[General] Top 4A0-D01 Vce File & Top Nokia Certification Training - Useful Nokia Nokia
84
General Top 4A0-D01 Vce File & Top Nokia Certification Training - Useful Nokia Nokia
Posted at 1/15/2026 06:30:49      View240 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New 4A0-D01 dumps are available on Google Drive shared by TestPassKing: https://drive.google.com/open?id=1lVmmXSAvCqAQP5fyuzCW6enVRbGdyTw0
If you want to pass the exam in the shortest time, our 4A0-D01 study materials can help you achieve this dream. Our 4A0-D01 learning quiz according to your specific circumstances, for you to develop a suitable schedule and learning materials, so that you can prepare in the shortest possible time to pass the exam needs everything. If you use our 4A0-D01 training prep, you only need to spend twenty to thirty hours to practice our 4A0-D01 study materials, then you are ready to take the exam and pass it successfully.
Nokia 4A0-D01 Exam Syllabus Topics:
  • This section of the exam measures skills of a Network Automation Specialist and introduces the principles of Event Driven Automation in SR Linux environments. It covers integration with Kubernetes and explores core use cases such as intent-based automation for fabrics and services, as well as enhanced network observability.
  • Module 5 C EDA (Event Driven Automation) Introduction
  • SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
  • SR Linux Logging, Monitoring, and Filtering: This section of the exam measures skills of a Data Center Network Engineer and addresses how to implement logging, monitoring, and traffic filtering in SR Linux. It explains log file usage, ACL types, CPM filtering, and packet capture filters. Configuration tasks involve applying ACLs and monitoring network activity using capture tools.
Topic 5
  • SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
Formal Nokia 4A0-D01 Test | 4A0-D01 Practice Exams FreeClients always wish that they can get immediate use after they buy our 4A0-D01 Test Questions because their time to get prepared for the exam is limited. Our 4A0-D01 test torrent wont let the client wait for too much time and the client will receive the mails in 5-10 minutes sent by our system. Then the client can log in and use our software to learn immediately. It saves the clients time.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q31-Q36):NEW QUESTION # 31
Examine the exhibit. Which of the following statements is TRUE?
  • A. The next-hop group for this static route is configured with two next-hops.
  • B. A recursive lookup is performed to resolve 10.1.1.0 to use 10.2.1.0.
  • C. A recursive lookup is performed to resolve 10.2.1.0 to use 10.1.1.0.
  • D. The next-hop selected for this route will be based on the preference value configured for each next-hop.
The static route shows two next-hop IP addresses (10.1.1.0 and 10.2.1.0) listed, indicating that a next-hop group with multiple next-hops is configured for load balancing or redundancy.
NEW QUESTION # 32
Which of the following statements about using BFD with BGP is FALSE?
  • A. It can help rapidly detect link failures.
  • B. Using BFD can speed up the BGP advertisement interval.
  • C. The BFD endpoints agree on the send/receive rate of control packets.
  • D. BGP is notified if several BFD control packets are missed.
BFD helps detect link failures rapidly and notifies BGP to trigger route updates quickly, but it does not speed up the BGP advertisement interval itself. BGP advertisement intervals are controlled by BGP timers, not by BFD.
NEW QUESTION # 33
Which of the following is NOT a function of Nokia's SR Linux application manager?
  • A. It monitors the health of all applications.
  • B. It reads the application's configuration information and starts each application.
  • C. It manages the SR Linux and customer-defined applications.
  • D. It translates the application's YANG model into protobufs for the IDB.
The SR Linux application manager does not perform the function of translating an application's YANG model into protobufs for the Interface DataBase (IDB). Its primary roles are managing applications, reading their configuration, and monitoring their health.
NEW QUESTION # 34
Based on the exhibit output, what CLI command can be used to display the contents of "bgp-log" in Nokia's SR Linux?
  • A. info system logging file bgp-log
  • B. show system logging buffer bgp-log
  • C. show system logging file bgp-log
  • D. info system logging buffer bgp-log
The "bgp-log" is defined as a log file in the configuration, so the correct command to display its contents is show system logging file bgp-log.
NEW QUESTION # 35
Based on the exhibit output, which of the following statements is TRUE?
  • A. An ACL filter is configured to accept ICMP packets, which are then processed by the tcpdump-like utility.
  • B. A cpm-filter is configured to accept ICMP packets, which are then captured in a log file.
  • C. capture-filter is configured to copy ICMP packets to the CPM where they are processed by the tcpdump-like utility.
  • D. A cpm-filter policer is configured to rate limit ICMP packets, which are then captured in a log file.
The exhibit shows ICMP packets being captured and displayed by a tcpdump-like utility, which indicates that a capture-filter is configured to copy ICMP packets to the Control Plane Manager (CPM) where they are processed and monitored.
NEW QUESTION # 36
The Practice Exam software is specially made for the students so they can feel real-based examination scenarios and feel some pressure on their brains and don't feel excessive issues while giving the final Nokia exam. There are a lot of customers that are currently using Nokia Data Center Fabric Fundamentals Exam (4A0-D01) and are satisfied with it. TestPassKing has designed this product after getting positive feedback from professionals and is rated one of the best study materials for the preparation of the Nokia 4A0-D01 exam.
Formal 4A0-D01 Test: https://www.testpassking.com/4A0-D01-exam-testking-pass.html
2026 Latest TestPassKing 4A0-D01 PDF Dumps and 4A0-D01 Exam Engine Free Share: https://drive.google.com/open?id=1lVmmXSAvCqAQP5fyuzCW6enVRbGdyTw0
Posted at 1/19/2026 14:03:42        Only Author  2#
This article is a real treasure, thank you for sharing it with us. Heres the free Valid D-PSC-DY-23 test book test content. Wishing you success!
Posted at 1/24/2026 10:01:19        Only Author  3#
DASCA SDS덤프구매에 관심이 있는데 선뜻 구매결정을 하지 못하는 분이라면 사이트에 있는 demo를 다운받아 보시면DASCA SDS시험패스에 믿음이 생길것입니다. DASCA SDS덤프는 시험문제변경에 따라 업데이트하여 항상 가장 최선버전이도록 유지하기 위해 최선을 다하고 있습니다.
