[General] Platform Developer I (PDI) Testking Cram & PDI Prep Vce & Platform Devel
99
【General】 Platform Developer I (PDI) Testking Cram & PDI Prep Vce & Platform Devel
Posted at 1/15/2026 02:09:00      View:143 | Replies:4        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Exam4Tests PDI dumps from Cloud Storage: https://drive.google.com/open?id=1zF0TVoH5CFUAFoyH-_qNUTqHThrNaSKb
Our PDI preparation quiz are able to aid you enhance work capability in a short time. In no time, you will surpass other colleagues and gain more opportunities to promote. Believe it or not, our PDI study materials are powerful and useful, which can solve all your pressures about reviewing the PDI Exam. You can try our free demo of our PDI practice engine before buying. The demos are free and part of the exam questions and answers.
Our approach to Salesforce PDI Exam Preparation is focused on quality over quantity, which means our Salesforce PDI practice tests help you identify the most important concepts and skills you need to master to pass the exam. We also provide ongoing 24/7 support to help you stay on track while using our product.
Salesforce PDI Latest Dumps & Latest PDI QuestionsIf you do not have access to internet most of the time, if you need to go somewhere is in an offline state, but you want to learn for your PDI exam. Don not worry, our products will help you solve your problem. We deeply believe that our latest PDI Exam Torrent will be very useful for you to strength your ability, pass your exam and get your certification. Our study materials with high quality and high pass rate in order to help you get out of your harassment.
Salesforce PDI certification exam is a 105-minute exam consisting of 60 multiple-choice questions. PDI exam is administered by Salesforce and is available in English, Japanese, and Spanish. PDI exam is computer-based and can be taken at one of the many testing centers located around the world. PDI Exam covers a range of topics such as Apex programming, Visualforce development, data modeling, and database design, among others.
Salesforce Platform Developer I (PDI) Sample Questions (Q100-Q105):NEW QUESTION # 100
Developers at Universal Containers (UC) use version control to share their code changes, but they notice that when they deploy their code to different environments they often have failures. They decide to set up Continuous Integration (CI).
What should the UC development team use to automatically run tests as part of their CI process?
  • A. Developer Console
  • B. Visual Studio Code
  • C. Force.com Toolkit
  • D. Salesforce CLI
NEW QUESTION # 101
A developer is asked to write helper methods that create test data for unit tests.
What should be changed in the TestUtils class so that its methods are only usable by unit test methods?
  • A. Remove static from line 03.
  • B. Change public to private on line 01.
  • C. Add @IsTest above line 03.
  • D. Add @1sTest above line 01.
NEW QUESTION # 102
Universal Containers (UC) wants to lower its shipping cost while making the shipping process more efficient.
The Distribution Officer advises UC to implement global addresses to allow multiple Accounts to share a default pickup address. The developer is tasked to create the supporting object and relationship for this business requirement and uses the Setup Menu to create a custom object called "Global Address".
Which field should the developer add to create the most efficient model that supports the business need?
  • A. Add a master-detail field on the Account object to the Global Address object.
  • B. Add a master-detail field on the Global Address object to the Account object.
  • C. Add a lookup field on the Global Address object to the Account object.
  • D. Add a lookup field on the Account object to the Global Address object.
* Why Lookup on Account to Global Address?
* An Account can reference a single default Global Address via a lookup field, allowing multiple Accounts to share the same address.
* This is more efficient than the reverse (lookup on Global Address to Account), as Global Address is the parent in this relationship.
* Avoiding Master-Detail:
* Lookup relationships provide flexibility in this use case since Accounts and Global Addresses have independent lifecycles.
Example:Create a custom lookup field on Account referencing the Global Address object.
NEW QUESTION # 103
Which three data types can a SOQL query return?
Choose 3 answers
  • A. Double
  • B. sObJect
  • C. List
  • D. Long
  • E. Integer
Answer: B,C,E
NEW QUESTION # 104
Which statement generates a list of Leads and Contacts that have a field with the phrase 'ACME'?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 105
If you want to get a higher position in your company, you must do an excellent work. Then your ability is the key to stand out. Perhaps our PDI study materials can help you get the desirable position. At present, many office workers are willing to choose our PDI study materials to improve their ability. So you can also join them and learn our study materials. You will gradually find your positive changes after a period of practices. Then you will finish all your tasks excellently. You will become the lucky guys if there has a chance. Our PDI Study Materials are waiting for you to have a try.
PDI Latest Dumps: https://www.exam4tests.com/PDI-valid-braindumps.html
Posted at 1/18/2026 02:52:55        Only Author  2#
Your article really made an impact on me, I’m truly grateful. I’m sharing the PEGACPBA24V1 latest associate level exam exam materials for free—best of luck!
Posted at 1/18/2026 03:03:08        Only Author  3#
Such a phenomenal article, I appreciate your sharing it with us. Sharing the New 1z0-076 exam prep test materials with you all—best of luck!
Posted at 1/20/2026 05:03:02        Only Author  4#
I appreciate your article, it was so refreshing and insightful. Upgrade your IT knowledge and access Valid test cram 220-1202 sheet file for free. Wishing you the best of luck!
Posted at 2/16/2026 07:07:23        Only Author  5#
Je früher die Zertifizierung der Cisco 300-745 zu erwerben, desto hilfreicher ist es für Ihre Karriere in der IT-Branche. Vielleicht haben Sie erfahren, dass die Vorbereitung dieser Prüfung viel Zeit oder Gebühren fürs Training braucht. Aber die Cisco 300-745 Prüfungssoftware von uns widerspricht diese Darstellung. Die komplizierte Sammlung und Ordnung der Prüfungsunterlagen der Cisco 300-745 werden von unserer professionellen Gruppen fertiggemacht. Genießen Sie doch die wunderbare Wirkungen der Prüfungsvorbereitung und den Erfolg bei der Cisco 300-745 Prüfung!
