[General] TDA-C01 Latest Mock Exam - TDA-C01 Test Topics Pdf
97
General TDA-C01 Latest Mock Exam - TDA-C01 Test Topics Pdf
Posted at 1/15/2026 07:04:47      View165 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4Test TDA-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1IRORNl5eJKBrjtMwxDTjP_0mSOaMWxE6
Pass4Test is a leading platform that has been helping the Tableau TDA-C01 exam candidates for many years. Over this long time period, countless Tableau TDA-C01 exam candidates have passed their dream Tableau Certified Data Analyst (TDA-C01) certification and they all got help from valid, updated, and real Tableau Certified Data Analyst (TDA-C01) exam questions. So you can also trust the top standard of Tableau TDA-C01 exam dumps and start TDA-C01 practice questions preparation without wasting further time.
The TDA-C01 Certification Exam is an online, proctored exam that consists of 36 multiple-choice questions. TDA-C01 exam is timed and lasts for 2 hours. Candidates who pass the exam are awarded the Tableau Certified Data Analyst certification. Tableau Certified Data Analyst certification is valid for two years and can be renewed by passing a recertification exam.
Tableau TDA-C01 Test Topics Pdf, Guaranteed TDA-C01 SuccessExperts at Pass4Test have also prepared Tableau TDA-C01 practice exam software for your self-assessment. This is especially handy for preparation and revision. You will be provided with an examination environment and you will be presented with actual exam Tableau TDA-C01 Exam Questions. This sort of preparation method enhances your knowledge which is crucial to excelling in the actual certification exam.
Tableau TDA-C01 certification exam covers a wide range of topics, including data preparation, data analysis and visualization, and dashboard creation. It is a comprehensive exam that requires candidates to have a deep understanding of Tableau's functionality, features, and best practices. TDA-C01 Exam is designed to test a candidate's ability to use Tableau to create effective visualizations, perform complex data analysis, and communicate insights to stakeholders.
Tableau Certified Data Analyst Sample Questions (Q10-Q15):NEW QUESTION # 10
A Data Analyst is given the following table and asked to create a flow that adds a date field to the data. This field should automatically update as new dates (months) are added to the original table.
Which technique should the analyst use as the first step to achieve this in Tableau Prep?
  • A. A wildcard search for multiple tables in the Input step
  • B. A wildcard search to pivot in the Pivot step
  • C. A Rows to Columns Pivot step
  • D. An Aggregate step to reshape the data
NEW QUESTION # 11
You have the following dataset.
You plan to create a dashboard that will be filtered to show only data that is relevant to a specific Tableau user based on the Tableau_User_Name field You need to create a boolean calculated field to place on the data source finer Which formula should you use for the filter?
  • A. ISFULLNAMETableu_USER_NAME))=USERNAME()
  • B. NAME Tableau-USER-NAME)
  • C. NAMEUSERNAME()
  • D. USERNAME()=(Tableau_USER_NAME)
NEW QUESTION # 12
You have a data source that contains data tor every city in the Unites States. The following is a sample of the data.
You need to use the City dimension to create a dynamic filter that snows the cities that have a population greater than one million Which type of filter should you use?
  • A. General filter
  • B. Condition filter
  • C. Wildcard filter
  • D. Top filter
To use the City dimension to create a dynamic filter that shows the cities that have a population greater than one million, you should use a condition filter. A condition filter is a type of filter that shows only the values that meet a specified condition based on a measure or a calculation. You can create a condition filter by dragging a dimension to the Filters shelf and selecting Condition from the dialog box. Then you can enter a formula or choose an option that defines your condition.
In this case, you want to create a condition filter based on Population, which is a measure. You can drag City to the Filters shelf and select Condition from the dialog box. Then you can choose By field from the tab and select Population > Sum > Greater than > 1000000 from the drop-down lists. This will create a condition filter that shows only the cities that have a sum of population greater than one million.
The other options are not correct for this scenario. A general filter is not a specific type of filter, but a term that refers to any type of filter in Tableau. A wildcard filter is a type of filter that shows only the values that match a specified pattern or string, such as "New*" or "*ton". A top filter is a type of filter that shows only the top or bottom N values of a measure or dimension based on a ranking or an aggregation. References:
https://help.tableau.com/current/pro/desktop/en-us/filtering.htm https://help.tableau.com/current/pro/desktop
/en-us/filtering_condition.htm https://help.tableau.com/current ... tering_wildcard.htm
https://help.tableau.com/current ... /filtering_topn.htm
NEW QUESTION # 13
You have a dataset that contains sates dat
a. The following is a sample of the data.
You need to return a value of true if a month has sales greater than $50 000. otherwise the formula must return a value of false.
Which two formulas achieve the goal Choose two
  • A. SUM{[Sales]) IN (50000)
  • B. MAX< [Sales], 50000)
  • C. [Sales] > 50000
  • D. IIF(SUM< [Sales] )>50000, TRUE, FALSE)
B) IIF(SUM([Sales]) > 50000, TRUE, FALSE)
D) [Sales] > 50000
The IIF function is a logical function that returns one value if a condition is true, and another value if the condition is false. In this case, the condition is SUM([Sales]) > 50000, which means that the sum of sales for a month is greater than $50,000. The function will return TRUE if the condition is true, and FALSE if the condition is false.
The comparison operator > is a logical operator that returns TRUE if the left operand is greater than the right operand, and FALSE otherwise. In this case, the operands are [Sales] and 50000, which means that the sales for a month are greater than $50,000. The operator will return TRUE if the sales are greater than $50,000, and FALSE otherwise.
The other options are not correct for this scenario. The IN function is a logical function that returns TRUE if a value is in a set of values, and FALSE otherwise. In this case, the value is SUM([Sales]), which is not in the set of values (50000). The function will always return FALSE. The MAX function is an aggregation function that returns the maximum value in a field or expression. In this case, the field or expression is [Sales], 50000, which is not valid syntax. The function will return an error. Reference: https://help.tableau.com/current ... ons_logical.htm#IIF https://help.tableau.com/current/pro/desktop/en-us/operators.htm https://help.tableau.com/current ... s_aggregate.htm#MAX Explanation:
The two formulas that will return a value of true if a month has sales greater than $50,000, otherwise the formula must return a value of false, are:
NEW QUESTION # 14
You have the following bar chart.
You want the chart to appear as shown in the Mowing exhibit.
What should you add?
  • A. A reference line
  • B. A reference band
  • C. An average line
  • D. A distribution band
NEW QUESTION # 15
TDA-C01 Test Topics Pdf: https://www.pass4test.com/TDA-C01.html
P.S. Free 2026 Tableau TDA-C01 dumps are available on Google Drive shared by Pass4Test: https://drive.google.com/open?id=1IRORNl5eJKBrjtMwxDTjP_0mSOaMWxE6
