[General] Valid H13-511_V5.5 Exam Vce, Valid Exam H13-511_V5.5 Book
97
【General】 Valid H13-511_V5.5 Exam Vce, Valid Exam H13-511_V5.5 Book
Posted at 1/15/2026 04:03:46      View:135 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamCost H13-511_V5.5 dumps for free: https://drive.google.com/open?id=1cJJiufa2AEuGpfNGQAZ63YuQgtUQrzS7
Most experts agree that the best time to ask for more dough is after you feel your H13-511_V5.5 performance has really stood out. Our H13-511_V5.5 guide materials provide such a learning system where you can improve your study efficiency to a great extent. During the process of using our H13-511_V5.5 Study Materials, you focus yourself on the exam bank within the given time, and we will refer to the real exam time to set your H13-511_V5.5 practice time, which will make you feel the actual H13-511_V5.5 exam environment and build up confidence.
Our H13-511_V5.5 study materials can help you pass the exam faster and take the certificate you want with the least time and efforts. Then you will have one more chip to get a good job. Our H13-511_V5.5 study braindumps allow you to stand at a higher starting point, pass the H13-511_V5.5 Exam one step faster than others, and take advantage of opportunities faster than others. With a high pass rate as 98% to 100%, our H13-511_V5.5 training questions can help you achieve your dream easily.
100% Pass 2026 Useful Huawei H13-511_V5.5: Valid HCIA-Cloud Computing V5.5 Exam VceOur IT professionals have made their best efforts to offer you the latest H13-511_V5.5 study guide in a smart way for the certification exam preparation. With the help of our H13-511_V5.5 dumps collection, all level of candidates can grasp the key content of the real exam and solve the difficulty of H13-511_V5.5 Real Questions easily. The most important is that our test engine enables you practice H13-511_V5.5 exam pdf on the exact pattern of the actual exam.
Huawei HCIA-Cloud Computing V5.5 Sample Questions (Q20-Q25):NEW QUESTION # 20
In Huawei FusionCompute, what is the function of the uplink?
  • A. Connect virtual and physical networks
  • B. Management virtual machine MAC address
  • C. Assign an IP address to the virtual machine
  • D. Detect the status of the virtual network card
NEW QUESTION # 21
Which of the following technologies is used by Open vSwitch (OVS) for remote access and traffic control?
  • A. OpenFlow
  • B. Bidirectional forwarding detection (BFD)
  • C. Network quality analysis (NQA)
  • D. Open vSwitch database (OVSDB)
In the Huawei HCIA-Cloud Computing curriculum, specifically under the "Network Technology Basics" module, Open vSwitch (OVS) is introduced as a key component of software-defined networking (SDN). The primary technology used by OVS for remote access to its control plane and for the programmatic control of traffic flows is OpenFlow.5 OpenFlow is a standard communications protocol that allows an SDN controller (the "brain" of the network) to interact with the forwarding plane (the switch) of a network device.
OpenFlow enables "traffic control" by allowing the controller to define specificflow rules.6These rules tell the switch exactly how to handle packets based on various criteria such as source MAC, destination IP, or TCP port. Instead of the switch making local, autonomous decisions (as a traditional switch does), OVS uses OpenFlow to receive instructions from a centralized management layer. This is how Huawei's cloud infrastructure achieves "remote access" for network orchestration; an administrator can change the network behavior of thousands of virtual machines across multiple physical hosts by pushing new OpenFlow tables from a central controller.
WhileOVSDB(Option B) is also a critical protocol for OVS, its primary role is to manage theconfigurationof the switch (such as creating bridges, adding ports, or setting up tunnels), rather than the "traffic control" or
"flow steering" handled by OpenFlow.BFD(Option C) is used for link failure detection, andNQA(Option D) is a Huawei-specific tool for measuring network performance. In the context of the HCIA exam, OpenFlow is the correct answer for the protocol that enables the intelligent, remote management of data paths in a virtualized network environment.
NEW QUESTION # 22
Which of the following methods can be used for fusion access to collect infrastructure computer logs?
  • A. manually obtaining logs
  • B. fusion care
  • C. TCM
  • D. one click log collection function of fusion access
NEW QUESTION # 23
In Huawei FusionAccess, Huawei Desktop Protocol (HDP) classifies displayed bitmaps. It uses the lossless compression algorithm for text and the lossy compression algorithm for non-sensitive data, saving bandwidth without compromising user experience.
  • A. TRUE
  • B. FALSE
According to the Huawei HCIA-Cloud Computing curriculum, specifically the section on Huawei Desktop Protocol (HDP), the statement provided is FALSE. While the protocol does indeed perform "Intelligent Desktop Recognition" to classify bitmaps and apply different compression algorithms, the classification criteria are based on the image type (content characteristics), not the "sensitivity" of the data.
HDP classifies screen content into two primary categories:Non-natural images(such as text, lines, and desktop window frames) andNatural images(such as photographs, gradients, and video frames). For non-natural images like text, HDP uses alossless compression algorithm. This ensures that the edges of characters remain crisp and readable, preventing the "blurring" effect that can lead to eye strain. For natural images, the protocol uses alossy compression algorithm(such as H.264/H.265 based encoding). This significantly reduces the amount of data transmitted over the network while maintaining a visual quality that is acceptable to the human eye for pictorial content.
The term "non-sensitive data" used in the question is not a technical term within the HDP specification. A user's bank statement (highly sensitive) and a random text document (non-sensitive) would both be compressed using the lossless algorithm because they are both "text" content. Therefore, the compression logic is strictly content-aware to optimize the User Experience (UX) and bandwidth, regardless of the data's security classification. Understanding this distinction is vital for the exam as it highlights Huawei's "Graphics and Text Separation" technology.
NEW QUESTION # 24
Which of the following are functions of FusionCompute?
  • A. Storage live migration is to migrate data within a storage device or between different storage devices.
  • B. VM live migration only allows VMs to migrate among hosts that share the same storage.
  • C. Users can expand or reduce the memory capacity for online or offline VMs as needed.
  • D. Datastores support file system formats VIMS, NFS, and EXT4.
Answer: A,C,D
As detailed in the Huawei HCIA-Cloud Computing technical documentation, FusionCompute offers a robust suite of resource management functions. Statement A is correct: FusionCompute datastores support multiple file system formats to accommodate different storage backends. VIMS (Virtual Image Management System) is Huawei's high-performance cluster file system used for SAN storage; NFS is used for Network Attached Storage; and EXT4 is used for local disk virtualization on a single host. This variety allows administrators to build heterogeneous storage pools.
Statement B is also a verified function. FusionCompute supports dynamic resource adjustment. Users can modify memory capacity for both offline VMs (while the VM is stopped) and online VMs (while running).
Online memory expansion requires the "Hot Add" feature and Guest OS support, while reduction typically requires the VM to be in a state where the kernel can release the address space. Statement C accurately describes Storage Live Migration. This feature allows a VM's virtual disk files to be moved from one datastore to another (or within the same storage device) while the VM remains running, which is essential for storage maintenance and load balancing.
Statement D is incorrect because of the word "only." While traditional VM live migration (vMotion style) does require shared storage so that both hosts can see the same disk, modern versions of FusionCompute also support Shared-Nothing Live Migration. This technology migrates both the VM's memory state and its disk data simultaneously over the network, allowing a VM to move between hosts that do *not* share a common backend storage. Because D ignores this advanced capability, it is excluded from the list of correct functions in the context of FusionCompute's full feature set.
NEW QUESTION # 25
To prepare successfully in a short time, you need a trusted platform of real and updated Huawei H13-511_V5.5 exam dumps. Studying with updated H13-511_V5.5 practice questions improve your skills of clearing the certification test in a short time. ExamCost makes it easy for you to prepare successfully for the H13-511_V5.5 Questions in a short time with H13-511_V5.5 Dumps. The product of ExamCost has been prepared under the expert supervision of thousands of experts worldwide.
Valid Exam H13-511_V5.5 Book: https://www.examcost.com/H13-511_V5.5-practice-exam.html
Huawei Valid H13-511_V5.5 Exam Vce The questions and answers have also been prepared on the pattern of the final exam, The pass rate for Huawei Valid Exam H13-511_V5.5 Book Valid Exam H13-511_V5.5 Book - HCIA-Cloud Computing V5.5 is about 95.49% or so, It is a time that people take on the appearance of competing for better future dramatically (H13-511_V5.5 new questions), As our company's flagship product, it has successfully helped countless candidates around the world to obtain the coveted H13-511_V5.5 certification.
Defining an Error-Logging Database, An organization that enjoys strong identification H13-511_V5.5 among its employees has many ambassadors and advocates and needs less help from PR public relations) experts to project a positive company image.
H13-511_V5.5 braindumps vce & H13-511_V5.5 study torrent & H13-511_V5.5 free questionsThe questions and answers have also been prepared Practice H13-511_V5.5 Test on the pattern of the final exam, The pass rate for Huawei HCIA-Cloud Computing V5.5 is about95.49% or so, It is a time that people take on the appearance of competing for better future dramatically (H13-511_V5.5 New Questions).
As our company's flagship product, it has successfully helped countless candidates around the world to obtain the coveted H13-511_V5.5 certification, This is the online version of the HCIA-Cloud Computing V5.5 (H13-511_V5.5) practice test software.
What's more, part of that ExamCost H13-511_V5.5 dumps now are free: https://drive.google.com/open?id=1cJJiufa2AEuGpfNGQAZ63YuQgtUQrzS7
Posted at 2/18/2026 04:05:34        Only Author  2#
What a remarkable piece of writing, thank you for sharing it. Free 1Z1-947 valid exam passing score available for boosting your IT skills. Wishing you success!
