[General] Exam Topics AAPC-CPC Pdf | AAPC-CPC Vce Download
76
General Exam Topics AAPC-CPC Pdf | AAPC-CPC Vce Download
Posted at 1/15/2026 05:52:03      View168 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that SureTorrent AAPC-CPC dumps now are free: https://drive.google.com/open?id=1X8YsXN2tJHVF9rTfCuCRXtCSgKuQrY8d
SureTorrent regularly updates American Academy of Professional Coders: Certified Professional Coder (AAPC-CPC) practice exam material to ensure that it keeps in line with the test. In the same way, SureTorrent provides a free demo before you purchase so that you may know the quality of the AAPC-CPC dumps. Similarly, the Medical Tests AAPC-CPC practice test creates an actual exam scenario on each and every step so that you may be well prepared before your actual AAPC-CPC examination time. Hence, it saves you time and money. SureTorrent provides three months of free updates if you purchase the Medical Tests AAPC-CPC questions and the content of the examination changes after that.
Do you want to pass the AAPC-CPC exam and get the certificate? If you want to pass the exam easily, come to learn our AAPC-CPC study materials. Our AAPC-CPC learning guide is very excellent, which are compiled by professional experts who have been devoting themself to doing research in this career for over ten years. I can say that no one can know more than them. So they know evey detail of the AAPC-CPC Exam Questions, and they will adopt the advices of our loyal customers to make better.
AAPC-CPC Vce Download, AAPC-CPC Exam Questions AnswersIf you purchase our American Academy of Professional Coders: Certified Professional Coder guide torrent, we can make sure that you just need to spend twenty to thirty hours on preparing for your exam before you take the exam, it will be very easy for you to save your time and energy. So do not hesitate and buy our AAPC-CPC study torrent, we believe it will give you a surprise, and it will not be a dream for you to pass your American Academy of Professional Coders: Certified Professional Coder exam and get your certification in the shortest time.
Medical Tests American Academy of Professional Coders: Certified Professional Coder Sample Questions (Q111-Q116):NEW QUESTION # 111
A male patient with cancerous cells in his right bronchus is given 150 mg of porfimer sodium via a single and slow intravenous injection and told to return to the office in 3 days.
Upon his return, the physician enters the right bronchus by means of a bronchoscope and activates LED for a total of 38 minutes to destroy the cancer cells. What should the physician report?
  • A. 96573, 96409, J9600x2
  • B. 31641, 96570, 96571, 96409,J9600x2
  • C. 96573, J9600x2
  • D. 31641, 96570, 96571, J9600x2
Photodynamic therapy applies a photosensitizing agent by either an external or endoscopic application. An external application is applied directly onto a patient's lesions, whereas an endoscopic application is an injection into the bloodstream, where it is absorbed by cells all over the body. Based on this differentiation, the documentation supports only an endoscopic application.
The code notes for CPT 96570 and 96571 indicate they are add-on codes to the bronchoscopy procedure, which is represented by CPT 31641. Any drug administration is inclusive to photodynamic therapy, making CPT 96409 not separately billable.
NEW QUESTION # 112
Which healthcare professional may NOT report medical nutrition therapy?
  • A. Registered nurse
  • B. Nutritionist
  • C. Dietician
  • D. Endocrinologist
Medical nutrition therapy describes nutritional assessments and interventions in a face-to- face or group patient setting and is reported with CPT codes 97802-97804. These codes are used by nonphysician healthcare professionals only. When a physician provides nutritional advice, a preventative service or evaluation and management code should be reported.
NEW QUESTION # 113
An extracapsular cataract extraction procedure was performed on a patient with a clouded and discolored lens. The physician uses iris hooks in the right pupil to ensure safe and controlled access to the cataract and blue staining dye to visualize the capsulorhexis. Using suction, the existing lens capsule is removed, and an intraocular lens is inserted. What should the physician report?
  • A. 66984-RT, H26.8
  • B. 66984-RT, H18.891
  • C. 66982-RT, Q12.8
  • D. 66982-RT, H27.8
When deciding between a routine extracapsular cataract removal and a complex extracapsular cataract removal, bear in mind the code descriptor for a complex procedure involves
"devices or techniques not generally used in a routine cataract surgery (e.g., iris expansion device)." Because iris hooks were used, the procedure is complex (CPT 66982). When it comes to the diagnosis, do not get confused with the anatomy of the eye. Although the cornea works with the lens to help refract light, they are anatomically separate, thus eliminating answer B as an acceptable choice. A congenital condition is one that is genetic and/or present from birth. The documentation does not specifiy the origin, nor does it indicate when the lens abnormality began. Symptoms of a cataract include clouded and discolored lenses but should not be reported unless the physician clearly identifies this as the diagnosis. Coding crosswalk for diseases of the lens leads a coder to H27.8 (other specified disorders of lens).
NEW QUESTION # 114
A provider documents that he spent 20 minutes with a patient. Based on this, an E/M can be chosen solely based on time.
  • A. True
  • B. False
The statement is true. According to AMA time documented is considered the minimum time the physician or other qualified health care professional spent on face-to-face and non-face-to-face services. This includes time spent reviewing the patient's medical record, consulting other healthcare professionals, or ordering prescriptions, tests, and/or other services.
NEW QUESTION # 115
Assign the appropriate CPT codes for the following surgical note: A 15-year-old patient is being treated for obstructive sleep apnea and adenoid tissue hypertrophy. After being placed under general anesthesia, a dental mirror is placed in the oropharynx to allow visualization of the nasopharynx. Suction electrocautery is used to remove the adenoid tissue that regrew after the initial adenoidectomy. Attention is then turned to the tonsils. The plane of tissue between the tonsillar capsule and the underlying muscles are cauterized, and the tonsils are removed. Bleeding is controlled by silver nitrate and gauze packing. Procedure is completed without complications, and patient is discharged to recovery.
  • A. 42999, 647.33, 135.2
  • B. 42826, 42836-51, 135.2, G47.33
  • C. 42821, G47.33, 135.2
  • D. 42826, 42831-59, 135.2, G47.33
An adenoidectomy and a tonsillectomy were performed in this surgical encounter (the root word -ectomy literally means the surgical removal of an anatomical structure). The adenoidectomy was done first and, if coded alone, would fall under one of Evo categories: primary (CPT 42830-
42831) or secondary (CPT 42835-42836). A primary adenoidectomy refers to the initial removal of the adenoid, whereas a secondary adenoidectomy occurs when adenoid tissue that was once removed has grown back. Because the documentation states that "the adenoid tissue ... regrew after the initial adenoidectomy," a coder can infer that this procedure is secondary. However, distinguishing betvveen the two procedures is not necessary when done in conjunction with a tonsillectomy because the procedures are bundled into two nonspecific CPT codes (42820 and
42821). Billing for an adenoidectomy and a tonsillectomy separately, as shown in answers A and C, is considered unbundling and is not allowed under the Correct Coding Initiative (CCI) edits.
Regarding the sequencing of the diagnoses, ICD-IO-CM guidelines state that when V,vo conditions meet the definition for principal diagnosis, either can be sequenced first In this scenario, J 35.2 or G47.33 could have been first listed because the procedures were to resolve both conditions in the same encounter.
NEW QUESTION # 116
You can overcome this hurdle by selecting real Medical Tests AAPC-CPC Exam Dumps that can help you ace the AAPC-CPC test quickly on the maiden endeavor. If you aspire to earn the Medical Tests AAPC-CPC Certification then obtaining trusted prep material is the most significant part of your AAPC-CPC test preparation.
AAPC-CPC Vce Download: https://www.suretorrent.com/AAPC-CPC-exam-guide-torrent.html
Medical Tests Exam Topics AAPC-CPC Pdf Are you still worried about you exam, Medical Tests Exam Topics AAPC-CPC Pdf It is our explicit aim to help you pass it, Our AAPC-CPC Vce Download pass guide is designed to solve all the difficulties of the candidates in the best possible way, So please don't worry about this question you will get the latest AAPC-CPC test dumps one year, Our Medical Tests AAPC-CPC study material provides you with per-trying experience.
Project these sample slides and review the colors with key decision AAPC-CPC makers, In this regard, you will make use of the show ip route command to get a list of all the routes which have been configured.
High-quality Exam Topics AAPC-CPC Pdf - Pass AAPC-CPC Once - Complete AAPC-CPC Vce DownloadAre you still worried about you exam, It is our explicit aim to help AAPC-CPC Exam Syllabus you pass it, Our Medical Certification pass guide is designed to solve all the difficulties of the candidates in the best possible way.
So please don't worry about this question you will get the Latest AAPC-CPC Test Dumps one year, Our Medical Tests AAPC-CPC study material provides you with per-trying experience.
2026 Latest SureTorrent AAPC-CPC PDF Dumps and AAPC-CPC Exam Engine Free Share: https://drive.google.com/open?id=1X8YsXN2tJHVF9rTfCuCRXtCSgKuQrY8d
Posted at 1/27/2026 06:17:02        Only Author  2#
The content is too good not to like. This is the New JN0-232 dumps files test that helped me secure a promotion and raise. It's free for everyone todaywishing you all the best in your career!
Posted at 2/19/2026 07:42:02        Only Author  3#
Perfectly executed content, like button pressed. I got promoted and received a raise thanks to the Premium LEED-Green-Associate files. Now, Im sharing it for free with everyone. Wishing you success in your career journeys!
