administrator take to mitigate this memory issue?
  • A. Increase the TCP profile Idle Timeout value
  • B. Configure the server to use Connection Mirroring
  • C. Configure the redundant pair to be active-active
  • D. Decrease the TCP profile Idle Timeout value
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: This log message indicates that the system is low on memory and has activated 'Aggressive Mode' to reclaim resources by closing old connections37. In an HA environment, one way to ensure state stability during memory pressure is to manage how connection data is handled38. While the document suggests D, procedural mitigation for 'Aggressive Mode' often involves reviewing resource provisioning or optimizing connection idle timeouts to reduce memory footprint39.
NEW QUESTION # 23
Which method is recommended for creating a new user from the CLI? (Choose one answer)
  • A. Run f5adduser 'username' then f5passwd username from bash or tmsh
  • B. Run tmsh create auth user username prompt-for-password from bash
  • C. Edit bigip.conf to add the new user and the user's clear-text password
  • D. Run useradd 'username' then passwd username from bash or tmsh
The recommended and supported method for creating BIG-IP users from the CLI is through TMSH, using the authentication subsystem.
tmsh create auth user <username> prompt-for-password:
Properly creates the user within BIG-IP's AAA/authentication framework
Encrypts the password securely
Ensures the user is stored and managed correctly in the BIG-IP configuration database Is fully supported and documented Why the other options are incorrect:
B is unsafe and unsupported because editing bigip.conf directly and storing clear-text passwords violates security and configuration management best practices.
C (f5adduser / f5passwd) is deprecated and not recommended for modern BIG-IP versions.
D creates a Linux system user only, not a BIG-IP administrative user, and will not allow access to the Configuration Utility or TMSH roles.
NEW QUESTION # 24
Our F5CAB4 study material is the most popular examination question bank for candidates. F5CAB4 study material has helped thousands of candidates successfully pass the exam and has been praised by all users since it was appearance. F5CAB4 study material has the most authoritative test counseling platform, and each topic in F5CAB4 Study Materials is carefully written by experts who are engaged in researching in the field of professional qualification exams all the year round.
Reliable F5CAB4 Test Syllabus: https://www.examprepaway.com/F5/braindumps.F5CAB4.ete.file.html
F5 F5CAB4 Flexible Learning Mode You just need to remain connected to internet for getting updates even on your mobile, F5 F5CAB4 Flexible Learning Mode The software is useable on Windows-based computers and laptops, F5 F5CAB4 Flexible Learning Mode You definitely have to have a try and you will be satisfied without doubt, F5CAB4 PDF version is printable, and you can print them into hard one if you like, and you can also take some notes on them and practice them anytime and anyplace.
Admin: Those are actual problems, These are planning, F5CAB4 Flexible Learning Mode configuration management, requirements management, subcontract management, quality assurance, and the like.
You just need to remain connected to internet for getting updates even on your F5CAB4 mobile, The software is useable on Windows-based computers and laptops, You definitely have to have a try and you will be satisfied without doubt.
Real F5CAB4 Questions With Free Updates C Start Exam Preparation TodayF5CAB4 PDF version is printable, and you can print them into hard one if you like, and you can also take some notes on them and practice them anytime and anyplace.
I dare to make a bet that you will not be exceptional.
Posted at 1/15/2026 22:50:25        Only Author  2#
Im truly grateful for your article, it really stayed in my mind. Good luck to me on my Braindump NP-Con-101 pdf exam! Hoping for great results!
Posted at 1/20/2026 13:17:34        Only Author  3#
Your article is brilliant beyond words, Im thankful for your share! This DP-300 new exam camp file helped me with my promotion and salary raise. Its now available for free to everyone.
Posted at 3/4/2026 15:48:24        Only Author  4#
Thank you for your brilliant article, it really made a lasting impression! Im sharing the Reliable C-P2W22-2504 test cram test that helped me achieve a promotion and raise. It's free for you todaybest of luck in reaching your career goals!
