Microsoft MD-102 test cram - Endpoint Administrator
Posted at 1/15/2026 06:50:10
View264
Replies4
P.S. Free 2026 Microsoft MD-102 dumps are available on Google Drive shared by Exam4Free: https://drive.google.com/open?id=16hxpHIywOYEY1TpUvSs2uhmVhf5ETNCD
The learning material is open in three excellent formats; Microsoft MD-102 dumps PDF, a desktop Microsoft MD-102 dumps practice test, and a web-based Microsoft MD-102 dumps practice test. Microsoft MD-102 dumps is organized by experts while saving the furthest down-the-line plan to them for the Microsoft MD-102 Exam. The sans bug plans have been given to you all to drift through the Endpoint Administrator certificate exam.
Microsoft MD-102 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Protect devices: In this topic, aspiring administrators get knowledge about configuration of endpoint security and management of device updates by using Intune.
| | Topic 2 | - Manage applications: This section covers skills to manage application implementation, manage updates, and manage performance to support the performance of users to meet the needs of business organizations.
| | Topic 3 | - Prepare infrastructure for devices: This topic focuses on adding devices to Microsoft Entra ID and enrolling devices to Microsoft Intune.
| | Topic 4 | - Manage and maintain devices: This section deals with managing, troubleshooting, and safeguarding various devices. It also covers methods to ensure that they meet organizational policies and security standards.
100% Pass Microsoft - MD-102 - High-quality Endpoint Administrator Latest Dumps PdfThree versions of MD-102 study materials will be offered by us. Eech one has its own advantage, you can pick the proper one for yourself. We also have free demo for you, you can have a look at and decide which version you want to choose. We also have the live chat service and the live off chat service to answer all questions you have. If you failed to pass the exam , money back will be guaranteed, if you have another exam to attend, we will replace another MD-102 Study Materials for you freely.
Microsoft Endpoint Administrator Sample Questions (Q44-Q49):NEW QUESTION # 44
To which devices do Policy1 and Policy2 apply? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us/intune/device-profile-assign
NEW QUESTION # 45
You have a Microsoft 365 subscription. The subscription contains computers that run Windows 11 and are enrolled in Microsoft Intune. You need to create a compliance policy that meets the following requirements:
* Requires BitLocker Drive Encryption (BitLocker) on each device
* Requires a minimum operating system version
Which setting of the compliance policy should you configure for each requirement? To answer, drag the appropriate settings to the correct requirements. Each setting may be used once, more than once, or not at all.
You may need to drag the split bar between panes or scroll to view content.
NOTE: Each correct selection is worth one point,
NEW QUESTION # 46
Your company has computers that run Windows 10 and are Microsoft Azure Active Directory (Azure AD)-joined.
The company purchases an Azure subscription.
You need to collect Windows events from the Windows 10 computers in Azure. The solution must enable you to create alerts based on the collected events.
What should you create in Azure and what should you configure on the computers? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
A screenshot of a computer Description automatically generated
https://docs.microsoft.com/en-us ... log-analytics-agent
NEW QUESTION # 47
Your company has an Azure Active Directory (Azure AD) tenant named contoso.com that contains several Windows 10 devices.
When you join new Windows 10 devices to contoso.com, users are prompted to set up a four- digit pin.
You need to ensure that the users are prompted to set up a six-digit pin when they join the Windows 10 devices to contoso.com.
Solution: From the Microsoft Entra admin center, you configure automatic mobile device management (MDM) enrollment. From the Microsoft Intune admin center, you configure the Windows Hello for Business enrollment options.
Does this meet the goal?
Hello for Business is an alternative sign-in method that uses Active Directory or an Azure Active Directory account to replace a password, smart card, or a virtual smart card. It lets you use a user gesture to sign in, instead of a password. A user gesture might be a PIN, biometric authentication such as Windows Hello, or an external device such as a fingerprint reader.
Intune integrates with Hello for Business in two ways:
An Intune policy can be created under Device enrollment. This policy targets the entire organization (tenant-wide). It supports the Windows AutoPilot out-of-box-experience (OOBE) and is applied when a device enrolls.
An identity protection profile can be created under Device configuration. This profile targets assigned users and devices, and is applied during check-in.
https://docs.microsoft.com/en-us/intune/protect/windows-hello
NEW QUESTION # 48
Your company standardizes on Windows 10 Enterprise for all users.
Some users purchase their own computer from a retail store. The computers run Windows 10 Pro.
You need to recommend a solution to upgrade the computers to Windows 10 Enterprise, join the computers to Azure AD, and install several Microsoft Store apps. The solution must meet the following requirements:
* Ensure that any applications installed by the users are retained.
* Minimize user intervention.
What is the best recommendation to achieve the goal?
More than one answer choice may achieve the goal.
Select the BEST answer.
- A. Windows Autopilot
- B. Windows Deployment Services (WDS)
- C. a Windows Configuration Designer provisioning package
- D. Microsoft Deployment Toolkit (MDT)
NEW QUESTION # 49
The Microsoft MD-102 exam offers a great opportunity for beginner and experienced to validate their expertise in a short time period. To do this they just need to pass the Endpoint Administrator MD-102 Certification Exam which is not an easy task. And Exam4Free offfers latest MD-102 exam practice, exam pattern and practice exam online.
New MD-102 Test Guide: https://www.exam4free.com/MD-102-valid-dumps.html
- MD-102 Exam Quizzes 💛 PDF MD-102 Cram Exam 👪 Latest MD-102 Braindumps Files 📴 Go to website { [url]www.testkingpass.com } open and search for MD-102 to download for free 🏨MD-102 Exam Certification Cost[/url]
- Dumps MD-102 Discount 🌽 New MD-102 Study Guide 🦞 PDF MD-102 Cram Exam 📴 Search for ☀ MD-102 ️☀️ on ☀ [url]www.pdfvce.com ️☀️ immediately to obtain a free download ⏭MD-102 Valid Real Exam[/url]
- MD-102 exam study material - MD-102 exam guide files - MD-102 latest pdf vce 🐸 Search for ➽ MD-102 🢪 and obtain a free download on ➥ [url]www.prep4away.com 🡄 🦩MD-102 Valid Real Exam[/url]
- Pass Guaranteed Microsoft - MD-102 - Endpoint Administrator CHigh Pass-Rate Latest Dumps Pdf 🌂 ⇛ [url]www.pdfvce.com ⇚ is best website to obtain MD-102 for free download 📇MD-102 Hot Questions[/url]
- Use Real Microsoft MD-102 PDF Questions [2026] - 100% Guaranteed Success 🔽 Copy URL ➥ [url]www.verifieddumps.com 🡄 open and search for ➠ MD-102 🠰 to download for free 🕖Exam MD-102 Fees[/url]
- Avoid Exam Failure With Microsoft MD-102 PDF Questions 🤕 Download { MD-102 } for free by simply entering [ [url]www.pdfvce.com ] website 🏐MD-102 Latest Practice Questions[/url]
- MD-102 exam study material - MD-102 exam guide files - MD-102 latest pdf vce 💆 Simply search for ☀ MD-102 ️☀️ for free download on { [url]www.troytecdumps.com } 🐖Latest MD-102 Demo[/url]
- Free PDF MD-102 - Updated Endpoint Administrator Latest Dumps Pdf 🗜 Open { [url]www.pdfvce.com } enter ➥ MD-102 🡄 and obtain a free download 🥞MD-102 Practice Test[/url]
- MD-102 Clearer Explanation 🚮 MD-102 Exam Certification Cost 🦲 MD-102 Practice Test 🐭 Download MD-102 for free by simply searching on [url]www.pass4test.com ⚽Latest MD-102 Demo[/url]
- Microsoft certification MD-102 exam training programs 🔱 Search for ⇛ MD-102 ⇚ and download exam materials for free through [url]www.pdfvce.com ✊MD-102 Latest Practice Questions[/url]
- MD-102 Exam Quizzes 🧙 Latest MD-102 Demo 😿 MD-102 New Dumps Questions 🔁 Copy URL ⇛ [url]www.validtorrent.com ⇚ open and search for ✔ MD-102 ️✔️ to download for free 🥽MD-102 Latest Practice Questions[/url]
- www.stes.tyc.edu.tw, evavinagradav.alboompro.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, witpacourses.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Exam4Free MD-102 dumps from Cloud Storage: https://drive.google.com/open?id=16hxpHIywOYEY1TpUvSs2uhmVhf5ETNCD
