Cisco 350-801 Exam Questions - Pass With Confidence!
Posted at 1/15/2026 06:12:21
View260
Replies6
DOWNLOAD the newest BraindumpsIT 350-801 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16-2U7lFRo7mwouGvKCas0ARF2Uhg8Mfu
The experts in our company are always keeping a close eye on even the slightest change on the 350-801 exam questions in the field. Therefore, we can assure that you will miss nothing needed for the 350-801 exam. What's more, the latest version of our 350-801 Study Materials will be a good way for you to broaden your horizons as well as improve your skills. You will certainly obtain a great chance to get a promotion in your company.
Cisco 350-801 (Implementing and Operating Cisco Collaboration Core Technologies) Certification Exam is an industry-recognized certification that tests the candidate's knowledge and skills in implementing and operating Cisco Collaboration Core Technologies. Implementing and Operating Cisco Collaboration Core Technologies certification exam is a part of the Cisco Certified Network Professional (CCNP) Collaboration certification. Candidates who Pass 350-801 Exam will demonstrate their competency in implementing and operating Cisco Collaboration solutions including Cisco Unified Communications Manager (UCM), Cisco Unity Connection, Cisco Unified Contact Center Express (UCCX), and Cisco Meeting Server.
Pass Guaranteed Quiz 2026 Efficient Cisco Cert 350-801 ExamJust install the Implementing and Operating Cisco Collaboration Core Technologies (350-801) PDF dumps file on your desktop computer, laptop, tab, or even on your smartphone and start Implementing and Operating Cisco Collaboration Core Technologies (350-801) exam preparation anytime and anywhere. Whereas the other two Implementing and Operating Cisco Collaboration Core Technologies (350-801) exam questions formats are concerned both are the easy-to-use and compatible Mock 350-801 Exam that will give you a real-time environment for quick Cisco Exams preparation. Now choose the right Cisco 350-801 exam questions format and start this career advancement journey.
Cisco Implementing and Operating Cisco Collaboration Core Technologies Sample Questions (Q178-Q183):NEW QUESTION # 178
Which codec should an engineer select for a call made between "Dallas-REG' & "Austin-REG'?
- A. MP4A-LATM
- B. G.729
- C. G.711
- D. OPUS
The codec preference list for the "Dallas-REG" region is "Factory Default low loss".
This list includes the following codecs in order of preference:
G. 729
G. 711
OPUS
MP4A-LATM
The codec preference list for the "Austin-REG" region is "Factory Default low loss". This list includes the following codecs in order of preference:
G. 729
G. 711
OPUS
MP4A-LATM
Since both regions have the same codec preference list, the codec that will be used for a call made between "Dallas-REG" and "Austin-REG" is G.729.
G. 729 is a narrowband speech codec that was developed by the ITU-T in 1988. It is a low-bitrate codec that provides good quality speech at a bitrate of 8 kbps. G.729 is widely used in VoIP applications and is the default codec for many VoIP systems.
G. 711 is a wideband speech codec that was developed by the ITU-T in 1972. It is a high-bitrate codec that provides excellent quality speech at a bitrate of 64 kbps. G.711 is not as widely used as G.729 due to its high bitrate requirements.
OPUS is a lossy audio codec that was developed by the IETF in 2012. It is a low-bitrate codec that provides good quality speech at a bitrate of 6 kbps. OPUS is widely used in VoIP applications and is the default codec for many VoIP systems.
MP4A-LATM is a lossy audio codec that was developed by the IETF in 1999. It is a high-bitrate codec that provides excellent quality speech at a bitrate of 24 kbps. MP4A-LATM is not as widely used as G.729 or OPUS due to its high bitrate requirements.
NEW QUESTION # 179
What is a description of the DiffServ model used for implementing QoS?
- A. AF43 has higher drop precedence than AF42 but lower drop precedence than AF41.
- B. RTP traffic from voice and video calls is marked EF and placed in the same queue.
- C. AF41 has higher drop precedence than AF42. which has higher drop precedence than AF43.
- D. Voice and video calls are marked with different DSCP values and placed in different queues.
NEW QUESTION # 180
Refer to the exhibit. A customer reports that MTP resources are being used in the recently deployed Cisco UCM and wants no MTP resources to be used. Cisco UCM SIP trunk configuration does not have the MTP Required box checked. Which configuration change resolves the issue?
- A. Change Cisco UCM SIP trunk DTMF Signaling Method to "sip-notify".
- B. Change Cisco UCM SIP trunk DTMF Signaling Method to "sip-kpml".
- C. Change Cisco Unified Border Element configuration to "dtmf-relay rtp-nte".
- D. Change Cisco Unified Border Element configuration to "dtmf-relay sip-notify sip-kpml".
In this scenario, the Media Termination Point (MTP) is being used despite the "MTP Required" option not being checked on the SIP trunk. One common reason for this is a mismatch in the DTMF relay method between Cisco Unified Border Element (CUBE) and Cisco Unified Communications Manager (CUCM).
The current CUBE configuration uses dtmf-relay sip-notify, while CUCM is set to use RFC 2833, which is equivalent to rtp-nteon CUBE. These two methods are incompatible, leading to MTP invocation to bridge the mismatch.
To resolve this, you should configure CUBE to use dtmf-relay rtp-nte, ensuring that both sides use RFC 2833 for DTMF signaling, preventing unnecessary MTP usage.
NEW QUESTION # 181
Refer to the exhibit. When making a call to a MRA client, what are the combinations of protocol on each of the different sections A-B-C?
- A. SIP TCP/TLS +SIP TCP/TLS (B) + SIP TCP/TLS (C)
- B. IP TCP/TLS(A) +SIP TCP/TLS (B) +TLS (C)
- C. SIP TLS (A) +SIP TLS (B) +SIP TLS (C)
- D. SIP TCP/TLS (A) + SIP TLS (B) + SIP TLS (C)
https://www.cisco.com/c/dam/en/u ... y/config_guide/X12-
5/Cisco-Expressway-IP-Port-Usage-for-Firewall-Traversal-Deployment-Guide-X12-5.pdf
NEW QUESTION # 182
Refer to the exhibit. An administrator accesses the terminal of a Cisco UCM and starts a packet capture. Which two commands must the administrator use on Cisco UCM to generate DNS traffic? (Choose two.)
- A. utils ntp status
- B. show version active
- C. show cdp neighbor
- D. utils diagnose test
- E. autils diagnose module validate Network
Answer: D,E
NEW QUESTION # 183
The benefits after you pass the test 350-801 certification are enormous and you can improve your social position and increase your wage. Our 350-801 study materials will help you gain the success in your career. You can be respected and enjoy the great fame among the industry. When applying for the jobs your resumes will be browsed for many times and paid high attention to. The odds to succeed in the job interview will increase. So you could see the detailed information of our 350-801 Study Materials before you decide to buy them.
Reliable 350-801 Exam Voucher: https://www.braindumpsit.com/350-801_real-exam.html
- Exam 350-801 Demo 🔖 Pass 350-801 Guaranteed ⛰ Exam 350-801 Demo ⬜ Open [url]www.examcollectionpass.com enter 350-801 and obtain a free download 🐍350-801 Practice Online[/url]
- 350-801 Reliable Test Answers ⤴ Valid 350-801 Test Cost 🐦 Exam 350-801 Demo 🍢 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for ▛ 350-801 ▟ for free download 🥺350-801 Certification Exam Cost[/url]
- 350-801 Dumps VCE: Implementing and Operating Cisco Collaboration Core Technologies - 350-801 exam torrent 🔳 Easily obtain 350-801 for free download through ▷ [url]www.examcollectionpass.com ◁ 💏Sample 350-801 Exam[/url]
- 350-801 Practice Online 🔺 350-801 Exam Voucher 📠 350-801 Practice Engine 🚈 Easily obtain free download of ⮆ 350-801 ⮄ by searching on ➤ [url]www.pdfvce.com ⮘ 🏃350-801 Reliable Test Labs[/url]
- Quiz 2026 Trustable Cisco 350-801: Cert Implementing and Operating Cisco Collaboration Core Technologies Exam 😽 Search for ➽ 350-801 🢪 on ➤ [url]www.easy4engine.com ⮘ immediately to obtain a free download 😗Valid Exam 350-801 Braindumps[/url]
- 350-801 Practice Engine 🟨 350-801 Reliable Test Labs ♿ 350-801 Relevant Questions 🛣 Open website ⇛ [url]www.pdfvce.com ⇚ and search for ▶ 350-801 ◀ for free download 🏙Valid 350-801 Test Cost[/url]
- Valid 350-801 Test Cost 🕤 350-801 Practice Engine 🏸 Exam 350-801 Demo 😳 Search on ☀ [url]www.exam4labs.com ️☀️ for ⮆ 350-801 ⮄ to obtain exam materials for free download 🥽New 350-801 Test Blueprint[/url]
- Exam 350-801 Demo 💺 350-801 Practice Online 🤼 350-801 Certification Exam Cost 🐜 Search for ☀ 350-801 ️☀️ and obtain a free download on ▶ [url]www.pdfvce.com ◀ 📭350-801 Practice Engine[/url]
- 350-801 Pdf Free 🔲 Latest 350-801 Exam Format 🍂 350-801 Premium Files 📪 Search for 350-801 and download it for free on ✔ [url]www.examdiscuss.com ️✔️ website 🥴350-801 Exams Collection[/url]
- 350-801 Exam Cert Exam - The Best Accurate Reliable 350-801 Exam Voucher Pass Success 😕 Open website [url]www.pdfvce.com and search for ⮆ 350-801 ⮄ for free download ✒Valid 350-801 Test Cost[/url]
- Valid Exam 350-801 Braindumps ➡️ 350-801 Reliable Test Answers 🏭 350-801 Exam Engine 😲 ⏩ [url]www.pdfdumps.com ⏪ is best website to obtain ➽ 350-801 🢪 for free download 🥪350-801 Practice Online[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest BraindumpsIT 350-801 PDF Dumps and 350-801 Exam Engine Free Share: https://drive.google.com/open?id=16-2U7lFRo7mwouGvKCas0ARF2Uhg8Mfu
