[General] C-TS422-2023 Best Preparation Materials & C-TS422-2023 Practice Test Fee
88
【General】 C-TS422-2023 Best Preparation Materials & C-TS422-2023 Practice Test Fee
Posted at 1/15/2026 04:58:24      View:126 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 Latest Exam4Labs C-TS422-2023 PDF Dumps and C-TS422-2023 Exam Engine Free Share: https://drive.google.com/open?id=1s5yFrwYgF0H9fXO2eqyiO2tIiG7VBu5u
In order to let you have a deep understanding of our C-TS422-2023 learning guide, our company designed the trial version for our customers. We will provide you with the trial version of our C-TS422-2023 study materials before you buy our products. If you want to know our C-TS422-2023 Training Materials, you can download the trial version from the web page of our company. It is easy and fast to download the free trial version of our C-TS422-2023 exam braindumps.
SAP C-TS422-2023 Exam Syllabus Topics:
  • Production Orders in SAP S
  • 4HANA: This section covers BOM item categorization, order status management, availability checks, routing selection, order type setup, and material handling processes.
  • Master Data in SAP S
  • 4HANA: This section covers the exploration of crucial production-related master data elements, with emphasis on bill of material, routing, and production version.
  • Advanced Planning in SAP S
  • 4HANA: This section includes an overview of advanced planning fundamentals and master data. Explanation of key tools and processes. Discussion of planning evaluation concepts.
  • Introduction to SAP S
  • 4HANA Production Planning: This section covers an overview of production planning components, functions, and planning approaches. Exploration of emerging trends.
Topic 5
  • Process Orders in SAP S
  • 4HANA: This section covers an introduction to process order components, processing, and relevant master data objects. Overview of Good Manufacturing Practices (GMP) features.
Topic 6
  • 4HANA Supply Chain Planning: This part covers the background and motivation for SAP S
  • 4HANA, its main components, business applications, and user experience strategy.
Pass Guaranteed 2026 SAP C-TS422-2023: Unparalleled SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing Best Preparation MaterialsEvery SAP aspirant wants to pass the SAP C-TS422-2023 exam to achieve high-paying jobs and promotions. The biggest issue SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing (C-TS422-2023) exam applicants face is that they don't find credible platforms to buy Real C-TS422-2023 Exam Dumps. When candidates don't locate actual SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing (C-TS422-2023) exam questions they prepare from outdated material and ultimately lose resources.
SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing Sample Questions (Q10-Q15):NEW QUESTION # 10
You have maintained the parameters for simple discontinuation in the material master of a component. Which business process will be affected if the available stock is zero and the discontinuation date is in the past?
  • A. Backflushing
  • B. Material requirements planning
  • C. Kanban
  • D. Production order release
If the available stock is zero and the discontinuation date is in the past, the material requirements planning (MRP) process will be affected. MRP will not create any planned orders or purchase requisitions for the discontinued component. Instead, it will create a discontinuation indicator in the MRP list and a discontinuation message in the exception message list. This will inform the planner that the component is no longer available and that a follow-up material should be used instead. Reference: [SAP Help Portal] - Discontinuation of Materials.
NEW QUESTION # 11
Which standard item categories can you select inside a bill of material (BOM)?
Note: There are 2 correct answers to this question
  • A. Variable-size item
  • B. WBS item
  • C. Non-stock item
  • D. Work item
You can select the following standard item categories inside a bill of material (BOM):
Variable-size item: This item category is used for materials that have variable dimensions, such as pipes, wires, or fabrics. The system calculates the quantity of the variable-size item based on the formula and the dimensions entered in the BOM. You can also use the variable-size item to define a scrap percentage for the material.
Non-stock item: This item category is used for materials that are not managed in inventory, such as consumables, services, or subcontracting items. The system does not create any reservations or stock movements for the non-stock item. You can use the non-stock item to trigger purchasing requisitions or purchase orders for the material. Reference: Bill of Material Item Category; Bills of Material in Production Planning
NEW QUESTION # 12
Which time elements does MRP consider in backward scheduling to determine the order dates for components from dependent requirements?
  • A. In-house production time
  • B. Planned delivery time
  • C. Operation duration
  • D. Total replenishment lead time
Backward scheduling is a method of determining the order dates for components from dependent requirements by starting from the requirement date of the finished product and working backwards through the production structure. Backward scheduling considers the following time elements:
Operation duration: This is the time required to perform an operation on a resource, such as a work center or a machine. Operation duration is influenced by various factors, such as the quantity, the lot size, the setup time, the processing time, the teardown time, and the operation scrap. Operation duration is subtracted from the requirement date of the finished product to determine the start date of the operation.
In-house production time: This is the time required to produce a material in-house, from the start of the first operation to the end of the last operation. In-house production time is influenced by various factors, such as the routing, the work center, the production version, and the scheduling margin key. In-house production time is subtracted from the start date of the first operation to determine the order start date of the material.
Backward scheduling does not consider the following time elements:
Total replenishment lead time: This is the time required to procure a material externally, from the creation of the purchase requisition to the receipt of the goods. Total replenishment lead time is influenced by various factors, such as the planned delivery time, the goods receipt processing time, the release time, and the scheduling margin key. Total replenishment lead time is used in forward scheduling, not backward scheduling, to determine the order dates for externally procured materials.
Planned delivery time: This is the time required to deliver a material from the vendor to the receiving plant. Planned delivery time is maintained in the purchasing info record or the material master record. Planned delivery time is a component of the total replenishment lead time, which is used in forward scheduling, not backward scheduling, to determine the order dates for externally procured materials. Reference: Backward Scheduling | SAP Help Portal, Scheduling | SAP Help Portal, SAP S/4HANA Production Planning and Manufacturing Certification Guide, page 77-78.
NEW QUESTION # 13
What do you need to consider when working with material master numbering in SAP S/4HANA?
  • A. Material numbering is defined at client level.
  • B. Material numbering is defined cross-client.
  • C. The maximum material number length is 18 for external numbers and 18 for internalnumbers.
  • D. The maximum material number length is 40 for external numbers and 18 for internal numbers
Material numbering is the process of assigning unique identifiers to materials in the system. Material numbering is defined at the client level, which means that the same material number can be used for different materials in different clients. However, within a client, the material number must be unique for each material. The material number can be either external or internal. External material numbers are entered manually by the user, while internal material numbers are generated automatically by the system. The maximum material number length is 40 characters for external numbers and 18 characters for internal numbers. The material number length can be customized in the configuration app Define Material Number Lengths1. The material number can also be formatted with prefixes, suffixes, and templates in the configuration app Define Material Number Formats2. Reference: Define Material Number Lengths | SAP Help Portal, Define Material Number Formats | SAP Help Portal
NEW QUESTION # 14
What are the prerequisites for a reporting point confirmation in repetitive manufacturing? Note: There are 2 correct answers to this question.
  • A. Activating the reporting point backflush in the order-dependent parameters
  • B. Activating the reporting point backflush in the work centers
  • C. Defining the operations as reporting points using the control key
  • D. Defining the relevant work centers in the routing
In SAP S/4HANA repetitive manufacturing,reporting point confirmation(e.g., via transaction MFBF) tracks progress at specific milestones. Prerequisites include:
* Activating the reporting point backflush in the work centers(B): The work center (transaction CR02, Basic Data tab, field: Backflush) must have backflushing activated (e.g., "Reporting Point Backflush" indicator). This enables goods movements (e.g., component consumption) at reporting points during confirmation, a key REM feature.
* Defining the operations as reporting points using the control key(D): In the rate routing (CA21), operations designated as reporting points require a control key (field: Control Key) with the "Reporting Point" indicator checked (configured in OPJ8). This marks the operation as a confirmation milestone (e.
g., RP01 control key).
Order-dependent parameters(A) apply to discrete manufacturing (OPL8), not REM, where the REM profile (OSP2) governs backflushing, not reporting points specifically.Defining work centers in the routing(C) is standard but insufficient without the control key specifying reporting points. This is per SAP's REM confirmation process.
NEW QUESTION # 15
Our SAP C-TS422-2023 practice exam simulator mirrors the C-TS422-2023 exam experience, so you know what to anticipate on SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing (C-TS422-2023) certification exam day. Our SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing practice test Exam4Labs features various question styles and levels, so you can customize your SAP C-TS422-2023 Exam Questions preparation to meet your needs.
C-TS422-2023 Practice Test Fee: https://www.exam4labs.com/C-TS422-2023-practice-torrent.html
DOWNLOAD the newest Exam4Labs C-TS422-2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1s5yFrwYgF0H9fXO2eqyiO2tIiG7VBu5u
Posted at 1/15/2026 22:42:54        Only Author  2#
Ihnen bei dem Bestehen der ISACA AAIA Prüfung erfolgreich zu helfen bedeutet die beste Anerkennung unseres Fleißes. Um diesen Wunsch zu verwirklichen verbessern wir die Prüfungsunterlagen der ISACA AAIA immer wieder. Sie können sie beruhigt benutzen. Wenn Sie Fragen über unsere Produkte oder Service haben, können Sie mit uns einfach online kontaktieren oder uns mailen. Nachdem Sie die ISACA AAIA Prüfungsunterlagen gekauft haben, geben wir Ihnen die neueste Informationen über die Aktualisierung per E-Mail.
Posted at 1/16/2026 11:38:29        Only Author  3#
The article left a lasting impression on me. The 712-50 reliable test camp materials exam that helped me get promoted and earn a salary raise is available for you today at no charge. Hope you reach your career targets soon!
Posted at 1/26/2026 18:36:05        Only Author  4#
Through this article, I gained a lot of useful information. The Plat-Arch-206 new study questions book content is truly valuable, and it’s free.
