[General] Nutanix NCM-MCI Valid Test Testking, NCM-MCI Latest Test Question
96
General Nutanix NCM-MCI Valid Test Testking, NCM-MCI Latest Test Question
Posted at 1/15/2026 05:46:18      View249 | Replies4        Print      Only Author   [Copy Link] 1#
Our experts have carefully researched each part of the test syllabus of the NCM-MCI guide materials. Then they compile new questions and answers of the study materials according to the new knowledge parts. At last, they reorganize the NCM-MCI learning questions and issue the new version of the study materials. Once the newest test syllabus of the NCM-MCI Exam appear on the official website, our staff will quickly analyze them and send you the updated version. So our NCM-MCI guide materials deserve your investment.
The need for Nutanix NCM-MCI Exam study materialNutanix NCM-MCI exam is a technical exam. This test requires candidates to have a clear understanding of the architecture and features that are associated with the Nutanix Prism web console and Prism Central. The topics covered in this exam are Networking, Storage, Security, and Cluster Management.
Candidates who plan on taking the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Exam (NCM-MCI) exam are required to take a training course so that they can acquire enough knowledge and skills to pass the exam in one go. If you wish to know more about the training course then you should visit the official website of Nutanix. You will find all the information related to training and certification exams on this site.
Nutanix NCM-MCI Dumps has been a great help for all the IT students. Most of the students have passed their Nutanix Certified Master - Multicloud Infrastructure exam with the help of certification questions. It has become possible due to the ease and accessibility of exam dumps material. These practice test are not only just for passing exams but also for improving skills and having expertise in relevant field. You can have online practice test and see your results yourself. You will be able to know where you are good at and at which points you need to focus more. In this way, you will learn accordingly and will get rid of your weak points. It is a short path to success that can take you to places within no time.
We offer free content demo actual prep tests version. We guarantee of dedicated qualification of sites for administrator receives container objectives.
NCM-MCI Latest Test Question, Answers NCM-MCI Real QuestionsAll time and energy you devoted to the NCM-MCI preparation quiz is worthwhile. With passing rate up to 98 percent and above, our NCM-MCI practice materials are highly recommended among exam candidates. So their validity and authority are unquestionable. Our NCM-MCI Learning Materials are just staring points for exam candidates, and you may meet several challenging tasks or exams in the future about computer knowledge, we can still offer help. Need any help, please contact with us again!
Nutanix Certified Master - Multicloud Infrastructure v6.10 Sample Questions (Q17-Q22):NEW QUESTION # 17
Task 11
An administrator has noticed that after a host failure, the SQL03 VM was not powered back on from another host within the cluster. The Other SQL VMs (SQL01, SQL02) have recovered properly in the past.
Resolve the issue and configure the environment to ensure any single host failure affects a minimal number os SQL VMs.
Note: Do not power on any VMs
See the Explanation for step by step solution
One possible reason why the SQL03 VM was not powered back on after a host failure is that the cluster was configured with the default (best effort) VM high availability mode, which does not guarantee the availability of VMs in case of insufficient resources on the remaining hosts. To resolve this issue, I suggest changing the VM high availability mode to guarantee (reserved segments), which reserves some memory on each host for failover of VMs from a failed host. This way, the SQL03 VM will have a higher chance of being restarted on another host in case of a host failure.
To change the VM high availability mode to guarantee (reserved segments), you can follow these steps:
Log in to Prism Central and select the cluster where the SQL VMs are running.
Click on the gear icon on the top right corner and select Cluster Settings.
Under Cluster Services, click on Virtual Machine High Availability.
Select Guarantee (Reserved Segments) from the drop-down menu and click Save.
To configure the environment to ensure any single host failure affects a minimal number of SQL VMs, I suggest using anti-affinity rules, which prevent VMs that belong to the same group from running on the same host. This way, if one host fails, only one SQL VM will be affected and the other SQL VMs will continue running on different hosts.
To create an anti-affinity rule for the SQL VMs, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Group.
Enter a name for the group, such as SQL Group, and click Next.
Select the SQL VMs (SQL01, SQL02, SQL03) from the list and click Next.
Select Anti-Affinity from the drop-down menu and click Next.
Review the group details and click Finish.
I hope this helps. How else can I help?
https://portal.nutanix.com/page/ ... ity-policies-c.html
NEW QUESTION # 18
Topic 1, Performance Based Questions
Environment
You have been provisioned a dedicated environment for your assessment which includes the following:
Workstation
* windows Server 2019
* All software/tools/etc to perform the required tasks
* Nutanix Documentation and whitepapers can be found in desktop ilesDocumentation
* Note that the workstation is the system you are currently togged into Nutanix Cluster
* There are three clusters provided. The connection information for the relevant cluster will be displayed to the high of the question Please make sure you are working on the correct cluster for each item Please ignore any licensing violations
* Cluster A is a 3-node cluster with Prism Central 2022.6 where most questions will be performed
* Cluster B is a one-node cluster and has one syslog item and one security item to perform
* Cluster D is a one-node duster with Prism Central 5.17 and has a security policy item to perform Important Notes
* If the text is too small and hard to read, or you cannot see an of the GUI. you can increase/decrease the zoom of the browser with CTRL + ,and CTRL + (the plus and minus keys) You will be given 3 hours to complete the scenarios for Nutanix NCMMCI Once you click the start button below, you will be provided with:
- A Windows desktop A browser page with the scenarios and credentials (Desktopinstructions) Notes for this exam delivery:
The browser can be scaled lo Improve visibility and fit all the content on the screen.
- Copy and paste hot-keys will not work Use your mouse for copy and paste.
- The Notes and Feedback tabs for each scenario are to leave notes for yourself or feedback for
- Make sure you are performing tasks on the correct components.
- Changing security or network settings on the wrong component may result in a falling grade.
- Do not change credentials on an component unless you are instructed to.
- All necessary documentation is contained in the DesktopFilesDocumentation directory Task 1 An administrator has been asked to configure a storage for a distributed application which uses large data sets across multiple worker VMs.
The worker VMs must run on every node. Data resilience is provided at the application level and low cost per GB is a Key Requirement.
Configure the storage on the cluster to meet these requirements. Any new object created should include the phrase Distributed_App in the name.
To configure the storage on the cluster for the distributed application, you can follow these steps:
Log in to Prism Element of cluster A using the credentials provided.
Go to Storage > Storage Pools and click on Create Storage Pool.
Enter a name for the new storage pool, such as Distributed_App_Storage_Pool, and select the disks to include in the pool. You can choose any combination of SSDs and HDDs, but for low cost per GB, you may prefer to use more HDDs than SSDs.
Click Save to create the storage pool.
Go to Storage > Containers and click on Create Container.
Enter a name for the new container, such as Distributed_App_Container, and select the storage pool that you just created, Distributed_App_Storage_Pool, as the source.
Under Advanced Settings, enable Erasure Coding and Compression to reduce the storage footprint of the dat a. You can also disable Replication Factor since data resilience is provided at the application level. These settings will help you achieve low cost per GB for the container.
Click Save to create the container.
Go to Storage > Datastores and click on Create Datastore.
Enter a name for the new datastore, such as Distributed_App_Datastore, and select NFS as the datastore type. Select the container that you just created, Distributed_App_Container, as the source.
Click Save to create the datastore.
The datastore will be automatically mounted on all nodes in the cluster. You can verify this by going to Storage > Datastores and clicking on Distributed_App_Datastore. You should see all nodes listed under Hosts.
You can now create or migrate your worker VMs to this datastore and run them on any node in the cluster. The datastore will provide low cost per GB and high performance for your distributed application.
NEW QUESTION # 19
Task 12
An administrator needs to create a report named VMs_Power_State that lists the VMs in the cluster and their basic details including the power state for the last month.
No other entities should be included in the report.
The report should run monthly and should send an email to admin@syberdyne.net when it runs.
Generate an instance of the report named VMs_Power_State as a CSV and save the zip file as DesktopFilesVMs_Power_state.zip Note: Make sure the report and zip file are named correctly. The SMTP server will not be configured.
To create a report named VMs_Power_State that lists the VMs in the cluster and their basic details including the power state for the last month, you can follow these steps:
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter VMs_Power_State as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, Cluster Name, vCPUs, Memory, Power State. Click Next.
Under the Time Period option, select Last Month. Click Next.
Under the Report Settings option, select Monthly from the Schedule drop-down menu. Enter admin@syberdyne.net as the Email Recipient. Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
To generate an instance of the report named VMs_Power_State as a CSV and save the zip file as DesktopFilesVMs_Power_state.zip, you can follow these steps:
Log in to Prism Central and click on Operations on the left menu.
Select Reports from the drop-down menu and find the VMs_Power_State report from the list. Click on Run Now.
Wait for the report to be generated and click on Download Report. Save the file as DesktopFilesVMs_Power_state.zip.
1.        Open the Report section on Prism Central (Operations > Reports)
2.        Click on the New Report button to start the creation of your custom report
3.        Under the Custom Views section, select Data Table
4.        Provide a title to your custom report, as well as a description if required.
5.        Under the Entity Type option, select VM
6.        This report can include all as well as a selection of the VMs
7.        Click on the Custom Columns option and add the below variables:
a.        Name - Name of the listed Virtual Machine
b.        vCPUs - A combination of the vCores and vCPU's assigned to the Virtual Machine c.        Memory - Amount of memory assigned to the Virtual Machine d.        Disk Capacity - The total amount of assigned virtual disk capacity e.        Disk Usage - The total used virtual disk capacity f.        Snapshot Usage - The total amount of capacity used by snapshots (Excluding Protection Domain snapshots)
8.        Under the Aggregation option for Memory and Disk Usage accept the default Average option
9.        Click on the Add button to add this custom selection to your report
10.        Next click on the Save and Run Now button on the bottom right of the screen
11.        Provide the relevant details on this screen for your custom report:
12.        You can leave the Time Period For Report variable at the default of Last 24 Hours
13.        Specify a report output of preference (PDF or CSV) and if required Additional Recipients for this report to be mailed to. The report can also simply be downloaded after this creation and initial run if required
14.        Below is an example of this report in a CSV format:
NEW QUESTION # 20
Task1
A newly created Windows VM "SQL02" is experiencing poor storage performance when compared to "SQL01" running within the same cluster, on the same storage container.
The cluster is in a healthy state.
Create a new session named Monitor SQL02 with meaningful metrics. Right click on the session page and click Select All then paste this into Notepad and save it as Task 1.txt on the desktop.
Also, save the analysis as a report named "MonitorSQL02" and send the report as a PDF on a daily basis to perf_group@ACME.org. Reports should not be retained. If any new objects need to be created, use monitorvm2 in the name.
Finally, correct the issue within "SQL02"
Notes:
Do not power on the VMs.
While you will be creating a session, you will need to examine the VM configurations to determine the issue.
Do not delete the VM to resolve the issue, any other destructive change is acceptable
See the Explanation
This is a classic Nutanix performance troubleshooting scenario. The issue is almost certainly that the VM was created using the wrong Disk Bus Type (IDE or SATA instead of SCSI).
Here is the step-by-step solution to complete Task 1.
Part 1: Analysis and Reporting
Create the Session
Log in to Prism Central (or Prism Element, depending on the exam environment, but Analysis is usually a PC feature).
Navigate to Operations -> Analysis.
Click New Session.
Entity: Search for and select the VM named SQL02.
Metrics: Since the issue is storage performance, search for and add these specific metrics:
Hypervisor IOPS (or Controller IOPS)
Hypervisor IO Latency (or Controller IO Latency)
Hypervisor IO Bandwidth
Click Save.
Save Session Data (Task 1.txt)
Open the "Monitor SQL02" session you just created.
(Per instructions): Right-click anywhere on the chart/data area -> Click Select All.
Copy the selected text (Ctrl+C).
Open Notepad on the provided desktop.
Paste the data.
Save the file as Task 1.txt on the Desktop.
Create and Schedule the Report
While still in the Analysis session, click the Create Report (or "Add to Report") button.
Report Name: MonitorSQL02
Report Settings:
Format: PDF
Frequency: Daily
Email Recipient: perf_group@ACME.org
Retention: 0 (or "Do not retain", as requested).
Note: If the system forces you to create a new Report object and MonitorSQL02 is rejected, use monitorvm2 as the name per the instructions.
Save/Schedule the report.
Part 2: Diagnose and Fix the Issue
The Issue:
VM SQL02 was likely created with its data disks set to IDE or SATA.
Why this causes poor performance: IDE/SATA are emulated hardware with high CPU overhead and low queue depths (single-threaded).
The Standard: SQL01 (the healthy VM) is using SCSI, which is multithreaded and optimized for virtualization.
The Fix (Steps):
Navigate to the VM list in Prism.
Select SQL02 and click Update (or Edit).
Scroll down to the Disks section.
Identify the data disk(s). You will see the Bus Type listed as IDE or SATA.
Do not delete the VM. instead, perform a disk conversion (destructive change to the disk is allowed, but we want to keep the data).
Method to Convert (Clone to SCSI):
Hover over the IDE/SATA disk to see the path/filename of the vDisk (or write it down).
Click Add New Disk.
Operation: select Clone from ADSF file.
Path: Browse to the storage container and select the file associated with the current IDE disk.
Bus Type: Select SCSI (This is the critical fix).
Index: Ensure it doesn't conflict with existing disks (usually index 1 or higher for data).
Click Add.
Once the new SCSI disk is added, find the original IDE/SATA disk and click the X to remove it.
Click Save.
Note: You do not need to power on the VM to verify. The change from IDE to SCSI allows the VM to use the Nutanix VirtIO drivers for maximum storage performance.
NEW QUESTION # 21
Task 15
An administrator found a CentOS VM, Cent_Down, on the cluster with a corrupted network stack. To correct the issue, the VM will need to be restored from a previous snapshot to become reachable on the network again.
VM credentials:
Username: root
Password: nutanix/4u
Restore the VM and ensure it is reachable on the network by pinging 172.31.0.1 from the VM.
Power off the VM before proceeding.
To restore the VM and ensure it is reachable on the network, you can follow these steps:
Log in to the Web Console of the cluster where the VM is running.
Click on Virtual Machines on the left menu and find Cent_Down from the list. Click on the power icon to power off the VM.
Click on the snapshot icon next to the power icon to open the Snapshot Management window.
Select a snapshot from the list that was taken before the network stack was corrupted. You can use the date and time information to choose a suitable snapshot.
Click on Restore VM and confirm the action in the dialog box. Wait for the restore process to complete.
Click on the power icon again to power on the VM.
Log in to the VM using SSH or console with the username and password provided.
Run the command ping 172.31.0.1 to verify that the VM is reachable on the network. You should see a reply from the destination IP address.
Go to VMS from the prism central gui
Select the VMand go to More -> Guest Shutdown
Go to Snapshots tab and revert to latest snapshot available
power on vm and verify if ping is working
NEW QUESTION # 22
Before the clients purchase our NCM-MCI study practice guide, they can have a free trial freely. The clients can log in our company's website and visit the pages of our products. The pages of our products lists many important information about our NCM-MCI exam materials and they include the price, version and updated time of our products, the exam name and code, the total amount of the questions and answers, the merits of our NCM-MCI useful test guide and the discounts. You can have a comprehensive understanding of our NCM-MCI useful test guide after you see this information.
NCM-MCI Latest Test Question: https://www.prep4away.com/Nutanix-certification/braindumps.NCM-MCI.ete.file.html
Posted at 1/17/2026 23:42:13        Only Author  2#
It was incredibly enriching. This Valid exam UiAAAv1 questions answers helped me secure a promotion and salary increase. Now its free for everyone. Best wishes for your career advancement!
Posted at 1/28/2026 10:10:19        Only Author  3#
This article is incredible, thank you for sharing such brilliance! The Valid Revenue-Cloud-Consultant-Accredited-Professional soft simulations content is fantastic, and you can access it freely.
Posted at 2/18/2026 12:37:48        Only Author  4#
The article was a real source of knowledge for me. This is the Reliable CIMAPRA19-F03-1 test cost exam that helped me advance in my career with a promotion and raise. Its free today for all of you. Wishing you success!
Posted at 2/21/2026 09:19:35        Only Author  5#
The article is truly inspiring, thank you for posting it! Upgrade your IT knowledge with free COG170 reliable study guide free download. Wishing you all the best!
