Authorized NCP-DB-6.10 Test Dumps | NCP-DB-6.10 Reliable Exam Preparation
Posted at 1/15/2026 08:12:19
Getting the related NCP-DB-6.10 certification in your field will be the most powerful way for you to show your professional knowledge and skills. However, it is not easy for the majority of candidates to prepare for the NCP-DB-6.10 exam in order to pass it, if you are one of the candidates who are worrying about the exam now, congratulations, you can have our NCP-DB-6.10 Study Tool. We can assure you that you can pass the exam as well as getting the related certification in a breeze with the guidance of our NCP-DB-6.10 test torrent.
Our NCP-DB-6.10 certification has great effect in this field and may affect your career even future. NCP-DB-6.10 real questions files are professional and high passing rate so that users can pass exam at the first attempt. High quality and pass rate make us famous and growing faster and faster. Many candidates compliment that NCP-DB-6.10 Study Guide materials are best assistant and useful for qualification exams, and only by practicing our NCP-DB-6.10 exam braindumps several times before exam, they can pass NCP-DB-6.10 exam in short time easily.
NCP-DB-6.10 Reliable Exam Preparation - NCP-DB-6.10 Exam OutlineStop hesitating. If you want to experience our NCP-DB-6.10 exam dumps, hurry to click Fast2test.com to try our pdf real questions and answers. You can free download a part of the dumps. Before you make a decision to buy Fast2test exam questions and answers, you can visit Fast2test to know more details so that it can make you understand the website better. In addition, about FULL REFUND policy that you fail the NCP-DB-6.10 Exam, you can understand that information in advance. Fast2test.com is the website which absolutely guarantees your interests and can imagine ourselves to be in your position.
Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Sample Questions (Q254-Q259):NEW QUESTION # 254
An administrator needs to migrate a large 1/0-intensive database that doesn't support multi-disk layout.
How should the storage be provisioned with Era to support the database while optimizing performance?
- A. vDisk based provisioning
- B. Volume Group with Load Balancing
- C. Storage Spaces
- D. Volume Group
In Nutanix Era, a Volume Group is the recommended storage provisioning method for a large I/O- intensive database that doesn't support a multi-disk layout. A Volume Group in Nutanix Era is a collection of disks that can be managed as a single entity, providing a way to aggregate the storage capacity of multiple disks into a larger storage unit. This allows for better performance optimization as it enables the database to leverage the combined I/O capabilities of all the disks in the group. It's important to note that while other options like Load Balancing, Storage Spaces, and vDisk based provisioning can also be used in certain scenarios, a Volume Group is specifically designed for situations where a single, high-performance storage unit is required.
NEW QUESTION # 255
An administrator needs to apply a minor version upgrade of the PostgreSQL software to an Era provisioned instance.
Which step should the administrator take before applying the patch?
- A. Go to the Software Profile Version widget and click update.
- B. Put the database instance into maintenance mode.
- C. Migrate a new software profile.
- D. Create a new software profile.
Nutanix Database Service (NDB) supports automated minor version upgrades for PostgreSQL.
Before applying the patch, the administrator should create a new software profile. This is because the software profile contains the database engine binaries and other software required to run the database engine. Therefore, to apply a minor version upgrade, a new software profile with the updated binaries needs to be created. Once the new software profile is created, it can be used to patch the PostgreSQL database.
NEW QUESTION # 256
An administrator needs to assign a VLAN to provide IP address to a database VM. What is the procedure to create the Network Profile?
- A. Create Network Profile, Select the VLAN, Define IP Range.
- B. Create Network Profile, Define IP Range. Add the VLAN.
- C. Add VLAN, Create Network Profile. Define IP range.
- D. Add VLAN, Define IP range, Create Network Profile.
In Nutanix Database Service (NDB), a Network Profile is used to define networking configurations for database VMs, including VLAN assignments and IP address ranges. The correct procedure to create a Network Profile that assigns a VLAN and provides IP addresses to a database VM is as follows:
Create Network Profile: Start by initiating the creation of a new Network Profile within NDB. This is done from the NDB interface under the "Network" or "Profiles" section.
Select the VLAN: During the Network Profile creation process, you specify the VLAN that the database VM will use. This involves selecting an existing VLAN configured in the Nutanix cluster (e.g., via Prism Element) or defining a new VLAN ID if applicable.
Define IP Range: Finally, you define the IP address range (e.g., a subnet or specific IPs) that will be assigned to the database VM(s) within the selected VLAN. This ensures the VM receives a valid IP address for communication.
NEW QUESTION # 257
Which two processes should an administrator take to create a software profile version for a newly- released Oracle ISc patch? (Choose two.)
- A. 1. Create new software profile version from the original software profile using the cloned VM where OPatchAuto was run successfully using Era Gul.
2. Mark the original patch profile as deprecated. - B. 1. Create new software profile version from the original software profile using the cloned VM where OPatchAuto was run successfully using Era Gul.
2. Mark the original patch profile as hidden. - C. 1. Download the required patch from MyOracle Support
2. Apply the patch to the Oracle HomGrid Home on a cloned VM of the gold image using O PatchAuto
3. Ensure success of patch application - D. 1. Download the required patch from Microsoft Support.
2. Apply the patch to the Oracle Home/Grid Home on e cloned VM of the gold image using OPatchAuto utiliv.
3. Ensure success of patch application.
To create a software profile version for a newly-released Oracle ISc patch, an administrator should follow these steps:
Download the required patch from MyOracle Support. This is because Oracle patches are typically available from MyOracle Support, not Microsoft Support. Apply the patch to the Oracle Home/Grid Home on a cloned VM of the gold image using OPatchAuto. OPatchAuto is a utility provided by Oracle that automates the process of applying patches to a database.
Ensure success of patch application. It's important to verify that the patch has been applied successfully to avoid any issues down the line.
Create a new software profile version from the original software profile using the cloned VM where OPatchAuto was run successfully using Era GUI. This step is necessary to ensure that the new patch is included in the software profile.
Mark the original patch profile as hidden. This step is optional but can be useful for keeping the software profile clean and organized.
Please note that these answers are based on the information available as of my last update in
2021 and may need to be verified with the most recent Nutanix Database Automation (NCP-DB) documentation or resources.
NEW QUESTION # 258
An administrator wants to enable Multi-Cluster management on an Era installation. Which prerequisites must be satisfied to complete this task?
- A. Hypervisor version supported, port 9440 open between Era VM and clusters
- B. Hardware version supported, DHCP Network enabled on Nutanix cluster
- C. AOS version supported, static VLAN setup in Era Networks
- D. Database Server VMS version supported. Network Profiles setup
For enabling Multi-Cluster management on an Era installation, the hypervisor version must be supported and port 9440 must be open between the Era VM and clusters. This ensures that the Era VM can communicate with the clusters for management tasks.
NEW QUESTION # 259
Fast2test provides thousands of examinations training materials especially for Nutanix certifications. We not only provide key knowledge points and detailed questions answers and explanations but also excellent after-sale service. You purchase NCP-DB-6.10 latest practice exam online, you will not only get exam materials but also one year tracking service. We will always provide NCP-DB-6.10 latest practice exam online the first time for your free downloading within one year.
NCP-DB-6.10 Reliable Exam Preparation: https://www.fast2test.com/NCP-DB-6.10-premium-file.html
And i can say no people can know the NCP-DB-6.10 exam braindumps better than them since they are the most professional, (NCP-DB-6.10 training materials) In fact, many factors contribute to the unfavorable situation, like furious competition, higher requirements and so on, You can practice the questions on practice software in test engine real NCP-DB-6.10 exam scenario or you can use simple PDF format to go through all the real NCP-DB-6.10 exam questions, Nutanix Authorized NCP-DB-6.10 Test Dumps Taking IT certification exam and getting the certificate are the way to upgrade yourself.
Select the Boys.mov file in the Artwork folder NCP-DB-6.10 Valid Exam Prep for the chapter and click Open, But once we start the thing, our potential will beyondwhat you think, And i can say no people can know the NCP-DB-6.10 Exam Braindumps better than them since they are the most professional.
Quiz NCP-DB-6.10 - Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 –Trustable Authorized Test Dumps(NCP-DB-6.10 training materials) In fact, many factors contribute to the unfavorable situation, like furious competition, higher requirements and so on, You can practice the questions on practice software in test engine real NCP-DB-6.10 exam scenario or you can use simple PDF format to go through all the real NCP-DB-6.10 exam questions.
Taking IT certification exam and getting the certificate are the NCP-DB-6.10 way to upgrade yourself, It’s structured in such a way so you can easily access the page you need with a single click.
- NCP-DB-6.10 Latest Test Fee 🌲 NCP-DB-6.10 New Cram Materials 🦱 NCP-DB-6.10 Reliable Exam Simulator 🚐 ▷ [url]www.dumpsmaterials.com ◁ is best website to obtain ⇛ NCP-DB-6.10 ⇚ for free download 🐜Test NCP-DB-6.10 Score Report[/url]
- NCP-DB-6.10 New Cram Materials 💺 NCP-DB-6.10 Latest Test Fee 🐵 Download NCP-DB-6.10 Demo 🚘 Enter ▷ [url]www.pdfvce.com ◁ and search for “ NCP-DB-6.10 ” to download for free 👦NCP-DB-6.10 Latest Test Fee[/url]
- Authorized NCP-DB-6.10 Test Dumps - Free PDF Quiz Nutanix NCP-DB-6.10 First-grade Reliable Exam Preparation 🧜 Search for “ NCP-DB-6.10 ” and download it for free on ⮆ [url]www.torrentvce.com ⮄ website 😼NCP-DB-6.10 Reliable Test Prep[/url]
- NCP-DB-6.10 Reliable Exam Simulator 👇 Exam NCP-DB-6.10 Quick Prep 🌰 NCP-DB-6.10 Valid Exam Dumps 📶 Simply search for ➽ NCP-DB-6.10 🢪 for free download on [ [url]www.pdfvce.com ] 😧Test NCP-DB-6.10 Score Report[/url]
- Regualer NCP-DB-6.10 Update ⤵ NCP-DB-6.10 Free Dumps 🔑 NCP-DB-6.10 New Cram Materials 🎓 Search for ➥ NCP-DB-6.10 🡄 and download it for free immediately on ▶ [url]www.prepawayete.com ◀ 🚺NCP-DB-6.10 Valid Exam Dumps[/url]
- Excellent NCP-DB-6.10 Exam Questions make up perfect Study Brain Dumps - Pdfvce 🚣 Easily obtain ➤ NCP-DB-6.10 ⮘ for free download through ➤ [url]www.pdfvce.com ⮘ 🥶NCP-DB-6.10 Latest Demo[/url]
- Free PDF 2026 Nutanix NCP-DB-6.10: Efficient Authorized Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Test Dumps ⛵ Search for 「 NCP-DB-6.10 」 and download exam materials for free through ✔ [url]www.pdfdumps.com ️✔️ 🔥Exam NCP-DB-6.10 Quick Prep[/url]
- NCP-DB-6.10 Valid Torrent 🐜 NCP-DB-6.10 Trustworthy Exam Content 🤤 NCP-DB-6.10 Valid Exam Dumps ⏏ Download ➥ NCP-DB-6.10 🡄 for free by simply searching on ➡ [url]www.pdfvce.com ️⬅️ ⚓NCP-DB-6.10 Reliable Test Prep[/url]
- Excellent NCP-DB-6.10 Exam Questions make up perfect Study Brain Dumps - [url]www.prepawayete.com 🅰 Search for ⮆ NCP-DB-6.10 ⮄ on ➽ www.prepawayete.com 🢪 immediately to obtain a free download 🖱NCP-DB-6.10 Exam Sample Online[/url]
- NCP-DB-6.10 Quiz 🎤 NCP-DB-6.10 Latest Test Fee 🦕 NCP-DB-6.10 Valid Torrent 🛳 Enter ☀ [url]www.pdfvce.com ️☀️ and search for ▛ NCP-DB-6.10 ▟ to download for free 💚Test NCP-DB-6.10 Dumps Free[/url]
- Free PDF 2026 Nutanix NCP-DB-6.10: Efficient Authorized Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Test Dumps 🤸 Search for ( NCP-DB-6.10 ) and obtain a free download on { [url]www.prepawaypdf.com } 🎁NCP-DB-6.10 Valid Exam Dumps[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, tutor.shmuprojects.co.uk, www.stes.tyc.edu.tw, www.ted.com, nairolinkshomeschool.com, Disposable vapes
